Page 11 of 13 1 2 9 10 11 12 13
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623691
05/21/11 03:29 AM
05/21/11 03:29 AM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline OP
Back to the instrument panel. Here is the mint original dash pad, I don't like any of the repros on the market, so I bought an original, right here on Moparts.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623692
05/21/11 03:37 AM
05/21/11 03:37 AM
I had a big problem getting the speedo converted to electric. First it was a long delay, then the job was not done to my standards. Finally I decided to do most of this myself, except for refinishing the gage face.
First of all, all the shops that offer this, patch up your original speedo gage face, as the odometer holes will be different in size and location. To me this is not a satisfactory solution. I did a little reserach, and found that the tachometer gage face uses the exact same stamping as the speedometer, of course minus the holes for the odometer. What I did is cut the hole for the odometer in an old tach gage face. This way I had a correct gage face that is not a patch job. Here the hole is being cut in a milling machine.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623693
05/21/11 03:38 AM
05/21/11 03:38 AM
Gage face with proper hole cut, stripped and ready to refinish.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623694
05/21/11 03:39 AM
05/21/11 03:39 AM
Speedo conversion almost done.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623695
05/21/11 03:44 AM
05/21/11 03:44 AM
Back side. I also wanted the reset knob to be in the proper place for 70-71, thru the wood grain. This required to relocate the reset switch from the speedo circuit board to an external switch. (These conversions usuall use a VDO electric speedometer as a start, which have the reset knob in the bottom of the gage face, much like the 72-74 E-body rally dash. Again, as far as I know, most shops that do this conversion leave the reset knob in the bottom of the gage face, incorrect for 70-71.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623696
05/21/11 03:46 AM
05/21/11 03:46 AM
Back of the cluster housing. A small cut is needed for the wiring connector.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623697
05/21/11 03:49 AM
05/21/11 03:49 AM
Finally, the completed instrument cluster. Looks almost stock, but has quartz clock, upgraded tach, ammeter converted to volt meter, electric speedo, upgraded instrument voltage regulator, etc. I have probably 40-50 hours into this alone.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623698
05/22/11 12:12 AM
05/22/11 12:12 AM
QLD Australia
Keith Black® Offline
QLD Australia
awesome work
Darren Beale
Keith Black Racing Engines®
Re: 70 cuda 340 - finally painted! [Re: Keith Black®] #623699
05/31/11 03:26 AM
05/31/11 03:26 AM
Here are some more pictures. This one is the main bulkhead connector being rebuilt, using an NOS fuse box, new gaskets, etc.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623700
05/31/11 03:27 AM
05/31/11 03:27 AM
Dash and instrument panel all assembled.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623701
05/31/11 03:28 AM
05/31/11 03:28 AM
Back side, everything is restored to look and work better than brand new.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623702
05/31/11 03:30 AM
05/31/11 03:30 AM
FAST XFI and XIM mounted on custom made bracket under the dash.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623703
05/31/11 03:32 AM
05/31/11 03:32 AM
Under dash wiring. This is what scares many people from going with a modern engine! Actually it is not that bad, but need a lot of patience. All the wires are now neatly hidden behind the dash.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623704
05/31/11 03:33 AM
05/31/11 03:33 AM
Dash installed. Only a few more wires left to connect.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623705
05/31/11 03:39 AM
05/31/11 03:39 AM
Here is the whole thing as it sits now. For the exterior only need to install the front and rear valances, front bumper, exhaust, grille and a few small items. The two major jobs left are the rest of the wiring, and the interior. Hopefully the engine can be fired up in about 3 more weeks, and it will be all done in about 5 weeks!
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623706
05/31/11 03:41 AM
05/31/11 03:41 AM
Rims and brakes.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623707
05/31/11 06:55 AM
05/31/11 06:55 AM
QLD Australia
QLD Australia
Wow. Awesome. Love the dash work.
I will have a similar challenge in dash wiring (may be in touch for help !!!)
Darren Beale
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623708
06/01/11 12:44 AM
06/01/11 12:44 AM
B.C, Canada
69bronzeT5 Offline
69bronzeT5  Offline
B.C, Canada
Wow!!!! Looks awesome Barnabas!!!!! You've done a lot since I was there a few weeks ago that's for sure! My offer still stands if you need help on it
Feature Editor; Mopar Connection Magazine
'69 Charger- T5 Copper- 383 auto
'70 Coronet 500- F8 Green- 318 auto
'71 Charger R/T- B5 Blue- 440 auto
'71 Charger R/T- GY3 Citron Yella- 440 auto
'71 Charger Super Bee- GY3 Citron Yella- U-Code 440 4-spd
'79 Power Wagon- Red- 318 auto 4x4
'06 Grand Cherokee SRT8- Black- 6.1L HEMI auto
'08 Challenger SRT8- Hemi Orange- 6.1L HEMI auto
'12 Ram 3500- True Blue- 6.7L Cummins Auto 4x4
'17 Wrangler Winter Edition- Plum Crazy- 3.6L 6-Speed
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623709
06/01/11 09:56 AM
06/01/11 09:56 AM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
Really looks nice you are doing great work and the results show it. Looking forward to seeing it fired up...Dennis
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: 70 cuda 340 - finally painted! [Re: 19cuda73] #623710
06/22/11 03:47 AM
06/22/11 03:47 AM
Here is a little update. Hopefully it will be fired up this weekend!!! Here is some of the engine compartment wiring in progress. Looks very messy, but all the wires are neatly wrapped and routed now.
