Rotating Assembly Weight Reduction
#626807
02/28/10 12:53 PM
02/28/10 12:53 PM
Posts: 2,054 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
I balanced my rotating assembly yesterday, and if my math is correct, I lost almost 4 3/4 lbs. New pistons, pins, rings, retainers = 888 grams, old = 1113 grams (old DC/TRW pistons) New H-beam rods were only 8 grams lighter than stock LY rods, but are bushed and have ARP 2000 7/16" cap screws and should be MUCH stronger. Plus King Pro rod bearings are 4g less than Clevitte 77. That comes to 237g/ hole X 8 = 1896g, plus the 240g removed from crank shaft = 2136g total weight removed from rotating assembly. (1g = 28.349 oz.) 3126g = 75.34 oz = 4.7 lbs Anyone know what the engine will "see" because of this? ![](/ubbthreads/images/graemlins/confused.gif) And then we add approx. 3.5 more points of compression (from 10.0:1 to 13.5:1) and a set of alum Stealth heads, we can do more of this ![](/ubbthreads/images/graemlins/biggrin.gif) Brian
Re: Rotating Assembly Weight Reduction
[Re: AndyF]
#626810
02/28/10 01:03 PM
02/28/10 01:03 PM
Posts: 1,880 USA
Ron Silva
USA
You did good! I have always been a big believer in weight reduction.
Here is 10 pounds of dead weight, GONE!
SRT DEMON ONE SEAT
[Re: '72CudaRacer]
#626811
02/28/10 01:07 PM
02/28/10 01:07 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Sounds like we're in the same boat. I dropped 7.7+ lbs off my rotating assy, upped the CR from 8.6-1 to 12-1, and opened the heads up a lot and now have no clue what's in store
[Re: '72CudaRacer]
#626813
02/28/10 01:20 PM
02/28/10 01:20 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Herb Adams had a comparison chart on rotatating vs static weight. On a rotating assembly each 1# loss was worth 2 HP. So if you were to accept that as Fact, then a 4.7# loss = 9.4 HP Whether its true or not. No doubt a 4.7# loss off the rotating assembly is a win, win deal. mike ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: tboomer]
#626814
02/28/10 01:39 PM
02/28/10 01:39 PM
'72CudaRacer
Mooresburg, Tn
Interesting,Brian...What did the ly rod weigh...
Stock LY rod, with a 1/8" hole in the top of the pin end, pin end floated (not bushed), ARP bolts (stock style), nuts, & no bearings = 860g The big ends were not resized if I remember correctly. I measured them and found them to be acceptable.
[Re: Ron Silva]
#626815
02/28/10 01:42 PM
02/28/10 01:42 PM
'72CudaRacer
Mooresburg, Tn
Did you rifle drill the crank??? That shouldn't affect the balance, because it's on the center line of the rotating mass, just lower total weight, correct?
[Re: '72CudaRacer]
#626818
02/28/10 02:15 PM
02/28/10 02:15 PM
Sport440
Canton, Ohio
EDIT:My calc says 3126g = 110.2664oz = 6.8915# ![](/ubbthreads/images/graemlins/shruggy.gif) All I can say is Hold On and Sinch Your Belts Tighter
I have 1g = .0352 oz, 1 oz = 28.349g. Or is that not correct?
Maybe its not exact but roughly 454 grams = 1#
454/16 oz. = 28.375 grams a oz. So you are correct.
That 110.266 grams per oz. is a mistake. His total grams converted to pounds is correct. mike
3126/454= 6.8854 pounds.
[Re: sturmenater]
#626820
02/28/10 03:54 PM
02/28/10 03:54 PM
Posts: 1,235 TN
65racer
2009 IHRA World Champion
TN
Brian, how's it going? Seems like your gonna step it up quite a bit. ![](/ubbthreads/images/graemlins/thumbs.gif) Get it ready, racing season is just around the corner. Maybe I should have made mine quicker, but didn't want to mess with my combo. Good luck Dave ps,,,,, If anyone around your neck of the woods is looking for a new enclosed trailer, send them my way, I have that 28' I need to get rid of. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: Sport440]
#626822
02/28/10 06:19 PM
02/28/10 06:19 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
So he took off 6.88# not 4.7# correct? ![](/ubbthreads/images/graemlins/confused.gif) I was using a converter that I found online and yes I made a mistake 1g = .03527396oz Hope I didn't cause any problems ![](/ubbthreads/images/graemlins/blush.gif)
[Re: roadhazard]
#626824
02/28/10 07:51 PM
02/28/10 07:51 PM
Sport440
Canton, Ohio
Hey Greg I see what happend with the 4.77# vs the 6.88# Brian had both sets of numbers listed in grams 3126 - 2136 and typoed a 3 and 2 switch. You did the math for the 3126, Brian did the math for 2136. After rereading the post the 2136 gram number is the correct one. So 4.7# is the number. 6.8 - 4.7 its all in the right direction. mike ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Sport440]
#626825
02/28/10 11:25 PM
02/28/10 11:25 PM
'72CudaRacer
Mooresburg, Tn
I think I need to take a break. Yesterday at the machine shop, Dan is letting me do as much as I can. (I'm a mechanic, not a machinist) Anyway, I'm weighing everything and balancing rods & pistons and filling out balancing work sheet. I get done and he comes over to set up balancer, and finds that I've recorded small end at 255g and big end at 297g (597g was correct) for a rod total of 552g, 300g light. Good thing he don't trust me yet! ![](/ubbthreads/images/graemlins/whistling.gif) Sorry about that. Brian
[Re: '72CudaRacer]
#626826
02/28/10 11:30 PM
02/28/10 11:30 PM
WILD BILL
BROOK PARK, OH
Maybe that's why Scott and Dale did all my balancing on a day I wasn't there to help ![](/ubbthreads/images/graemlins/tongue.gif)
