Re: Piston pin/rod bushing clearance???
[Re: '72CudaRacer]
#626666
02/28/10 12:31 PM
02/28/10 12:31 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
.0003 is too tight. shoot for .0008-.001
RIP Monte Smith
[Re: '72CudaRacer]
#626669
02/28/10 08:37 PM
02/28/10 08:37 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
If your using Ross pins in the Ross pistons I believe they recommend .001 or more for N/A gasoline motors drag racing. I would open them up a little more on a street/strip motor on the rod to pin clearances, .0010 to .0013. I went out to my shop and looked at several sets of instructions for Ross pistons in my motors, the instructions do not make any reccommendatios on wrist pin clearances Both sets of instructions are for Ross custom made pistons, Ross does not include the wrist pins with thier custom made pistons, you have to order them seperate and pay extra for them Try taking one of the pistons, if you can, and measure the wrist pin bore at room tempature and then heat it up in a oven for twenty minutes at 200 F and see how much the wrist pin hole grows or schrinks
[Re: Cab_Burge]
#626670
02/28/10 09:18 PM
02/28/10 09:18 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
my machinist set mine at .001
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: '72CudaRacer]
#626673
02/28/10 11:41 PM
02/28/10 11:41 PM
Cab_Burge
.0003 is way to tight I'm assuming this is a full floating wrist pin,not press fit is it? ask him how much clearance you have for the rod bushing to the wrist pin and how much between the pistons and wrist pins Also ask about how much end clearances between the end of the wrist pins and the retainers( minimum .001 IMO) The end play should be enough to be felt with your finger stuck into the wrst pin pushing it back and forth while holding the piston in your other hand or in a rod vice
[Re: Cab_Burge]
#626676
03/01/10 12:08 AM
03/01/10 12:08 AM
Posts: 2,049 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Brain, I wouldn't, and don't, use grease on wrist pin installation. Use the oil your going to run the motor with
I was thinking the same thing. Using Lubriplate these days is akin to using placigauge to build a engine.
