Re: 70 cuda 340 - finally painted!
[Re: Barnabas_Kriss]
#623681
05/04/11 11:10 AM
05/04/11 11:10 AM
Posts: 387 Almont, MI.
gdemon
Almont, MI.
Looking great. I like the idea bout spacing the Alt out.
69 Barracuda
70 Cuda
70 Cuda
70 Cuda Conv.
70 T/A Challenger
70 Sport Fury GT
71 Demon 5.7 Hemi
72 Demon
[Re: cdp]
#623684
05/20/11 04:14 AM
05/20/11 04:14 AM
Posts: 2,679 Maple Ridge, BC, Canada
Barnabas_Kriss
Fantastic job on your build!
I'm curious about the K-frame. It appears stock, but did you have to modify anything for the 6.1 install...other than say motor mounts?
TTI sells motor mounts to install a 5.7 or 6.1 hemi onto a stock mopar V8 K-member.
#623685
05/20/11 06:43 AM
05/20/11 06:43 AM
Posts: 1,462 Mrytle Beach SC
johnscudashop
Mrytle Beach SC
Did you modify the transmission tunnel for the TKO 600 transmission. I know the E-body requires a section removed from the RH side of the tunnel. You might need to move the alternator so you can clear the RH frame rail. Looks great so far.
[Re: johnscudashop]
#623686
05/21/11 02:03 AM
05/21/11 02:03 AM
Barnabas_Kriss
Yes, I did have to modify the trans tunnel, raised it about 1" on the top, and moved it out about 3/4" on the pass side. I did not use the Keisler supplied patch, but made my own, and butt welded it in place. Looking at the tunnel it is hard to see where it has been modified. The alternator cleared OK, with about 5/8" clearance.
#623688
05/21/11 02:23 AM
05/21/11 02:23 AM
Barnabas_Kriss
Front suspension parts: Firm feel tubular upper control arms, Firm feel sway bar, restored and reinforced lower control arms, Koni shocks (painted semi gloss black), Mopar 1" T-bars, urethane strut rod bushings, 73-74 E/A body spindles. etc.
