Page 8 of 13 1 2 6 7 8 9 10 12 13
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623631
11/21/10 04:26 AM
11/21/10 04:26 AM
tampa
gregd Offline
gregd  Offline
tampa
HEY BRO. I WANT TO INSTALL MY HEADLINER MYSELF AS WELL. 70 CUDA. I'VE GOT THE JIST. THE SAIL PNLS. HAVE ME ??? YOUR PIC SHOWS THAT YOURS ARE NOT IN YET, WHAT ARE YOUR PLANS? MY HDLNR. HAS MATERIAL, FOR THAT AREA IS THERE A HARD BACKING? I'M MISSING, OR IS IT GKUED & STRECHED? THANKS. NICE CARS YOU'VE GOT!
Re: 70 cuda 340 - finally painted! [Re: gregd] #623632
11/24/10 04:32 AM
11/24/10 04:32 AM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline OP
The sail panels are separate hard molded panels, and they are covered with the same material as the headliner. Sounds like you are missing them.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623633
12/08/10 03:14 PM
12/08/10 03:14 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Your attention to detail is an inspiration Barnabas! I ended up having a professional install my headliner and vinyl top. It's amazing to watch an expert install them while making it look so easy. No wrinkles at all. He said they will just look better once it sits out in the sun for a few hours too.
We found that the Ledgendary Interior replacement sail panels are simply too flat and once they're pushed into position, which is a curved shape, the fabric gets wrinkled and looks bad. The velcro fastening system leaves a lot to be desired too.
My molded originals have a bit of lumpiness on the face where the material glues on. I guess it's caused from moisture and slight deterioration over the years. I lightly sanded them to knock off the loose parts, and my upholsterer is glueing a very thin veneer of foam on them to smooth them out prior to glueing on the headliner material and installing them.
Overall, the Ledgendary Interiors headliner, vinyl top and seat covers look outstanding!
Re: 70 cuda 340 - finally painted! [Re: 69bronzeT5] #623634
01/19/11 04:28 PM
01/19/11 04:28 PM
midwest
68427vette Offline
68427vette  Offline
midwest
any new updates??? photos?
Re: 70 cuda 340 - finally painted! [Re: 68427vette] #623635
03/12/11 03:20 AM
03/12/11 03:20 AM
After a long delay, here are some new pictures. I have been working on the car every week, but a lot of the progress was not so visible. A lot of parts were custom machined for the engine installation, EFI, brakes, etc, small hardware and parts were cleaned and painted, and so on.
I was mainly working on the engine (tear down, and reassemble with upgraded parts) and on the rear disc brake setup (all custom built).
The firts pic is the brand new crate hemi stripped down to a bare short block, new cam and roller timing set installed and degreed.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623636
03/12/11 03:22 AM
03/12/11 03:22 AM
Engine block repainted. I didn't like the fact that the block was painted by the factory after machining. All the exposed machined surfaces were bare metal which does not look good.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623637
03/12/11 03:24 AM
03/12/11 03:24 AM
Bellhousing painted to match, all painted with a spray gun, and proper paint, no rattle cans here!
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623638
03/12/11 03:25 AM
03/12/11 03:25 AM
New parts ready for assembly.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623639
03/12/11 03:28 AM
03/12/11 03:28 AM
Heads were CNC ported for a little extra power, valve spings upgraded for new cam. These intake ports flow 350 CFM @ 600 lift, that is better than a stock 426 hemi head and better than most aftermarket BB heads! The exhausts flow 200+ CFM! This is a mild port job, nothing radical.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623640
03/12/11 03:31 AM
03/12/11 03:31 AM
Re-assembly.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623641
03/12/11 03:31 AM
03/12/11 03:31 AM
Re-assembly #2.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623642
03/12/11 03:34 AM
03/12/11 03:34 AM
I modified the heater tubes, as on the 6.1 hemi they stick straight up, this would not make for a clean looking installation. I re-oriented the tubes so they point to the pass side, this will make for a clean heater hose routing.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623643
03/12/11 03:35 AM
03/12/11 03:35 AM
Intake manifold. The runners were CNC ported, the plenum was hand ported.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623644
03/12/11 03:38 AM
03/12/11 03:38 AM
Assembled long block. Still need to add the EFI parts, alternator, motor mounts, etc. I'll be getting the parts back from the anodizing shop on Monday, then I can finish installing the accessories.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623645
03/12/11 03:40 AM
03/12/11 03:40 AM
Canada
DmanSRT71 Offline
DmanSRT71  Offline
Canada
Looking good. Nice details on the engine build. Be excruciatingly detailed on the photos of the EFI installation, please.
69 Road Runner 383/auto/N96 71 Demon 340/4 spd Would like to find a rust free Cuda body.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623646
03/12/11 03:50 AM
03/12/11 03:50 AM
On the rear brakes, my original plan was to use the 74 Imperial rear disc setup. I used this setup on another car in the past with excellent results.
However I wanted to upgrade the calipers from the ugly stock cast iron to something a little more modern... Well, after a few mock-ups one thing led to another... I ended up almost custom making the whole rear brake setup. The reason was that there was nothing in the aftermarket that met all my criteria: (1) Parking brake in rotor hat (2) Lightweight aluminum calipers (3) Retains stock adjustable wheel bearings (4) Appearance that would match the front setup which is Viper calipers on 13" rotors.
Finally this is what I came up with: Chrysler LX rotors (12.6"), SRT-8 rear calipers, custom mounting brackets, custom axles, stock 74 Imperial parking brake setup which uses small brake shoes inside the rotor hats.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623647
03/12/11 03:51 AM
03/12/11 03:51 AM
Back side view mock up. You can see the custom mounting bracket with provision for the park brake.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623648
03/12/11 03:56 AM
03/12/11 03:56 AM
Brake shields. I used the 74 Imperial pieces, but they had to be cut and re-welded, (1) for a different offset and (2) one flipped as the Imperial uses the same parts on both sides, with one caliper mounted toward the front, one mounted toward the rear. While this works fine it looks odd. I wanted both calipers mouted toward the front.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623649
03/12/11 03:58 AM
03/12/11 03:58 AM
Custom mouting bracket designed for the Brembo/SRT-8 caliper, compared to the stock Imperial bracket.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623650
03/12/11 03:58 AM
03/12/11 03:58 AM
Back side.
