Page 2 of 6 1 2 3 4 5 6
Re: New Edelbrock Carb Issues. [Re: 05dakota] #631958
03/08/10 03:36 PM
03/08/10 03:36 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
and enjoy fuel leaks.
And less MPG. Some people do care about that, especially when they drive from Indiana to Columbus OH (that's a pre-emptive rebuttal for Swingin's 'who cares about MPG?' response, which is always right around the corner ).
Here are 2 links:
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: New Edelbrock Carb Issues. [Re: Fury Fan] #631959
03/08/10 03:40 PM
03/08/10 03:40 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Here are 2 links:
FWIW, I got just as good mpg in my 340 swinger w/ the 750DP as the 625 carter. any 4bbl carb is going to use gas if your foot is on the floor. I'd guess 90% of our members have other cars they drive for "gas milage" if you want gas milage go buy a honda.
Re: New Edelbrock Carb Issues. [Re: Mr.Yuck] #631960
03/08/10 07:39 PM
03/08/10 07:39 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Holleys are just a little simpler and more crude in terms of operation over the Carter design. If they work for you best, great. It doesnt matter who made the carb. You can make the same power when the carb, any carb, is properly set and matched to the combo.
Re: New Edelbrock Carb Issues. [Re: moper] #631961
03/08/10 08:26 PM
03/08/10 08:26 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
That didn't work for me. I had a 750 Edelbrock Performer. Tuned on that thing till I was cross eyed. Ended up with a 750 Holley. Tuned on it till it flat out performs that Edelbrock 750 greatly! There's no comparison as far as I'm concerned. That's just my experience.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: New Edelbrock Carb Issues. [Re: Mr.Yuck] #631962
03/09/10 01:26 AM
03/09/10 01:26 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
run,dont walk and take that junk back.
get your cash back.
get a holley ASAP.
that is a smart man. why anybody would run a Carterbrock carb is besides me. go get a holley and be done.
I've been waiting for the "buy a Holley" guy to show up. He never misses an Edelbrock carb thread.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: New Edelbrock Carb Issues. [Re: MY340] #631963
03/09/10 06:22 AM
03/09/10 06:22 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
You can probably find as many Holley bashers out there as there are Carter/Edelbrock. Everybodies experiences are different and when it's bad for some reason you tend not to like or want it.I've had lots of 600/750 Holleys and have had problems with the pump diaphrams not lasting on some, causing leaks. The Holley I took off to replace with the Edelbrock I had replaced the pump diaphram twice within a year. Same issue I had with my 74 Roadrunner back in 1978 and others along the line. I prefer the Carter type setup.But there are Carter issues too. Each has its own in my opinion.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: New Edelbrock Carb Issues. [Re: TimS] #631964
03/09/10 08:08 AM
03/09/10 08:08 AM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I got a couple of 650 thunderseries carbs I plan to run on a hemi. I got them from Tim Banning at FHO. One of the things I remember him saying was not to run too much fuel pressure. He said 5-6psi tops. Too much fuel pressure will raise the float level which gets exaggerated with a hot engine. Might be something to look into. The instruction say the same thing. Not sure if the AFB style have the same instructions.
Re: New Edelbrock Carb Issues. [Re: torkrules] #631965
03/09/10 09:08 AM
03/09/10 09:08 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I think that has more to do with leverage (or less leverage than the Holley) on the needle and seat than performance. If someone has enough of an issue that no matter what swapping of the adjustbale stuff can't make it better, it was probably the wrong carb. Doesnt matter if it's Holley, Demon, Carter, Edelbrock, Predator, or a custom shop's carb. I think a TON of the Edelbrock 750 issues are the result of that fact that there's two types, and only one is a performance carb while the other is listed as a mileage peice. It's like taking the Holley off a factory 383 and expecting it to run like a 3310 on a modified engine. It's unrealistic.
Re: New Edelbrock Carb Issues. [Re: Junky] #631966
03/09/10 09:25 AM
03/09/10 09:25 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you can quote me on this... a 750 Eddy/carter carb will NOT ever out perform a holley 750DP ever. You can take your "well tuned 750 eddy" and I'll drop an out of the box 750DP on an beat you by a tenth, and that's before I tweak it. I've run both types on many cars. The eddy design is great for a driver but if you want anykind of performance you'll want a holley.
Can he make his 750 work, sure but it should be pretty close out of the box. I'd pump up the metering rods, and it is a good idea to have a good vacuum gauge when you are trying to tune a carb. As mentioned if you have too much fuel pressure they will flood. I also had issues w/ the floats on hard turns and stops they stall. If you have a big block and you want an eddy buy the 800 thunder. They don't seem to have the issues like the 750.
If you want to beat a 750 Holley w/ an Eddy 750 you'd better have 2 on the car..
Coming soon!!!!
Re: New Edelbrock Carb Issues. [Re: Mr.Yuck] #631967
03/09/10 11:32 AM
03/09/10 11:32 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
The 750 Edelbrock I speak of was a vacuum secondary carb.
Re: New Edelbrock Carb Issues. [Re: torkrules] #631968
03/09/10 01:07 PM
03/09/10 01:07 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I sat down and watched the little how to CD that comes with the Edelbrock and the demonstrator states 7psi max on fuel pressure for the AFB style carbs. I'm running a little over 6. I initially suspected a possible over pressure conditon but around 6 shouldn't push those seats off. I popped the top on the 600 and found the float adjustments to be off per the video. I reset those and really improved idle on it.
Re: New Edelbrock Carb Issues. [Re: Junky] #631969
03/09/10 02:00 PM
03/09/10 02:00 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Actually, it's not. It's airflow sensing thru the secondary and uses a counterweight or spring to counteract the air door's tendency to flop open. Holleys use a pressure drop off the primary bores to open the secondaries, hence the name vacuum secondary.
72, do try not to sound so ignorant and insecure about things...lol
Re: New Edelbrock Carb Issues. [Re: moper] #631970
03/09/10 02:07 PM
03/09/10 02:07 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
wha? I never said a eddy 750 is vacuum...I know how it works,.
Re: New Edelbrock Carb Issues. [Re: Mr.Yuck] #631971
03/09/10 03:48 PM
03/09/10 03:48 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
That was directed at me. I realize that it's not a "vacuum" secondary carb, just a reference that most everyone uses. I was just pointing out and clarifying what carb I was speaking of that I worked with, that it wasn't a double pump.
The "72" part was directed at you.
Re: New Edelbrock Carb Issues. [Re: Mr.Yuck] #631972
03/09/10 06:02 PM
03/09/10 06:02 PM
ILLINOIS
V
volaredon Online content
volaredon  Online Content
V
ILLINOIS
you could not give me a Holley 4 bbl;
as far as MPG and the "buy a Honda" BS, myself, no; MPG is not "the" "#1" when I buy a vehicle; BUT I want the vehicle to get the best MPG it can--FOR WHAT IT IS! My brother had a 360-powered Ramcharger; had a holley 1850 on it; what a POS; it never seen more than 9MPG; I dropped a TQ on there and it ran so much better than it did with the Holley, it was unbelieveable- and MPG went up to 14; just by the carb swap; same vehicle, same powertrain, just a different carb. so (to a point) MPG does matter.
and every time I try to "experiment" wiuth a Holley my results are about similar; I always wind up going back to Carter.
Re: New Edelbrock Carb Issues. [Re: volaredon] #631973
03/09/10 07:21 PM
03/09/10 07:21 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Same here, Carter is the best all around carb for a driver. I care more about 1 mpg than I do 1 tenth.
Don't be the exception.
Re: New Edelbrock Carb Issues. [Re: Supercuda] #631974
03/09/10 08:46 PM
03/09/10 08:46 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
The edelbrock AVS 800 is one of the best carbs out , for a mild big block. That 800 will slap a street avenger silly. Selection depends what you are putting it on. auto or manual makes a big difference. A 4 speed with some gearing, install a 750 DP and forget-about-it.
Volaredon- look into a Q jet , they are a bulletproof carb. After working them, actually can be Great all around.
Re: New Edelbrock Carb Issues. [Re: Supercuda] #631975
03/09/10 08:48 PM
03/09/10 08:48 PM
Santa Barbara, CA
HitIt Offline
HitIt  Offline
Santa Barbara, CA
Regarding the origInal post a 750 edelbrock out of the box is way overkill for a 383 unless it's a really hot engine.
Also relative fuel efficiency is a general sign of a well tuned car and a proper setup.
Edelbrock or Holley, I don't care.
Re: New Edelbrock Carb Issues. [Re: TimS] #631976
03/09/10 09:28 PM
03/09/10 09:28 PM
Mid-Atlantic
Scatransit Offline
Scatransit  Offline
Mid-Atlantic
This worked for me...First, install a valley pan with blocked off exhaust crossovers. Then install a 1/4" carb insulator kit - Mr.Gasket has 'em...It's a laminated design with 2 aluminum plates and 3 gaskets...I painted the edges flat black to make less noticeable. If you're using a stock intake, make sure to get the one with 4 individual barrel holes as opposed to the one with one big square hole.
This will greatly reduce "hot soak" issues....regardless of carb brand used. Yes, cold driveabilty may be affected slightly, but unless it's a daily driver, it's not a big deal...
Re: New Edelbrock Carb Issues. [Re: HitIt] #631977
03/10/10 07:40 AM
03/10/10 07:40 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I agree about the 750 being overkill for a 383 for general driveability use. The Edelbrock tech told me the same thing. The 750 would be more suited for a 440HP engine like I have in my 68 Super Bee right now or a hopped up 383 with more cam , head work etc... Mine is stock. The 600 was a better choice as I got to run 2 new ones on it back to back. My issues weren't actual performance related so I got the chance to evaluate from that standpoint. I use new and old age Carters on all my other cars with no problems. All but the stock Holley six barrel I have on my 70RR but those ar two's.
