Page 10 of 13 1 2 8 9 10 11 12 13
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623671
05/04/11 03:58 AM
05/04/11 03:58 AM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline OP
Other side.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623672
05/04/11 04:11 AM
05/04/11 04:11 AM
I built a dolly to roll the engine/trans/K-member under the car.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623673
05/04/11 04:12 AM
05/04/11 04:12 AM
Billet steel flywheel installation.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623674
05/04/11 04:12 AM
05/04/11 04:12 AM
Hydraulic clutch installation.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623675
05/04/11 04:13 AM
05/04/11 04:13 AM
Lowering the engine onto the K-member.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623676
05/04/11 04:15 AM
05/04/11 04:15 AM
Completed engine/trans/K-member assembly. The TTI headers seem to clear everything, no interference, but there are a few tight spots with minimal clearance.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623677
05/04/11 04:16 AM
05/04/11 04:16 AM
#2
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623678
05/04/11 04:17 AM
05/04/11 04:17 AM
The block has two cast in ears that required some grinding to clear the Mopar mini starter.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623679
05/04/11 04:17 AM
05/04/11 04:17 AM
Installation!
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623680
05/04/11 04:18 AM
05/04/11 04:18 AM
Install #2, I will post more pictures soon.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623681
05/04/11 12:10 PM
05/04/11 12:10 PM
Almont, MI.
gdemon Offline
gdemon  Offline
Almont, MI.
Looking great. I like the idea bout spacing the Alt out.
69 Barracuda 70 Cuda 70 Cuda 70 Cuda Conv. 70 T/A Challenger 70 Sport Fury GT 71 Demon 5.7 Hemi 72 Demon
Re: 70 cuda 340 - finally painted! [Re: gdemon] #623682
05/19/11 02:54 PM
05/19/11 02:54 PM
MO
cdp Offline
cdp  Offline
MO
Fantastic job on your build!
I'm curious about the K-frame. It appears stock, but did you have to modify anything for the 6.1 install...other than say motor mounts?
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623683
05/20/11 02:31 AM
05/20/11 02:31 AM
Canada
CrAzYMoPaRGuY Offline
Canada
AWESOME!!!
CrAzYMoPaRGuY
Re: 70 cuda 340 - finally painted! [Re: cdp] #623684
05/20/11 05:14 AM
05/20/11 05:14 AM
TTI sells motor mounts to install a 5.7 or 6.1 hemi onto a stock mopar V8 K-member.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623685
05/20/11 07:43 AM
05/20/11 07:43 AM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
Did you modify the transmission tunnel for the TKO 600 transmission. I know the E-body requires a section removed from the RH side of the tunnel. You might need to move the alternator so you can clear the RH frame rail. Looks great so far.
Re: 70 cuda 340 - finally painted! [Re: johnscudashop] #623686
05/21/11 03:03 AM
05/21/11 03:03 AM
Yes, I did have to modify the trans tunnel, raised it about 1" on the top, and moved it out about 3/4" on the pass side. I did not use the Keisler supplied patch, but made my own, and butt welded it in place. Looking at the tunnel it is hard to see where it has been modified. The alternator cleared OK, with about 5/8" clearance.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623687
05/21/11 03:20 AM
05/21/11 03:20 AM
Here are some more pictures. Engine installed.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623688
05/21/11 03:23 AM
05/21/11 03:23 AM
Front suspension parts: Firm feel tubular upper control arms, Firm feel sway bar, restored and reinforced lower control arms, Koni shocks (painted semi gloss black), Mopar 1" T-bars, urethane strut rod bushings, 73-74 E/A body spindles. etc.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623689
05/21/11 03:24 AM
05/21/11 03:24 AM
Front suspension assembled
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623690
05/21/11 03:25 AM
05/21/11 03:25 AM
Front brakes installed, AR engineering 13" brake kit.
