Re: Black radiator cools better than silver
[Re: 383'D]
#621657
02/24/10 02:44 PM
02/24/10 02:44 PM
Posts: 4,880 Virginia
BSharp
Virginia
Here's an article from the Department of Energy. Sounds like radiators should be renamed "convectors". But the real question is, what if the airplane is white and the conveyor belt is black?
[Re: Mr.Yuck]
#621659
02/24/10 03:17 PM
02/24/10 03:17 PM
Posts: 8,911 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Also consider that if black was so much better at cooling, NASCAR cars would have black radiators where even 5* would be a great benefit.
They run the grill taped up most of the time anyway so obviously cooling isn't an issue. Besides, as previously mentioned, the temp is controlled by the thermostat. It doesn't matter how much heat the rad dissipates, the thermostat will maintain its preset temp.
Everyone seems to be thinking along the lines of "running cooler". Not so. Operating temp is controlled by the thermostat. BUT, if you shut down the engine the car with the black rad would cool down faster.
[Re: Mr.Yuck]
#621661
02/24/10 04:22 PM
02/24/10 04:22 PM
Posts: 10,759 North Dakota
6PakBee
North Dakota
"Home > Library > Miscellaneous > Britannica Concise Encyclopedia
Thermal Radiation
Process by which energy is emitted by a warm surface. The energy is electromagnetic radiation and so travels at the speed of light and does not require a medium to carry it. Thermal radiation ranges in frequency from infrared rays through visible light to ultraviolet rays. The intensity and frequency distribution of the emitted rays are determined by the nature and temperature of the emitting surface; in general, the hotter the object, the shorter the wavelength. A hotter object is a better emitter than a cooler one, and a blackened surface is a better emitter than a silvered one. An example of thermal radiation is the heating of the Earth by the Sun. For more information on thermal radiation, visit Britannica.com. "
[Re: 6PakBee]
#621662
02/24/10 04:45 PM
02/24/10 04:45 PM
Posts: 329 Orange Park, FL
MRHWS
Orange Park, FL
I believe radiators were painted black to hide welded seams and metal discoloration and to match the rest of the underhood compartment.
1973 Charger SE
1974 Charger Rallye 440 Aztec
2008 Charger SRT8
[Re: 6PakBee]
#621663
02/24/10 05:34 PM
02/24/10 05:34 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Thermal Radiation
great in theory but does it apply to a cars raditor? will it be enough difference to notice? not likely.
[Re: Mr.Yuck]
#621664
02/24/10 08:43 PM
02/24/10 08:43 PM
Posts: 22,731 Bitopia
jcc
Bitopia
It was widely reported back in the day that "Grumpy" Jenkins painted his race engines white to contain heat that would then be converted to mechanical energy. I am of the paint is a better emitter, but think the question of how much insulation paint adds, is a valid one, and the comment on black lacquer is on target. An example that comes to mind is the enclosed glass bulb with a two side free spinning black sided/white sided flag. When lit by a light/heat source, the black side flag spins away from the energy source, indicating I believe it heats more, and gives up its heat faster, not sure if this is a valid example of anything, but hey this is moparts.
[Re: jcc]
#621665
02/24/10 08:54 PM
02/24/10 08:54 PM
Posts: 1,630 North Central Florida
eightlitermopar
Honest question then...not being sarcastic From what I read here, a black metal roof will actually be better in the summer for cooling my house vs a white metal roof? Is this right? (based on the argument presented for radiating heat?) eightlitermopar
Mopar or no car
[Re: eightlitermopar]
#621667
02/24/10 09:05 PM
02/24/10 09:05 PM
jcc
Bitopia
Yes and no, But only in the shade, but your example would be based on whether a black shaded roof over an attic space is hotter or cooler then the cooled living space below the attic, which really makes little sense other then for arguments sake, but its also I think why nearly every piece of decent high powered audio equipment has the heat sinks for cooling black in color
[Re: jcc]
#621668
02/24/10 11:44 PM
02/24/10 11:44 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Yeah, and a black interior will keep your car cooler on a hot sunny day too !!!
[Re: dOc …]
#621670
02/25/10 03:11 AM
02/25/10 03:11 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Come on guyz ...common sense ...
ANY paint on a rad is going to PREVENT(and insulate) the best heat transfer from the rad to the outside air.
The reasons WHY they are painted(oEM) is to prevent or retard outside corrosion.
I know it goes against common sense. BUT- Just how does a positraction rearend work in a 67 Plymouth?? It just does!!
