no i got a double pully/120 amp denso/ext regulated alt from a member here
I had to flip it and use the single ear as the pivot on the 440 with stock non a/c brackets/pullys
a double pully should be on a 89-up pre mag 318 truck with a/c= or van,IIRC
i got another one from a tbi van from the u-pull for the sb
the sb one does not looked fliped in the last pic posted
fliping it on the BB moved the batt post away from the head and did not need shortend as some have done??? with just the right spaceing the feild studs just clear the head/freeze plug boss and vc edge
