Re: For all of you that think slapper bars dont work ...
[Re: maximum entropy]
#626247
03/01/10 08:07 PM
03/01/10 08:07 PM
Posts: 34,934 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I watched yah make a couple runs ..
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: SLOW67]
#626249
03/02/10 01:24 AM
03/02/10 01:24 AM
Posts: 336 Creston, Iowa
340man4ever
Creston, Iowa
Car sounds tough!
Curator at Adams County Speed Shop
[Re: 340man4ever]
#626250
03/02/10 09:19 AM
03/02/10 09:19 AM
Posts: 4,988 new jersey usa
11secdart
new jersey usa
The $20 bars I bought at Carlisle also have the shock bolt in them, I had to longate the U bolt holes on the mounting plate to fit my trucks larger bolt pattern.
[Re: cudasteve68]
#626252
03/02/10 06:28 PM
03/02/10 06:28 PM
Posts: 429 Sherman Texas
The Shocker
Sherman Texas
1.60 short times with a 8.0" tires and spinning? Like someone stated, they were a crutch to help and problem else where. Springs, Shocks or whatever. I run a 9.0" tire with springs. I have no snubber or bars. I foot brake the car with a 727 and 60's are always one the money at any track. The best 60 foot is a 1.42 Now I would work on getting the car to hook with out the slapper bars. After the car is working "right" with out the bars, and see what happens then.
Not sure if it was spinning before or not.I do know that it was rapping the springs badly .It dented both shocks where they hit the rearend housing .Big diff between a 727 first gear and a PG first gear .Gears multiply torque big time ,and also create better 60's in the process if it hooks up.Try to get a 1.42 60' with your motor with a PG and 4.10's on 8.5 slicks with 3500 launches (Traction bars or not ).Saying one motor/car gets these 60' times and this one doesnt without listing other details is kinda like people saying they are better at setting the car up because they beat a 440 big block with their 360 ,but they left out small details like :The 440 had 9 to 1 compression and stock cam in a 4,400 pound New Yorker and their 360 had 14 to 1 compression and a .600 lift solid roller cam and was in an altered.Small little details like that can have small little bearings on things .See what im getting at ?
[Re: bigdad]
#626253
03/02/10 06:57 PM
03/02/10 06:57 PM
The Shocker
Sherman Texas
Thanks for posting the pic of my Dart .I stole it and used it for my avator on the other site we are on .I like the pic for sum reason .I also sent you a pm over there.I still have yet to meet you in person though ,even though i figured i would Saturday .Lots of people there at that race this year ...
[Re: joedust451]
#626256
03/02/10 08:06 PM
03/02/10 08:06 PM
The Shocker
Sherman Texas
I'm wanting to run slapper bars, now after seeing this thread, i'm going to, should be fine for what i'm doing. What Lakewood bars do i need for an A body??
The ones i got for cheap are real old .I have been told by a few that they are old Foxcraft Comp lift bars.I was told by the guy that i got them from , that they were purchased in 1970 for a GM by his father.The hole spread for the U bolts on the spring plates were the same as my Darts and had a plce for the shock bolt on both sides front and back.The only problem i had was that the plates hit the backing plates on the brakes slightly .I trimmed off about a 1/4 inch and the went on no problem .The snubbers i used are just Mopar front A arm bumpers (cost me like $6.00 at Oreillys).They are directly under the spring eyes in the second hole of the bars .I kept trimming the snubbers (only about 3/8 of an inch) till they were touching the spring with me in the car ,but not compressed.Seemed to work well .I also used a flat plate with 2 holes drilled in it to go between the spring and the bars at the rear clamp location behind the axle with a U bolt ,to make it fit snug .Mine are slightly nosed down on my car ,but get perfectly straight when i launch.It lifts the rear off the car as well as the front ...
[Re: goldmember]
#626257
03/02/10 08:06 PM
03/02/10 08:06 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I plan to run home made cal tracks, and factory /6 springs for my Super Stock Plymouth making near 900hp... here is a pic of my homemade bottom leaf spring bracket, and homemade disc brake setup.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
