Re: 383 Stroker build from spare parts. [Re: StealthWedge67] #625176
03/01/10 08:18 AM
03/01/10 08:18 AM
warfordsburg, PA
dirt Offline
dirt  Offline
warfordsburg, PA
i had a 400 block and sold it.
so the 400 has a bigger bore than a 440? and would fit a little better in a A body ,that sounds like a pretty good deal! what would a shop normally charge to turn a 440 crank to use in a 400?
Re: 383 Stroker build from spare parts. [Re: forphorty] #625177
03/01/10 01:30 PM
03/01/10 01:30 PM
Tulsa oklahoma USA
2
2734bbl Offline
2734bbl  Offline
Tulsa oklahoma USA
here is a little about a cast 440 crank in a 400. I have the whole article at home in an old CP issue. http://www3.sympatico.ca/big-d/460.htm
So you used stock cast 400 pistons? What all did you have to do to make them work?
400 or 440 rod?
Could you have stroked it to 3.90 and made it a 470?
Neat-0 motor build for sure.
