Re: For all of you that think slapper bars dont work ...
[Re: Quicktree]
#626226
02/28/10 11:13 AM
02/28/10 11:13 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
While I think any forward progress is good, I agree with most of the posters about it helping but only at the level you're at now. Something else too... How sure are you that the springs are good? That might explain the "wandering" you feel in your seat. Not traction, just not good suspension control at higher speeds. That is a sing of bad springs too. The deal with the lack of traction bars on mopars comes from having a snubber that's properly set up and traction bars, which can interfere with each other. I also agree that a Glide with 4.10s will hit much softer than a 727 with the deeper first. I think you would go faster with 3 gears providing you can actually hook it with the extra torque that gives.
[Re: Quicktree]
#626227
02/28/10 11:18 AM
02/28/10 11:18 AM
Posts: 429 Sherman Texas
The Shocker
Sherman Texas
Such negativity. The OP spend $30 which led to a huge improvement to his car. He can now move forward from this point ( with all the great info found here on Moparts) to replace springs and/or shocks as he deems necessary.
how do you know there was a huge improvement? I think they could help him at his level but he didn't give us before and after numbers? no negativity I amm all for it if it helped him no matter if it wouldn't work for everybody
Heres a vid of my car the last time i ran before the slapper bars.Notice how it comes off the line and jerks to the right .No lift on the rear of the body and this was with the springs clamped in three spots on the front segments.It still wrapped the springs bad ,so bad that the shocks had dents in them from rolling into the rearend housing.My 60 foots ranged anywhere from 1.65 most of the time to 1.71.Best 60 at that point was 1.638 once on a well prepped track.Now my 60's are 1.60 or 1.61 everytime and it lifts the front and back of of the car evenly with no spring wrap ,and pops the wheels off the pavement.My point is that noone said before that slapper bars work in sum applications on Mopars.I always heard a blanket statement that "They just dont work on Mopars".All im trying to say is that they do work if setup right ...
http://www.youtube.com/watch?v=BIIyWUefEYQ
[Re: The Shocker]
#626228
02/28/10 12:11 PM
02/28/10 12:11 PM
dulcich
Nice results! I had a set of HD Lakewoods that had been on my shelf for 20 years after pulling them off a 69 Super Bee project car. I figured what the heck and put them on my Plymouth and they really work great.
You guys that say they just stiffen the front segment are wrong; they act as a lever to apply lift at the front spring eye. Most of the info in those old Mopar manuals shouldn't be taken for gospel. The traction bars can be very effective with some combinations, but of course there are other and sometimes better ways to get the job done. -dulcich
[Re: The Shocker]
#626229
02/28/10 12:14 PM
02/28/10 12:14 PM
Quicktree
in that video it looked like the car went where it was aimed and then you corrected it. it didn't jerk right it just drove where it was headed. there are way to many varibles that can effect traction. so only a back to back same day same conditions could prove it helps one way or the other. you will hear some people say snubbers don't work also, and yes they are both band aids to weak or bad springs. but they can help prevent spring wrap if adjusted right just like your slappers. but add another 100hp then come back and tell us if they will work.
[Re: The Shocker]
#626230
02/28/10 12:49 PM
02/28/10 12:49 PM
Posts: 10,036 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Shocker, they are working well if you have no spin off the line. Might require some better shocks down the road to expand the range of hp and torque they can control. I wouldn't worry too much about those that want to pick apart what you are doing. Just refine your data recording for your own purpose, keep an eye on what out there works, and how. With enough shock control and travel, combined with front suspension tuning, you might not need to upgrade till you need a full cage! I
[Re: Sport440]
#626232
02/28/10 02:18 PM
02/28/10 02:18 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
Slapper bars are just like any suspension mod. They either work for you or they don't, for what ever reason. Find the reason, make the adjustment , or modification, and it can work.
The only drawback from using a slapper that I saw, happened to my buddy. He ran an AMC rear end from a AMX in his 343 powered Spirit.
First time out at the track he broke the spring perches off. Had that repaired.
The next time out, he spun the center of the axle housing, causing the tubes to break the factory welds. The driveshaft took a beating and he also broke the rear tailshaft housing of the 4 gear trans.
Well, he had all that repaired and switched to an automatic AMC 727.
He has no issues now. The car hooks hard and fans the rear segment of the springs like a peacock. It was something to see. I wish I had a camera with me that day.
The only concern about slappers has always been breakage somewhere in the suspension, etc.
He is planning on upgrading to Cal Tracs eventually.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: Quicktree]
#626233
02/28/10 03:34 PM
02/28/10 03:34 PM
The Shocker
Sherman Texas
Your right the car picked up and i learned my lesson about how slapper bars wont work on a Mopar .Im not saying that slapper bars are the only option or the best ,but they are very cost affective .Please keep in mind that we are just a bunch good old boys having fun at nostalgia drags ,not a bunch gold chainers that just sit back and throw money at are cars .If a cheap solution is solving the spring rap problem on my car (which is the only car im concerned with at this point ),then i will take it.If you want to send me a set of Caltracs and mono leafs for free ,i will be glad to give them a try for you ,and let you know what happens .Till then i will use whats working now .BTW i have never heard the statement that "slapper bars will work fine on a Mopar up to a certain hp ",i have always heard the blanket statement "they wont work on a Mopar ".I was just trying to show that they can work is all ,but anything can be picked to death ,and what if'd to death as well ...
[Re: gregsdart]
#626234
02/28/10 03:39 PM
02/28/10 03:39 PM
The Shocker
Sherman Texas
Thanks for the support man ... Im gunna get a set of adjustable shocks for it next .I only race the car a half a dozen times a year proly ,but i always want to go a little faster each time out (who doesnt).She will come around a little at time ,solving one problem at a time...
[Re: Quicktree]
#626237
02/28/10 04:39 PM
02/28/10 04:39 PM
Posts: 4,993 new jersey usa
11secdart
new jersey usa
I can top that! I bought a pair for $20 at Carlisle last year for my 92 D150. I race it occasionally and didn`t want to spend the $ for Cal-Tracs, I couldn`t leave over 1,600 with out wheel hop and tire spin. I put the bars on , clamped every leaf in front of the rear housing and replaced the air shocks with a set of B body Ranchos I had on my Dart when I had S/S springs and now I can leave at 2,000 with out spinning. It only runs low-mid 15s but its not spinning anymore.
[Re: 11secdart]
#626238
02/28/10 05:13 PM
02/28/10 05:13 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Did you make all those changes at one time, if so I'll bet the biggest factor was the adjustable shocks that didnt let them hit the end to cause the lift on the axle. Anything that helps the car is worth the price, but every thing DOESNT work on ALL cars
[Re: MR_P_BODY]
#626239
02/28/10 09:06 PM
02/28/10 09:06 PM
11secdart
new jersey usa
I know that! I`ve been flogging my Dart for 28 years and have made a lot of changes that didn`t help/work. I did the mods in stages, I think the shocks helped as I can adjust them and they have to be better than stiff air shocks. I was pretty happy with the minimal investment in the setup as its not my primary race vehicle. If I ever get a few extra bucks I`d like to try a drag radial or some type of dot legal race tire I can drive to the track with. As I said its not real fast but everytime I race it I go rounds.
[Re: 11secdart]
#626240
02/28/10 11:12 PM
02/28/10 11:12 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
My homemade traction bars worked for me when I added about 600 more horsepower...from roughly 450 hp NA..... Hope they will take about 300 more...we'll see soon enough
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: maximum entropy]
#626242
03/01/10 01:38 PM
03/01/10 01:38 PM
Posts: 371 Fort Worth, Texas
Mike Miller
Fort Worth, Texas
I ran slapper bars on the Spirit with great success. A friend of mine has a Spirit also (a little quicker and lighter than mine) that had slapper bars on it too. He bought CalTracs and installed them on his and didn't pick up anything at all.... we had the slappers dialed in that good. Mine was preloaded a bit on the right side and the car launched straight and level and would get a couple of inches of air every time and it seemed to launch good no matter how bad the track was. Both of our cars had a little problem when shifting into second on marginal tracks though. You could feel the rear end lift, but not bite. My 60's were right at 1.58/1.59 when it was a good day and the car was running 7.25 or so.... that was in real good air at Ennis. Here is a video of the car launching against another car I built. the wagon is using Cal Tracs. http://www.youtube.com/watch?v=wOE6iwt9Dao I fixed this...... DOH!
[Re: The Shocker]
#626244
03/01/10 05:31 PM
03/01/10 05:31 PM
Posts: 1,613 Burlington,Ont.
77DragracerR/T
Burlington,Ont.
It's nice to try and improve the performance of your car with simple fixes just to see if it works or not.I know todays traction aids are way better then what we had years ago and in fact i'm still running a snubber on my and i have no reason to spend the big $ for Cal Tracs when the car works just fine. Here's a vid of my car with a fresh 408 in the beginning of last year.It was opening day and the traction was almost non existant. http://www.youtube.com/watch?v=ZS8MPzDurYkI think my 60' that day was 1.50 I run a 9X30 slick with 4.30 gears Have fun with what you're doing!
