Adjusting Adjustable pushrods on Hyd cam #626386
02/28/10 12:54 AM
02/28/10 12:54 AM
NORTHERN CA
HUSTLESTUFF Offline OP
NORTHERN CA
I am trying to figure out my valve train noise. I have a 340 with a Hughes 1928 cam hydraulic. I used the stock rockers and with the stock push rods and had a lot of lifter noise so they said I probably needed a longer push rod due to the difference of the base circle. I need to figure out how to set the preload. Anyone have some suggestions. When I set them where I think they should be there is no compression, ie valve opened. Thanks in advance. Mike
Re: Adjusting Adjustable pushrods on Hyd cam [Re: HUSTLESTUFF] #626387
02/28/10 01:17 AM
02/28/10 01:17 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
the adj pushrods are made to get the right length. then you have a set made.
I am truckless..
Re: Adjusting Adjustable pushrods on Hyd cam [Re: HUSTLESTUFF] #626388
02/28/10 01:51 AM
02/28/10 01:51 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
easy way would be with intake off ,not what you wanted to hear !
turn engine till lifter you are working on is on cam base circle adjust pushrod till it just touches the lifter plunger and the rocker arm seat , add 1/2- 34 turn and lock it there !
do all 16 same way .
some newer cam profiles cause lifter noise !!
Re: Adjusting Adjustable pushrods on Hyd cam [Re: calrobb2000] #626389
03/01/10 06:30 PM
03/01/10 06:30 PM
