Page 3 of 13 1 2 3 4 5 12 13
Re: 70 cuda 340 - finally painted! [Re: jrwoodjoe] #623531
02/26/10 12:42 PM
02/26/10 12:42 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
looks awsome!
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: 70 cuda 340 - finally painted! [Re: mopars_1] #623532
02/28/10 12:23 AM
02/28/10 12:23 AM
southeast, mich
MachoMan Offline
MachoMan  Offline
southeast, mich
when can i send mine over
Please register your Dodge truck here 1972-1980 Dodge truck registry
Re: 70 cuda 340 - finally painted! [Re: MachoMan] #623533
03/20/10 03:03 AM
03/20/10 03:03 AM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline OP
Here are some more pics. Most of the parts are now refinished, ready for assembly. I had all the small parts replated as original.
These are the zinc plated parts, done by Jules.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623534
03/20/10 03:04 AM
03/20/10 03:04 AM
Black zinc and zinc dichromated parts, also done by Jules.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623535
03/20/10 03:05 AM
03/20/10 03:05 AM
Phosphate coated suspension nuts, bolts, etc.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623536
03/20/10 03:06 AM
03/20/10 03:06 AM
Galvanized metal parts.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623537
03/20/10 03:07 AM
03/20/10 03:07 AM
Powder coated suspension parts, rear end housing, etc, done by a local shop that does very nice work.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623538
03/20/10 03:10 AM
03/20/10 03:10 AM
While the car was at the paint shop, I also restored a lot of the parts, here is the refinished grille. I stripped the grille to bare plastic by glass beading using a very fine glass bead. I used the paint sold by Frank Badalson. I am very happy with the outcome. I tried to duplicate the factory overspray as well.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623539
03/20/10 03:11 AM
03/20/10 03:11 AM
Grille pic #2.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623540
03/20/10 03:12 AM
03/20/10 03:12 AM
Grille back side.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623541
03/20/10 03:13 AM
03/20/10 03:13 AM
Heater box restoration. I removed all the riveted brackets, glass beaded the case and re-finished using a satin clear coat.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623542
03/20/10 03:14 AM
03/20/10 03:14 AM
Assembled heater box.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623543
03/20/10 03:15 AM
03/20/10 03:15 AM
Heater box pic #2. I re-applied the factory stamp also.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623544
03/20/10 03:20 AM
03/20/10 03:20 AM
Steering column all disassembled, every part stripped to bare metal.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623545
03/20/10 03:21 AM
03/20/10 03:21 AM
Parts refinished, new ignition switch, turnsignal switch, key buzzer switch, ignition lock, bearings, etc.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623546
03/20/10 03:22 AM
03/20/10 03:22 AM
Assembled steering column.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623547
03/20/10 07:28 AM
03/20/10 07:28 AM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
Very very nice !!!!
Congratulations Barnabas
Jules
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623548
03/20/10 10:10 AM
03/20/10 10:10 AM
Looks awesome! How much did Ready Strip charge for the dip and coating if you don't mind me asking?
Robert.
Re: 70 cuda 340 - finally painted! [Re: ] #623549
03/21/10 06:28 PM
03/21/10 06:28 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
wow,really REALLY nice.top notch job. from sweden= 10 tumbs up.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623550
03/22/10 09:55 AM
03/22/10 09:55 AM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
This is a really good pic, just wish it was larger so I could see all your part numbers on the replacement parts.
I'll be doing the same thing to my SW Column and I have never done one before. Yours turned out really nice and I'm hoping mine will look that good when done. I have many of the parts you have in that photo but I must be missing some, Don't have that many boxes.
Looks great!
Joe
65 Barracuda
70 Challenger
