Re: What fluid to use in A833 manual transmission?
[Re: dustergirl340]
#1906300
09/04/15 12:59 PM
09/04/15 12:59 PM
Posts: 5,133 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
I have always run 90 weight in all my Chrysler factory stock four speeds since the early 70s. I have run both Nash and Liberty, really the same stuff with 90 weight also. The Chrysler manuals give all the same speeches about hot climate use 140 colder climate use 80-90 or ATF. If you use your car for what it is build for, 90 weight I would recommend. If it is a trailer queen it really does not matter but I still prefer 90 Weight anyways.
1971 HEMI E BODY REGISTRY
[Re: chargervert]
#1906305
09/04/15 01:05 PM
09/04/15 01:05 PM
Posts: 28,137 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Use 90 weight gear oil,my friend did what the book said,and it cost him two 4 speed transmissions. The front bearing in one came out in peices. ATF may be ok in northern Alaska,but not down here. ATF worked fine in Texas heat behind a twin turbo 440. I ran an 18 spline 833 as well as an OD box.
[Re: Supercuda]
#1906323
09/04/15 01:38 PM
09/04/15 01:38 PM
Posts: 27,344 Rio Linda, CA
John_Kunkel
The Erection Connection
Rio Linda, CA
Resurrecting a 5 year old thread? Yep, and the same old anecdotal experiences.
[Re: 383man]
#1906483
09/04/15 06:38 PM
09/04/15 06:38 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
I believe Mopar went to ATF in very cold climate's because of complaints about hard shifting when cold with gear oil in very cold places. Yes... First time I saw it was around 1980...
[Re: dustergirl340]
#1906550
09/04/15 09:14 PM
09/04/15 09:14 PM
Posts: 21,142 Niles , Ohio
therocks
Niles , Ohio
Ron I agree in Ohio it gets cold also.I drove the 65 everywhere for years in the winter.Never used anything but ger grease and shifted fine.Must work I still have the same trans after 46 years.Rocky
Chrysler Firepower
[Re: dustergirl340]
#1906650
09/04/15 11:54 PM
09/04/15 11:54 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
My '65 came form the factory with SAE 140, and that's what the FSM called for. It was very "firm" in very cold weather, but a pleasure when warmed up. It also suppressed a lot of the gear rattle that non-OD A833s are known for.
The FSM did allow for lighter oils in cold / very cold climates, and I did try SAE 90, but immediately went back to 140 - it was like a hot knife through butter, awesome shift quality.
Later FSMs did "lighten up".
I personally believe heavier lubricants reduce wear. Today I use SAE 85W140 multigrade.
Rick
[Re: dustergirl340]
#1906873
09/05/15 12:31 PM
09/05/15 12:31 PM
Posts: 4,393 Morrow, OH
markz528
Morrow, OH
My Mom had a 65 6 cylinder 3 speed on the column Belvedere in Connecticut. Not sure what it originally came with, but my Dad put gear oil in it. Very hard to shift so put ATF in it and it solved the problem.
I flat towed my race car with that car for a while and kept breaking tranny gears - not sure if the ATF contributed or not.
[Re: TheMoparJunky]
#1906877
09/05/15 12:42 PM
09/05/15 12:42 PM
Posts: 21,935 Kirkland, Washington
Pacnorthcuda
Racers back in the day used it I think because of the heat transfer, fluid compaction(none) and high viscosity rather than the thick sludgy, stinky straight 80 or 90. Because it is a gear box, I would recommend straight 80(The same for the diff.). Like all petroleum products after heated up to temp. it will become very viscous so there won't be as much "Fluid/power loss". The dynamic seals will not act differently with either.
The Mopar Junky "fluid compaction" "become very viscous" "dynamic seals" Umm......OK.
[Re: 383man]
#1906922
09/05/15 02:04 PM
09/05/15 02:04 PM
John_Kunkel
Rio Linda, CA
Yes Rick you are right about the gear rattle in Neutral as I forgot about how bad that can get with the lighter fluid. Neutral Gear Rattle (NGR) is also a big issue in some modern cars that run ATF, that's why synthetics are popular in them....quiets the rattle but doesn't stiffen the shifting like heavy gears lubes would.
[Re: John_Kunkel]
#1907308
09/06/15 05:14 AM
09/06/15 05:14 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Yes Rick you are right about the gear rattle in Neutral as I forgot about how bad that can get with the lighter fluid. Neutral Gear Rattle (NGR) is also a big issue in some modern cars that run ATF, that's why synthetics are popular in them....quiets the rattle but doesn't stiffen the shifting like heavy gears lubes would. That is so true as we had so many different manual tranny fluids at the dealer that they called for in different models that Dodge made up a chart for the techs so we knew what each model trans called for when I left in 2009. And many were synthetic as you stated. Ron
