Re: Best street / strip fuel pump for 600 HP?
[Re: Jeff_383]
#620486
02/23/10 01:32 PM
02/23/10 01:32 PM
Posts: 518 ny
greenmcode
ny
I know a couple guys still use mechanical pumps in the F.A.S.T class.. My car might not have the hp that you might around 500 and I use the carter 6903.. My car runs high 11s at 115mph 3940lbs stk stroke.. I hate those noisey things..
1969 A12 R.R. 11.61 117.96 F.A.S.T. STOCK STROKE..
[Re: 300by500]
#620488
02/23/10 02:08 PM
02/23/10 02:08 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
For the power level that you are looking at, I would go with the highest flowing mechanical pump you can find. My brothers car was in going 10.70s with a high volume carter mechanical pump, we were told it wasnt enough so we got suckered into a noisey Edelbrock electric pump and the car runs the same. I installed a Holley 150 Billet fuel pump on my neighbors pump gas 511 HEMI with 1/2 fuel lines and that thing is very quiet. I would definitely run that pump if I were to buy a new one. I think it could easily flow enough fuel for 700hp. Nice pump also. I mounted it with some large rubber insulation pads and then ran the new XRP cloth braided black hose with AN fittings on both sides of the pump and I think it really keeps the noise down. My wifes car has a Magnafuel 300 and its a nice pump, but its noisey.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
[Re: 300by500]
#620490
02/23/10 09:27 PM
02/23/10 09:27 PM
Posts: 43,367 Bend,OR USA
Cab_Burge
It's time to get working on the Barracuda again, it'll probably see mostly street use with some trips to the track now and then. 4.15 crank 440, .040 over, around 498 inches. 11:1, hydraulic cam, prepped Edelbrocks, Holley 950 HP, I'm guessing it'll be in the 550-570 horsepower range. I'm looking for a pump that will handle the fuel needs of the motor, be dependable, and be quiet as possible. Any suggestions?
Any chance of you wanting to hop this combination up in the future with a power adder like NOS? If so buy and install a lot better fuel delivery system than you need for the present combination Way better to overbuy and not need it than it is to have to buy it again in another year or two. I have had issues with a Mallory 140 pump and the proper Mallory two port regulator keeping up with a stock stroke 440 with a set of inexpensive ported iron "346" heads with stock size valves ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: jamesc]
#620491
02/26/10 05:47 AM
02/26/10 05:47 AM
Posts: 793 Utah
topbrent
Utah
i wonder what Dwayne was using on his satellite. afaik he was running a stock fuel system on that and it ran pretty good. just wondering what a HV carter would do with bigger plumbing on both sides of it. losing a few HP is one thing leaning out the engine is another.
https://board.moparts.org/ubbthreads/show...rue#Post5149730
fast68plymouth however, more to the point about the OE 5/16 line......i had a roller cammed 448 with ported big valve 906's in the car from '95-'97, running high 10's/125+ in summer air.......with nothing but the OE 5/16" line and a Carter mechanical pump. best ET from that combo was 10.61, best speed was 129, best 60' time was 1.46(all from different runs).....also done with the full interior, flat steel hood, battery up front, and crank driven water pump......and 3650lb race weight.
[Re: TonyS451]
#620492
02/26/10 04:08 PM
02/26/10 04:08 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
For a good, reliable and quiet electric pump, you can't go wrong with the Mallory 140. More than enough to handle 600 horses and then some.
When I asked a few years back this is the advice I was given also. My 140 has served me well, but at least for me, it is no quieter than a Holley blue. Pretty dang noisy. Maybe it is how I have it mounted? ![](/ubbthreads/images/graemlins/shruggy.gif)
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: 300by500]
#620495
02/26/10 04:46 PM
02/26/10 04:46 PM
Posts: 4,085 Indiana
W5Duster436
Indiana
I just installed an Aeromotive 11203 pump on mine. Fairly noisy but will hopefully do okay.
'70 Duster - SDSS 436 W5 4spd (Gone) '71 Dodge D100 '70 Dodge W100
[Re: 300by500]
#620497
02/27/10 12:39 PM
02/27/10 12:39 PM
Posts: 1,880 USA
Ron Silva
USA
The carter race electric fuel pumps are BLACK and I think they are rated for 15 PSI.
SRT DEMON ONE SEAT
[Re: Ron Silva]
#620499
02/27/10 05:50 PM
02/27/10 05:50 PM
Posts: 2,886 Bowling Green KY / Nashville, ...
300by500
Sorry, I should've been more specific. I have the Carter mechanical pump that came with the car, but don't know how to tell which mechanical pump it is...
[Re: 23T Hemmee]
#620500
02/27/10 11:58 PM
02/27/10 11:58 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
Have any of you guys had any experience or knowledge with this particular mechanical pump. Saw this somewhere a while back and kept the link, just interested for simplicity sake since it was alky compatible and mounted in stock position. Just curious.
http://claysmithcams.com/moparbandhemifuelpump.aspx
I have been running their pump on my car now for 4 years with zero problems. I would highly recommend one. I'm going to E85 this year too. Jim
