Page 7 of 13 1 2 5 6 7 8 9 12 13
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623611
09/16/10 09:22 PM
09/16/10 09:22 PM
Rome, Ga
sbhpcb Offline
sbhpcb  Offline
Rome, Ga
It Looks Great! Tell Me more about the test fiting of the 5 Speed. I am working on my 71 Cuda, still in the metal stage. I have set the 5.7 hemi in the car to look, I used a 833 shell to locate the Hemi, and it looks tight. What Clutch Hydrolic? Manifolds or headers? Steering Box? I hpoe to do a budget minded swap but I will spend as needed to get a sweet ride. Please expand on details of the swap. it looks like You really have your act together.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623612
09/16/10 10:50 PM
09/16/10 10:50 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Don't know how I missed the Last month's updates. All I can say is the level of work you are doing is incredible. I thought about trying to do my windows in the same/similar manner as you have. The pics are great motivators and extremely inspiring. Keep the updates coming.
Joe
65 Barracuda
70 Challenger
Re: 70 cuda 340 - finally painted! [Re: jrwoodjoe] #623613
09/17/10 11:35 AM
09/17/10 11:35 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Great work. I'm installing the window mechanisms in my car right now. I'm nervous about the aligning process but so far the assembly is going well.
How complicated was the 1/4 glass to take apart and redo? There are rivets holding the stainless trim onto the aluminium bracket on my 73. I'm nervous about drilling out rivets around the glass too. Any tips you can give me on that would be great.
That car is looking awsome. Keep posting pics!
Re: 70 cuda 340 - finally painted! [Re: sbhpcb] #623614
09/21/10 03:33 AM
09/21/10 03:33 AM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline OP
I'm installing a Tremec TKO600 5-speed, which I bought from Keisler. I did the test fit when I was changing the floor pan. I had the tranny, bellhousing, engine, K-member all bolted in. I also bolted in the rear axle, and tried to get the driveshaft angles close to correct. The top and passenger side of the trans tunnel had to be slightly enlarged. The top needed to be raised about 3/4" and the side moved out about the same. Now I have decent clearance there. Less would have been enough, but then clearance is tighter than what I like. Keisler included a patch piece for the tunnel, which I threw out, and fabricated my own. I butt welded everything, and you wouln't even see that the tunnel has been modified. I'll be running TTI headers, TTI motor mounts, stock K-member and a manual steering box.
Re: 70 cuda 340 - finally painted! [Re: burdar] #623615
09/21/10 03:39 AM
09/21/10 03:39 AM
The 1/4 glass was not that hard to take apart. On the 70, there are small screws, not rivets. If you can get the right rivets, yours shoudn't be any more difficult. I had to take them apart to get the stainless trim polished. I found the stainless to glass sealing strip available in a local glass shop. It comes in various thicknesses, and about 2" wide. After installation, the excess is trimmed along the molding with a sharp knife.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623616
09/21/10 08:47 AM
09/21/10 08:47 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Barnabas, Looking Good!!!!
I'm worried about my door window install. Hopefully I will have my Cuda back in December. Then its time to install everything that is all layed out in pieces like your parts were.
I have the engineering diagrams. But is there any procedure you can give us or any tips in the correct sequence to install everything?
Re: 70 cuda 340 - finally painted! [Re: Finoke] #623617
11/06/10 04:46 AM
11/06/10 04:46 AM
Here is a some update again. Lately I didn't take too many pictures, but the rear glass, rear spoiler, rear window louvers and headliner are all installed. I'm still waiting for some of my instruments to be returned. The back of the car now looks almost complete. I will post more pictures soon.
I also rebuilt the manual steering box, with the fast ratio worm gear, NOS seals, bearings, etc. It turned out very nice.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623618
11/06/10 04:47 AM
11/06/10 04:47 AM
Steering box all assembled.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623619
11/06/10 04:49 AM
11/06/10 04:49 AM
Clutch type sure grip unit all rebuilt.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623620
11/06/10 10:22 AM
11/06/10 10:22 AM
midwest
68427vette Offline
68427vette  Offline
midwest
awsome build!! are you doing a modern A/C unit? i love the look, and drive train!! modern touches,, JUST AWSOME!! and the up grades can be returned to factory..sweet
the likely hood of someone offering you WAY to much money.. will be there!!! cool car!!
jc
Re: 70 cuda 340 - finally painted! [Re: 68427vette] #623621
11/06/10 12:33 PM
11/06/10 12:33 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
oj oj oj,all these nice nos parts makes me dizzy.supernice.what did you do to the outside of the steering box to make it look that good?
Re: 70 cuda 340 - finally painted! [Re: cuda-sweden] #623622
11/09/10 04:57 AM
11/09/10 04:57 AM
For the steering box, I glass beaded the outside with a fine glass bead, then rubbed it with fine steel wool. This will bring back the original as cast look.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623623
11/09/10 05:06 AM
11/09/10 05:06 AM
Here are some more pictures as promised. The differential is assemled, ready to set up the ring and pinion.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623624
11/09/10 05:07 AM
11/09/10 05:07 AM
Rear window, louvers, and spoiler installed.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623625
11/09/10 05:08 AM
11/09/10 05:08 AM
I bought some nice emblems for the hood from Modern Muscle. This will be the only give-away that it is not all stock under the hood.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623626
11/09/10 05:09 AM
11/09/10 05:09 AM
Headliner also installed. Still need a little stretching in the rear corners.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623627
11/10/10 11:14 PM
11/10/10 11:14 PM
West Coast, USA
jbc426 Online content
jbc426  Online Content
West Coast, USA
Any tips on the headliner install?
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623628
11/12/10 03:09 PM
11/12/10 03:09 PM
Chula Vista, California
Hollywood1336 Offline
Was the undercoating a one coat process, easy to apply. How thick (Approx.) is it once dry. Thanks.
Re: 70 cuda 340 - finally painted! [Re: Hollywood1336] #623629
11/14/10 10:12 AM
11/14/10 10:12 AM
B.C, Canada
69bronzeT5 Offline
69bronzeT5  Offline
B.C, Canada
Looking good Barnabas! Here are the pictures I took back in September when I came over with my Duster.
Feature Editor; Mopar Connection Magazine
'69 Charger- T5 Copper- 383 auto
'70 Coronet 500- F8 Green- 318 auto
'71 Charger R/T- B5 Blue- 440 auto
'71 Charger R/T- GY3 Citron Yella- 440 auto
'71 Charger Super Bee- GY3 Citron Yella- U-Code 440 4-spd
'79 Power Wagon- Red- 318 auto 4x4
'06 Grand Cherokee SRT8- Black- 6.1L HEMI auto
'08 Challenger SRT8- Hemi Orange- 6.1L HEMI auto
'12 Ram 3500- True Blue- 6.7L Cummins Auto 4x4
'17 Wrangler Winter Edition- Plum Crazy- 3.6L 6-Speed
Re: 70 cuda 340 - finally painted! [Re: 69bronzeT5] #623630
11/14/10 10:13 AM
11/14/10 10:13 AM
B.C, Canada
69bronzeT5 Offline
69bronzeT5  Offline
B.C, Canada
