Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: BleedDodge] #634273
03/09/10 09:09 PM
03/09/10 09:09 PM
Maryland USA
beatgoeson Offline
beatgoeson  Offline
Maryland USA
275 MM is 275 MM
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: BleedDodge] #634274
03/09/10 10:47 PM
03/09/10 10:47 PM
NY usa
540challenger Offline
NY usa
A 275/50 shouldn't be wider than a 275/60, just shorter.
not correct the best way i can expalin tire size is that 275/60 which means
275 is the section width and 60 mean that 60% of the section widith is the side wall.
Which means a 275/50 has about 10% more width in the thread area b/c the sidewall is only 50% of the section width"275".
From mickey thomas site
3753R P275/50R15 26 X 11.50R15 Thread width 10.5"
3754R P275/60R15 28 X 11.50R15 Thread width 9.5"
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: beatgoeson] #634275
03/09/10 10:51 PM
03/09/10 10:51 PM
IN
ahy Offline
ahy  Offline
IN
Depends on what you mean by fit? With full suspension travel and at least a finger or more for clearance I think 255's are about max with stock spring placement. With the rear lifted and little or no fender clearnace bigger could work.
Leaf springs work best for handling if they are almost flat. Plus a lower CG is better so lifting the rear for clearance does hurt handling. It all depends on what you're after.
If you want clearance plus wide tires, either moving the springs in or adding fender flares may be the best option.
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: 540challenger] #634276
03/09/10 11:41 PM
03/09/10 11:41 PM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
I think I know the answer, but this statement completely lost me.
I forbid my content here from being learned and used by artificial intelligence systems.
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: kielbasa] #634277
03/10/10 12:13 AM
03/10/10 12:13 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
15X8 wide, 4.5 inches backspace, 295-50-15 Cooper Cobras. Fit and don't rub on my car with stock suspension. If you want to run a 10 inch wide rim you will need to relocate the springs in. There are a few places that sell kits to do this, I recommend Dr. Diff, a member on this board.
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: Azzkikrcuda] #634278
03/10/10 12:16 AM
03/10/10 12:16 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
My dads challenger, 10 wide rims and relocation kit.
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: jcc] #634279
03/10/10 07:57 AM
03/10/10 07:57 AM
NY usa
NY usa
Ya after i read what i wrote i was thinking i better just copy and paste something online that explains it. After i read 3 different explaination i thought wow my doesn't seem too bad now.
either way 275/50 is wider and shorter then a 275/60
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: cudaized] #634280
03/11/10 06:59 AM
03/11/10 06:59 AM
P
PasiR Offline
PasiR  Offline
P
It got to the point that I did not want to drive wth the 295 50 15 tires anymore.
I switched back to 275 50 15 for more than one reason, though.
I need traction. The standard street tires would not grip on dry roads.
So back to the "Sticky" soft tires.......
What's the size of that soft one?
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: PasiR] #634281
03/11/10 08:42 AM
03/11/10 08:42 AM
South, FL
cudaized Offline
cudaized  Offline
South, FL
275 50 15
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: cudaized] #634282
03/11/10 08:48 AM
03/11/10 08:48 AM
South, FL
cudaized Offline
cudaized  Offline
South, FL
They fit better during suspension travel.
1970 `cuda: stock wheel well, stock spring location, 15 x 8 rim with 4.5" back spacing.
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: jcc] #634283
03/11/10 01:02 PM
03/11/10 01:02 PM
Slantytown
DUFFMAN Offline
Ask And Ye Shall Receive
DUFFMAN  Offline
Slantytown
I think I understand too, Let me take a crack at explaining it.
275 is the section width of the tire. This means that it's measured from the inside wall to the outside wall of the tire on a recommend wheel width. Because the sidewalls of a 60 profile tire will generally bow out more than the side walls of a 50 profile tire there is less difference between the TREAD width and the SECTION width of the tire. So yes a 275/50R15 will have a slightly wider tread width than a 275/60R15, but I don't think it ever reaches 10% when comparing the same line of tire from the same brand.
More so, a 275/60/15 from one tire line could have the same tread width as a 275/50/15 from another tire line IF the 60 profile has a stiffer sidewall construction. Generally this won't be true since the reason for going to a lower profile tire is to decrease sidewall deflection, so lower profile tires will generally have a stiffer sidewall. I hope this makes sense.
Anyway, the original poster was asking for fit-up on his car, all that matters then is section width which will be the same whether its a 60 profile or a 50 profile tire.
No longer taking $h!t from anyone!
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: DUFFMAN] #634284
03/11/10 02:32 PM
03/11/10 02:32 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
If you really want to run a tire and wheel combo that big you have to narrow the springs or jack it way up in the back. I did the spring relocation on a b body and widened the inner fenders it was really easy and most people would never even know since i just widened the stock inner fenders.
67' charger 499 RB 10.57 at 127
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: DUFFMAN] #634285
03/11/10 03:46 PM
03/11/10 03:46 PM
NY usa
NY usa
you said alot better ten I did. I said about 10% since both my friend and i had mickey tomas street radials installed on a 15x8 rim he had 275/60r15 i had 275/50/R15 I measured both tires as best i could eyeing it up with a tape measue and i was around 1 inch wider in the thread area maybe more"it as over a year ago when we noticed this and i don't remember it too clear." but the difference if width is very clear when looking at the two side by side
