Anyone using the Paxton small block supercharger? #621054
02/22/10 04:45 PM
02/22/10 04:45 PM
Davis, California, USA
MrBelvedere2 Offline OP
I see there is a new forum! My main question is if anyone on here is using the paxton NOVI supercharger setup for small block mopar A bodies, here's the link for more info http://www.paxtonauto.com/product.php?id=127
I am looking into this for my 1967 barracuda, it has a 360 with J heads, headers, RPM air gap intake, 9.5:1 compression and a comp268 cam. Is that too much compression to run the setup? Just seeing who out there have taken the dive and put it on their car already and get some "real world" feedback. Thanks!
1965 Plymouth Belvedere II hardtop
Re: Anyone using the Paxton small block supercharger? [Re: MrBelvedere2] #621055
02/22/10 08:26 PM
02/22/10 08:26 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
call Craig at Paradise wheels (California). He has a big selection of old Paxtons. He can hook you up.
Coming soon!!!!
Re: Anyone using the Paxton small block supercharger? [Re: Mr.Yuck] #621056
02/23/10 12:39 AM
02/23/10 12:39 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yeah but the old Paxtons do have their drawbacks. Finicky ball drive setup, limited flow and lack of product support. Since paxton sold out the design you can't get any help from them anymore, and tech info is a trade secret that the two companies that deal with the older paxton superchargers(paradaise wheels and cundn racing) flat out told me they do not reveal tech info. They want you to send your superchargers to them so they can charge you to rebuild it. I've got a SN2000 and it took a lot of digging to get all the info/specs on the internals I wanted. The regular paxtons only flow around 850cfm, mine with the upgraded impellor is 1100 (I think) and the $$$$$ VR-4 conversion kits for the paxtons do 1500. The VR-4 kit will do 15psi or more, but the other units will not pressurize above 10psi from what I've heard. For the price you can get good deals on paxton novi series superchargers and have a unit with a modern gear drive design and capable of putting out much higher boost levels. I would not buy another paxton SN series unit.
Re: Anyone using the Paxton small block supercharger? [Re: DaytonaTurbo] #621057
02/23/10 09:04 AM
02/23/10 09:04 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
this is true, but for what he's looking for it will work. My SN had a modified impeller as aweel. and was fully capable of supporting my mild 440. And remember it's more about how much air it can push not how much boost. Boost is just the measurment of air restriction. I liked my SN, easy set-up, self contained and quiet.
Coming soon!!!!
Re: Anyone using the Paxton small block supercharger? [Re: Mr.Yuck] #621058
02/23/10 12:33 PM
02/23/10 12:33 PM
Manitoba, Canada
Manitoba, Canada
True, it will work for his combo, especially if he gets one with the upgraded impellor. But by then the price starts to creep up to Novi territory unless you get a really good deal on one.
Quiet... where's the whine, need that supercharger whine! That's the whole point right!
And to answer your question, no that's not too much compression, however at that CR you will need an alcohol injection system if you want to run it on pump 93. Or run race gas. I hear devilsown makes good, affordable alcohol injection systems.
Re: Anyone using the Paxton small block supercharger? [Re: DaytonaTurbo] #621059
02/25/10 08:46 PM
02/25/10 08:46 PM
West Central Wi.
1969 HEMI R-T Offline
West Central Wi.
I am doing one I will post some pics as soon as I can get some. 318, novi 2000, 1969 Coronet 440 4 dr.
HEMI,S ARE FOREVER!!!
Re: Anyone using the Paxton small block supercharger? [Re: 1969 HEMI R-T] #621060
02/27/10 03:35 PM
02/27/10 03:35 PM
West Central Wi.
West Central Wi.
Here is where I am at!, I am going to get a 99 ram Power steering pump, and get the belt arrangement done next, I used a 99 ram lower crank pulley W/a custom spacer. I will do the inner-cooler next winter.
Re: Anyone using the Paxton small block supercharger? [Re: 1969 HEMI R-T] #621061
02/27/10 03:35 PM
02/27/10 03:35 PM
West Central Wi.
West Central Wi.
#2
Re: Anyone using the Paxton small block supercharger? [Re: 1969 HEMI R-T] #621062
02/27/10 03:36 PM
02/27/10 03:36 PM
West Central Wi.
West Central Wi.
#3
Re: Anyone using the Paxton small block supercharger? [Re: 1969 HEMI R-T] #621063
02/27/10 03:38 PM
02/27/10 03:38 PM
West Central Wi.
West Central Wi.
I was going to build & weld on a custom bottom for the origional air cleaner, add a inlet and use it for the air intake. but to much work and would be boost limiting!
Re: Anyone using the Paxton small block supercharger? [Re: 1969 HEMI R-T] #621064
02/27/10 07:04 PM
02/27/10 07:04 PM
Manitoba, Canada
Manitoba, Canada
What I thought about doing was modding my stock air cleaner to fix the aftermarket carb bonnet underneath/inside it. So the air cleaner assy would be just for looks, but I think I would like the look of that better than an exposed carb with the air hat on it.
Are you planning on running the ram ps pump off the serpentine belt for the supercharger?
Re: Anyone using the Paxton small block supercharger? [Re: DaytonaTurbo] #621065
03/27/10 08:36 PM
03/27/10 08:36 PM
Camillus N.Y
rollerfork Offline
rollerfork  Offline
Camillus N.Y
Just about ready to try it.
Re: Anyone using the Paxton small block supercharger? [Re: Mr.Yuck] #621066
04/08/10 05:05 PM
04/08/10 05:05 PM
Tracy, CA, USA, Earth
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
What SN series do you have? I am considering adding one to the 440 in my Challenger, not sure if I can use the one I have on the shelf or if I should be looking to purchase a better one. I'm not sure if it's a SN60 or SN93, I don't have it at hand right now.
I believe the SN series all share the same bolt pattern, so regardless, upgrading later shouldn't be too difficult.
My 1970 Dodge Challenger
See my other junk here: http://waywardgarage.com
I like my cars like I like my wimmen: rough, old, fast and covered in patches of primer... loud exhaust optional as long as it doesn't smell too bad...
Re: Anyone using the Paxton small block supercharger? [Re: rabid scott] #621067
04/08/10 07:11 PM
04/08/10 07:11 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
What's the price difference between a Paxton VS Pro charger??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Anyone using the Paxton small block supercharger? [Re: rabid scott] #621068
04/09/10 12:41 AM
04/09/10 12:41 AM
Manitoba, Canada
Manitoba, Canada
Actually all the paxton SN superchargers are basically the same (SN60, SN89, SN92, SN93 and SN2000). There were some slight changes in the way the internals bolt together, but they all ran the same 4.44 internal step-up ratio and they all came stock with the same impellor. There is an upgraded impellor available for the SN series superchargers, it's an upgrade you definitely want.
Re: Anyone using the Paxton small block supercharger? [Re: rollerfork] #621069
06/02/10 09:41 AM
06/02/10 09:41 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Continue please....
Re: Anyone using the Paxton small block supercharger? [Re: rollerfork] #621070
07/04/10 11:21 AM
07/04/10 11:21 AM
Central Ky
P
Peters Offline
Peters  Offline
P
Central Ky
Yeah keep us updated, and a little info would be nice...
Re: Anyone using the Paxton small block supercharger? [Re: Peters] #621071
07/06/10 11:58 AM
07/06/10 11:58 AM
Camillus N.Y
rollerfork Offline
rollerfork  Offline
Camillus N.Y
Sorry guys have been busy.Anyway Motor is a 410 ,Took car out with the pulley that came with the kit. Would only make 2 pounds of boost. Called paxton and they said that is about all you can get with that size motor and pulley.So i orderd a 3.33 inch pulley that only made 4 pounds of boost till about 4700 rpm and would fall back to 2 pounds and hold. Took car to the track and it ran the best of 11.66 116mph going threw at 6000 rpm felt very flat. Was going to take the blower belt off and run it on the moter but it started to rain.I did run the car around a bit on the street with no blower and it feels almost as fast with out it and pulls to 6500 no problem. So i guess i ill be looking for a bigger blower. Ill post some numbers when i run it on the motor.
Re: Anyone using the Paxton small block supercharger? [Re: rollerfork] #621072
07/06/10 01:08 PM
07/06/10 01:08 PM
Manitoba, Canada
Manitoba, Canada
rollerfork, which model blower are you using?
Re: Anyone using the Paxton small block supercharger? [Re: DaytonaTurbo] #621073
07/06/10 01:37 PM
07/06/10 01:37 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
my old 440 w/ a Paxton SN2000.
