Re: edlebrock 800 cfm thunder series opinions.... [Re: BobR] #634433
03/09/10 10:50 PM
03/09/10 10:50 PM
Sidney Ohio
9SecRoadRunner Offline
Sidney Ohio
you'll need two in order to beat one holley.
Maybe if you're tuning on them......
Wayne
humm 3 big block posters use them in pairs....not saying an 800 eddy is junk, just not as good as a 750 Holley.
any dyno PROOF to back up that claim?
I'm at a lot of drag strips and I don't see them on anything other than mild street/strip combos.
I'm at alot of dragstrips too, still no DYNO PROOF offered up here, just the normal moparts "EXPERTS" bs
You Thinking It's So Doesn't Make It a Fact
Re: edlebrock 800 cfm thunder series opinions.... [Re: 9SecRoadRunner] #634434
03/10/10 12:29 AM
03/10/10 12:29 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Wow, thanks folks!
Mike
1969 Dodge Dart Swinger
Re: edlebrock 800 cfm thunder series opinions.... [Re: MikeyT] #634435
03/10/10 12:54 AM
03/10/10 12:54 AM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
I have never tried the 800 but i had 2 of the 750 edelbrocks on my 65 plymouth that weighed 3500 pounds. with my 11.1 440 and a set of box stock edelbrocks 750 carbs i was running 10.50 @ 128 in the 1/4 and that was with out using the nos i had on it at the time. i will be running the same set up on my Indy EZ headed roller camed 440 in my 73 dart. if anybody has a set of 750 Holley dp i could try. i would be more than willing to do a 1/4 mile shoot out between both set of carbs. Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: edlebrock 800 cfm thunder series opinions.... [Re: 9SecRoadRunner] #634436
03/10/10 07:40 AM
03/10/10 07:40 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Wayne
hey show us your dyno numbers. the door swings both ways
Re: edlebrock 800 cfm thunder series opinions.... [Re: Quicktree] #634437
03/10/10 12:26 PM
03/10/10 12:26 PM
Sidney Ohio
Sidney Ohio
Wayne
I'm not the one saying that Holleys make more power, I didnt say Carters / Eddy's did either, all I ask for was PROOF from all of you saying one way or the other, not opinions, PROOF
Re: edlebrock 800 cfm thunder series opinions.... [Re: 9SecRoadRunner] #634438
03/10/10 12:48 PM
03/10/10 12:48 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I have not had any personal experience with the Thunder Edelbrock. But I have had a lot with the 440 HP Carter AVS. When the Carter is tuned to the combo it will take an equal amount of tuning with the Holley 750 DP to match the Carters ET. The Holley MPH will be slightly better. This testing was done on a 7.50 in the 1/8 440 at 3700# with 727. If it is a street strip car mileage a drivability will be better with the carter.
Getting old just means you were smarter than some and luckier than others.
Re: edlebrock 800 cfm thunder series opinions.... [Re: dannysbee] #634439
03/10/10 01:08 PM
03/10/10 01:08 PM
....... If it is a street strip car mileage a drivability will be better with the carter.
I don't believe that.......A/F is A/F......and you can make a Holley do anything you want.......
Wayne
Re: edlebrock 800 cfm thunder series opinions.... #634440
03/10/10 01:18 PM
03/10/10 01:18 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
When both the holley and the carter are tuned for the best performance at the track. The carter will get better mileage and be more responsive on the street. Its just a matter of design.
Re: edlebrock 800 cfm thunder series opinions.... [Re: 9SecRoadRunner] #634441
03/10/10 01:20 PM
03/10/10 01:20 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Wayne
Uh, look at the thread title. He asked for opinions. It sounds like you don't have one either way sooo....
Re: edlebrock 800 cfm thunder series opinions.... [Re: sasquatch] #634442
03/10/10 02:05 PM
03/10/10 02:05 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Gee I have a customer that has a pair of the 800 AVS carbs on a Stage V inline intake and fairly mild hemi that only made 845 on the pump and runs 9.50s at close to 3600 lbs. No gurus, no secret voodoo magic, out of the box and we changed the jets a little. Just junky street carbs though. Alot of the NSS guys run them on the wedges and the hemis due to class rules and they crack off plenty of 9 second passes all the time.
Todd.
key word in this is PAIR....
