sfi fluid damper from 440 source #627496
02/28/10 11:07 PM
02/28/10 11:07 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Anyone had any problems or success running one of 440 source's sfi fluid dampers?
I'm still running a stock one and have already had one slip,took it off and found several cracks in the steel.Lucky it did'nt come apart.
Let me know I'm ready to buy.-John
Re: sfi fluid damper from 440 source [Re: jcastle1] #627497
03/01/10 12:14 AM
03/01/10 12:14 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
they are tight as hell to fit on the crank & they have an annoying recess that makes fitting your front pulley on square to be a pita. i made an alloy disc to sandwich between the damper & pulley. so far so good but i'll be upgrading to an ATI this coming off season.
