Motor plate waterpump sealing questions???
#630631
03/04/10 07:47 PM
03/04/10 07:47 PM
Posts: 205 Chicago,Illinois
nosboy
Chicago,Illinois
I have a Brand new 1/4 inch thick 6061 T6 motor plate . I was told to use YAMABOND (the stuff that seals casehalves on motorcycle and snowmobile engines) and NOT to use gaskets... I rebuilt snowmobile motors in the 1980's and 1990's and used YAMABOND without issues... Does ANYONE use stuff like that in place of water pump gaskets????? BTW,,, its a 4.5 inch bore WORLD PRODUCTS 440 block stroked to 572..
Re: Motor plate waterpump sealing questions???
[Re: nosboy]
#630632
03/04/10 07:50 PM
03/04/10 07:50 PM
Posts: 5,620 long island NY
Ari440
long island NY
permatex ultra grey
on my moter plate to water pump
no gaskets
1.39 9.85 - 137 mph
[Re: nosboy]
#630634
03/04/10 08:01 PM
03/04/10 08:01 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I use Yamabond or a good RTV... I like the Mopar black RTV... no gaskets
[Re: MR_P_BODY]
#630635
03/04/10 08:04 PM
03/04/10 08:04 PM
Posts: 2,524 PA
moparacer
PA
Black RTV here too.
Never any problems.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: nosboy]
#630638
03/04/10 08:47 PM
03/04/10 08:47 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
If you guys that use sealer have to take the water pump off at the track for some reason what do you do? I've run my MP-15 gaskets on my POS motorplate that is all eaten from corrosion with NO sealers and no leaks either. I drive it on the street, race it at the track and I know it's flexing all over up there and yet the nuts on my water pump studs stay at the same torque level un like others I've used in the past. When I pull my motor (soon I hope) the gaskets WILL go back on for another reuse.
[Re: Ari440]
#630640
03/04/10 09:17 PM
03/04/10 09:17 PM
Posts: 2,563 S.E. Michigan
cl440
S.E. Michigan
permatex ultra grey
no gaskets
have used both Ultra Grey and Ultra Black and have never had a leak. I had a leak with gaskets before. Got a little hairy at the 1/8 mile one night and lost me a round!! Never again!!
[Re: roadhazard]
#630642
03/04/10 10:35 PM
03/04/10 10:35 PM
who makes the mp-15 gaskets?
#630643
03/04/10 10:39 PM
03/04/10 10:39 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Moparts member Roadhazard makes them. I want 4,PM me to give me the skinny on how to get them.
[Re: roadhazard]
#630647
03/05/10 12:36 AM
03/05/10 12:36 AM
Posts: 4,647 aotearoa
rebel
aotearoa
i have Mezzaires reverse flow pump. with std water pump gaskets they leak as they don't line up the holes correctly.(why do gaskets have D shaped holes? ). anyway i make my own gaskets with round holes, smear synthetic grease on them & have had zero failures in reguard to water leaks, my gaskets also get recycled a few times & it's so easy to clean up. one wipe with the rag & we're done & the grease seems to prevent the ali motor plate from pitting. kind of a win win situation. gaskets are made from the packaging from the beers that go in the frig. howzat for recycling?
[Re: rebel]
#630648
03/05/10 04:36 AM
03/05/10 04:36 AM
Posts: 315 Russiaville, IN
mopar376d
Russiaville, IN
I quit using gaskets last year and use "The Right Stuff" No leaks on either car.
Why does divorce cost so much?
Because it is worth it!!!!!
[Re: roadhazard]
#630649
03/05/10 12:28 PM
03/05/10 12:28 PM
The MP-15 material was originaly developed for the heavy duty diesel market. Designed to maintain bolt torque on low to medium torque applications. This material does not wick fluids as may be seen with some carb base gaskets or intake gaskets when they get fuel soaked. When this happens it brakes down the binders that hold the polymers and fibers together and then you start the degeneration of the gasket. This MP-15 material also has a high shear and tensil strain rating and is very flexible.
Superformance Products, Greg
I will try those when I am ready to assemble
[Re: Ari440]
#630650
03/05/10 12:55 PM
03/05/10 12:55 PM
Posts: 2,007 Apollo, PA.
B1MAXX
Apollo, PA.
permatex ultra grey
no gaskets
same here
