Page 6 of 13 1 2 4 5 6 7 8 12 13
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623591
06/12/10 02:10 AM
06/12/10 02:10 AM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline OP
Right now I'm working on the rally dash. I plan to keep it looking stock, but upgrade all the gages. I bought the quartz clock conversion, and the tach kit from Real Time Engineering. Both were easy to install.
The speedometer will be sent out to conver to electric (since the Tremec tranny also has an electric speedo output). This way the speedo cable will be eliminated, the odometer will be digital built into the stock gage face.
Here is a picture of the tach kit.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623592
06/12/10 02:11 AM
06/12/10 02:11 AM
Quartz clock installed.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623593
06/12/10 11:37 PM
06/12/10 11:37 PM
Canada
CrAzYMoPaRGuY Offline
Canada
Impressive to say the least Barnabas!!!!!
I love the color, the efforts you are taking is amazing, great work!
I *might* have a troublemaking rusty Jensen at the MoPars Madness if I'm not moving.... I hope if your Cuda isn't ready I will get to see another of your vehicles...?
Keep those updates coming!
CrAzYMoPaRGuY
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623594
07/10/10 02:58 AM
07/10/10 02:58 AM
More dash pictures. I bought and installed the nice PRE-BENT woodgrain panels from Performace Car Graphics. These are really nice pieces! The wood grain is much more correct than the other ones on the market. If you're really into nit picking, there are a few tiny differeces from OEM, but overall very very nice. In fact, I'll order another set for my challenger as well. The fit is also perfect! Well worth the few extra bucks!
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623595
07/10/10 02:59 AM
07/10/10 02:59 AM
They also come with the backing plates already glued on.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623596
07/10/10 03:00 AM
07/10/10 03:00 AM
After spending hours restoring the plastic bezels, actual installation took 5 minutes.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623597
07/10/10 03:01 AM
07/10/10 03:01 AM
Switch panel disassembled. I also disassembled the actual switches to clean the internal contacts.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623598
07/10/10 03:02 AM
07/10/10 03:02 AM
All assembled.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623599
07/10/10 03:02 AM
07/10/10 03:02 AM
Close-up.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623600
08/15/10 05:09 PM
08/15/10 05:09 PM
Here is a little update again. While I was waiting for some of the dash parts to come back, I installed the side windows. It was a very tedious task, took about 50 hours to clean and rebuild all mechanisms, lightly polish the glass, install and align.
Here are the rear windows, all disassembled. Stainless moldings polished, brackets lightly glass beaded and rubbed with steel wool (for as cast look) and new seals installed.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623601
08/15/10 05:12 PM
08/15/10 05:12 PM
Side glass all assembled.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623602
08/15/10 05:19 PM
08/15/10 05:19 PM
Rear window mechanisms all cleaned. I installed NOS PW motors, which I bought very cheap, for $25.00 each!
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623603
08/15/10 05:22 PM
08/15/10 05:22 PM
Front window regulators cleaned and disassembled, with new motors.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623604
08/15/10 05:23 PM
08/15/10 05:23 PM
Front glass hardware, with new gaskets, new plastic slides.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623605
08/15/10 05:25 PM
08/15/10 05:25 PM
Finally, all windows installed and aligned!
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623606
08/15/10 05:27 PM
08/15/10 05:27 PM
Original rocker moldings refinished and installed.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623607
08/15/10 05:28 PM
08/15/10 05:28 PM
Tail light panel all dressed, rear bumper and fuel tank installed.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623608
08/15/10 05:30 PM
08/15/10 05:30 PM
Engine copartment and firewall partially dressed.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623609
08/15/10 05:48 PM
08/15/10 05:48 PM
Long Island Ny
V
varlo Offline
varlo  Offline
V
Long Island Ny
amazing work I love the color. Would you be able to tell me where you located those power windows so cheap?
Re: 70 cuda 340 - finally painted! [Re: varlo] #623610
08/15/10 06:07 PM
08/15/10 06:07 PM
I bought the PW motors off ebay 2-3 years ago. They were listed as a "Dodge Truck" PW motors. They are the same, except for the connector, which I swapped to the original.
