Re: 68 69 Power brake booster backing plate wire guide
[Re: Dougsmopars]
#632821
03/10/10 06:54 PM
03/10/10 06:54 PM
Posts: 3,967 S.I. N.Y.
1MYTGTX
S.I. N.Y.
Looks like the same one I have on my power booster pictured above.....how much longer does it need to be?
1MYTGTX
[Re: Dougsmopars]
#632823
03/16/10 09:53 PM
03/16/10 09:53 PM
Posts: 21,539 It's a dry heat
gtx6970
It's a dry heat
bump this back up. I was walking around a local junkyard today and found out 1969-70 B-body disc brake cars use the same wire guide as manual drum brake cars. @ 3-3/4" long as far as power drum brake cars , I found none
see pics exibit a - 1970 power dic brake charger
[Re: gtx6970]
#632824
03/16/10 09:55 PM
03/16/10 09:55 PM
gtx6970
It's a dry heat
exibit B I'll have to double ck what car this one was
[Re: gtx6970]
#632825
03/16/10 09:55 PM
03/16/10 09:55 PM
gtx6970
It's a dry heat
finally exibit C 1969 Superbee - with manual brakes
[Re: Dougsmopars]
#632832
04/30/10 02:54 PM
04/30/10 02:54 PM
gtx6970
It's a dry heat
something I found out today. These are galvanized and not zinc plated,,,,,,,,,,interesting ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) I sent this one out yesterday to get quotes, so we'll see what happens next.
[Re: gtx6970]
#632833
04/30/10 02:58 PM
04/30/10 02:58 PM
gtx6970
It's a dry heat
BTW,What I've found out so far
They are used on at least 66 thru 1970 B-body. AND there are actually 2 different lengths.This one and a second one approx 1" shorter And there doesn't seem to be any rhyme or reason to which car received which length. Be it manual +/or power drum or power disc brakes.
