Post deleted by Defbob
[Re: blownzoom440]
#623346
02/27/10 11:46 AM
02/27/10 11:46 AM
#623347
02/27/10 12:05 PM
02/27/10 12:05 PM
[Re: feets]
#623350
02/28/10 01:44 AM
02/28/10 01:44 AM
Re: Turbo Big Block Header Pics
#623352
02/28/10 04:16 AM
02/28/10 04:16 AM
Posts: 180 merrill, wisconsin
voigtspeed
merrill, wisconsin
Alot of ways that work money and fabrication skills play a big part .large long tubes will heat up your engine compartment better but look more intimidating also may help delay the hit of big boost to help hook your car. 4 cylinder engines can benifit from tuned headers designed to keep the pulses even to spool big turbos. 8 cylinders dont have this problem and a simple log manifold keeps the velocity and the heat high to spool you up faster it does not take alot of boost to make you happy and get you hooked. build what your wallet can aford and move up from there. sise the turbo right and get a good wastegate and you will be in love also not a bad idea to learn the tuning lesons on a low buck engine first.
You can simply weld a flange on top of one of your manifolds run a crossover from original outlets with some type of slip joint or flex joint to deal with heat expansion. Also turbo needs a oil supply and a large oil drainback to the pan i have made a plate and used the fuel pump mounting pad for a quick down and dirty path... add turbo and wastegate and go......
Heres some fun cobbling from years ago.
ACCELERATION SPECIALIST
#623353
02/28/10 10:20 AM
02/28/10 10:20 AM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
What about exhaust flanges on the head? Cut 'em or leave 'em as one piece? Mine are 1/2" hot rolled steel and won't hold gaskets. The old headers used normal header flanges. I cut those and they wouldn't seal either. Header leaks are a way of life for me. ![](/ubbthreads/images/graemlins/frown.gif)
[Re: go green]
#623356
02/28/10 09:10 PM
02/28/10 09:10 PM
feets
Senior Management
Senior Management
Irving, TX
I was incorrect. They are cold rolled steel. I did not do a raised bead around the ports. The flanges were flat when I installed them. All of the bolt holes are over sized to prevent the studs and bolts from breaking. I do have studs wherever possible. It makes things MUCH easier to assemble. An early B engine compartment is pretty tight, especially with the later B K-frame.
I have tried a variety of normal exhaust gaskets as well as solid copper. The Cometics are next on my list.
It seems that exhaust leaks are a way of life for me.
[Re: TrxR]
#623358
02/28/10 09:29 PM
02/28/10 09:29 PM
feets
Senior Management
Senior Management
Irving, TX
A driver's side C body manifold will fit nicely on the passenger side of the engine. The exhaust outlet will be facing a bit down and towards the outside.
I don't know a good one to use for the driver's side. All of those I've ever seen had somewhat long outlets that face almost straight down. They would need to be cut off and welded into something more favorable. Welding cast iron is a pain so I'd either find someone with experience or go to something else.
[Re: moparmattkos]
#623359
03/01/10 12:56 AM
03/01/10 12:56 AM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
What do you guys think about starting with the hooker headers flange kit? 2" primary. I think they are $175 at Summit. To me it is a little expensive for what it is. But what are some of the other alternatives?
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#623362
03/01/10 05:21 PM
03/01/10 05:21 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
I guarantee they won't ![](/ubbthreads/images/graemlins/thumbs.gif)
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
#623363
03/01/10 06:13 PM
03/01/10 06:13 PM
