Page 9 of 13 1 2 7 8 9 10 11 12 13
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623651
03/12/11 04:00 AM
03/12/11 04:00 AM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline OP
Custom axles from Dutchman Motorsports, built to my specifications, I needed new axles anyways. Timken bearings, NOS Mopar retainers and adjuster.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623652
03/12/11 12:19 PM
03/12/11 12:19 PM
your fridge
dmaddox Offline
dmaddox  Offline
your fridge
Sweet write-up! Nothing quite like new parts in the mail.
keep up the good work!! I have never been a big fan of the rear window louvers.....reminds me of the boned out 80's IROC Z's roaming around high school parking lots with them...
Sweet color!
Re: 70 cuda 340 - finally painted! [Re: dmaddox] #623653
03/13/11 10:27 AM
03/13/11 10:27 AM
Brantford Ontario
69_SIX_PACK Offline
69_SIX_PACK  Offline
Brantford Ontario
Incredible car with such a high level of detail. Good luck with the rest of the resto!
Re: 70 cuda 340 - finally painted! [Re: 69_SIX_PACK] #623654
03/14/11 05:16 PM
03/14/11 05:16 PM
Oakley CA
69charger440_6pa Offline
Oakley CA
Took the words right out of my mouth.
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: 70 cuda 340 - finally painted! [Re: 69charger440_6pa] #623655
03/14/11 11:05 PM
03/14/11 11:05 PM
I would be scared s--tless to drive a work of art like this and to think I will be able to see this car in person.
Re: 70 cuda 340 - finally painted! [Re: ] #623656
03/17/11 02:10 AM
03/17/11 02:10 AM
Custom machined aluminum parts: Belt tensioner, fuel rails, rear disc brake brackets, ECU mounting bracket (to mount under the dash), FAST throttle body (modified for better fit/cleaner installation), misc. small parts.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623657
03/17/11 02:11 AM
03/17/11 02:11 AM
Aluminum parts after anodizing.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623658
03/17/11 11:07 AM
03/17/11 11:07 AM
Boca Raton, Florida
jpilone Offline
jpilone  Offline
Boca Raton, Florida
WOW! Just WOW!
-Jarrod Pilone
'70 Plymouth RR Convertible with amazing custom paint(Tribute/Recreation/Whateveryouwannacallit)
My Project Thread
Re: 70 cuda 340 - finally painted! [Re: jpilone] #623659
05/04/11 03:36 AM
05/04/11 03:36 AM
I have been very busy lately. I have the complete drivetrain and suspension installed! Here are some newer pitures, I will post many more soon.
This is all the rear brake parts refinished ready for final assembly. Previously, I must have put these together at least 20 times to check everything!
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623660
05/04/11 03:37 AM
05/04/11 03:37 AM
Rear calipers repainted to match the fronts.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623661
05/04/11 03:38 AM
05/04/11 03:38 AM
Axle partially assembled with the custom brackets.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623662
05/04/11 03:38 AM
05/04/11 03:38 AM
Completely assembled.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623663
05/04/11 03:39 AM
05/04/11 03:39 AM
Close-up from the back side.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623664
05/04/11 03:39 AM
05/04/11 03:39 AM
Completed axle ready to install.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623665
05/04/11 03:51 AM
05/04/11 03:51 AM
Here are some pictues of the engine with all the EFI parts installed. Back of engine with various sensors, fuel pressure regulator, etc.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623666
05/04/11 03:52 AM
05/04/11 03:52 AM
Front of engine. I did away with the complex factory accessory setup, as I won't be running AC or PS.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623667
05/04/11 03:53 AM
05/04/11 03:53 AM
Custom made belt tensioner.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623668
05/04/11 03:56 AM
05/04/11 03:56 AM
I was able to install the original old style oil pressure sending unit without any adapters. All I had to do is space the alternator out by about 0.125". I was also able to install the stock old style water temp sendning unit in the water pump housing. This way using the stock rally gages will be no problem.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623669
05/04/11 03:57 AM
05/04/11 03:57 AM
FAST cable operated throttle body. I had to modify it a bit so I can route the throttle cable under the intake manifold for a cleaner look. While apart, I also had it anodized.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623670
05/04/11 03:58 AM
05/04/11 03:58 AM
Completed engine.
