Page 3 of 3 1 2 3
Re: Don't use a toggle switch for your line loc? [Re: 70HemiGTX] #619692
02/26/10 06:42 AM
02/26/10 06:42 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I guess I should clarify that I run a stick, so I have no way of holding the car at the line with out using a line lock. I assume you guys with toggle switches have a trans-brake in you car. If you look in the picture and see the red toggle switch, I have to turn that toggle switch on before I can use my line lock. If I have it in the off position I can't apply the line lock at the momentary switch on the shifter handle.
Re: Don't use a toggle switch for your line loc? [Re: ProSport] #619693
02/26/10 09:19 AM
02/26/10 09:19 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
You guys are right, it's best to try and follow every single little rule in that thick book of rules, especially if your building from scratch. But like I said, there's a Painless toggle on my dash for my line lock and it is in no way 'stupid' to have it there. I can't power out of the water box unless it's switched off.
What if someone has racing gloves on and doesn't realize they're finger is on their momentary button on their steering wheel or shifter til they hit the brakes at 130? Then are they gonna change the 'rule' to a toggle on the dash?
I just get tired of all the little rules, I still haven't removed my on/off knob on the back of the car to change it to a push/pull that they require now.
wait...the master kill switches have to be push-pull now?! I just put mine on last summer, haven't even been to a real race yet!
**Photobucket sucks**
Re: Don't use a toggle switch for your line loc? [Re: 70Cuda383] #619694
02/26/10 09:38 AM
02/26/10 09:38 AM
USA
Ron Silva Offline
Ron Silva  Offline
USA
NO.
SRT DEMON ONE SEAT
Re: Don't use a toggle switch for your line loc? [Re: Ron Silva] #619695
02/26/10 11:02 AM
02/26/10 11:02 AM
Hamilton,Ohio
P
POZEST Offline
POZEST  Offline
P
Hamilton,Ohio
Ok, time to tell on myself. Last fall at Muncie I accidentally bumped the toggle switch I use for a line lock on the starting line. This was during my 2nd time run and the first time I had ever been to this track. I could have sworn something had come apart in the steering column. It just wouldn't steer and was drifting to the left. I got stopped just short of the 330 timer about a inch from the wall. Had to climb out of the passenger side. Pulled the hood off to figure out why it wouldn't steer and it seemed ok. Jumped in the car for them to get me off the wall and figure out what to do and looked down to see the red toggle switch lit up! I was so embarrassed. Yes, I still use the toggle switch but you can see how things could have gotten real ugly.
Re: Don't use a toggle switch for your line loc? [Re: BradH] #619696
02/26/10 11:13 AM
02/26/10 11:13 AM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
Sorry to change the topic. I haven't finished the wiring for my line lock, although the actual solenoid has been integrated into my braking system since 2008. The button supplied w/ the Hurst unit I have looks pretty "budget" and won't attach to my OEM Slap-Stik shifter very easily. Any recommendations (other than a toggle switch ) for a better part to use here?
For the longest time i had my line loc hooked up to my horn relay and just used the horn pad.Keeps the hands on the steering wheel and when you release your thumb from the horn it moves forward.That was good until my horn pad died and i installed a toggle switch with a red light to show it's on.Either one works well.
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: Don't use a toggle switch for your line loc? [Re: 77DragracerR/T] #619697
02/26/10 03:05 PM
02/26/10 03:05 PM
Detroit,MI
BADDART Offline
BADDART  Offline
Detroit,MI
I have a stick car and use a toggle and momentary switch.With toggle switch up(burnout mode)the 2-step is off.With the toggle down(race)the 2-step is on for launch. Next step is to take the momentary sw. off the shifter and put it on the clutch pedal. Chris
Re: Don't use a toggle switch for your line loc? [Re: BADDART] #619698
02/26/10 07:46 PM
02/26/10 07:46 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Having the line loc on the rear brakes is more of a safety hazard than a seperate toggle switch that has to be off to move forward. And you are more likely to inadvertantly hit it if it is on a momentary switch on the shifter, right where your hand and fingers are.
Re: Don't use a toggle switch for your line loc? [Re: RemCharger] #619699
02/26/10 09:54 PM
02/26/10 09:54 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
that's kind of how I feel too. if the car won't move till you turn the lock OFF...then it'll be really hard to forget to turn it off.
that, and a LIGHTED rocker switch will also give you the red light that says "hey dummy, turn me off"
Re: Don't use a toggle switch for your line loc? [Re: Lawn Monkey] #619700
02/27/10 12:18 AM
02/27/10 12:18 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
If I recall correctly, the NHRA says the linelock can only be connected to the front brakes, not the rear.
I tried to download the NHRA rulebook but evidently you have to be a member.
Re: Don't use a toggle switch for your line loc? [Re: Dave Watt] #619701
02/27/10 12:26 AM
02/27/10 12:26 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
How in the hell can you do a burnout w/the rear brakes locked out? I would think the only reason to lock out the rears would be for leaving the line kinda like a poor mans trans brake.....am I off base here?
Re: Don't use a toggle switch for your line loc? [Re: plumridiculous] #619702
02/27/10 12:30 AM
02/27/10 12:30 AM
warfordsburg, PA
dirt Offline
dirt  Offline
warfordsburg, PA
i had a toggle switch on my cuda line lock. the E brake didnt work so i flipped the line lock on to hold the car , i was only going to let it sit for a few minutes so i could move another car that was in my way to the garage. well i got side tracked and left the cuda sit on the hill, forgot about it. when the battery died the car rolled down the hill and hit a tree. yea i know that was stupid, thats why i dont like a toggle, i'm to brain dead to remember to turn it off sometimes.
Re: Don't use a toggle switch for your line loc? [Re: Thumperdart] #619703
02/27/10 01:42 AM
02/27/10 01:42 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I've used a setup in the rear and it works good. You hit the solenoid, and hammer the brakes (activating the front) and then you have manual control coming out of the box. Then you have to turn it off.
The problem is if the solenoid is on down the track and it locks the rear.... thats the most dangerous situation.
Re: Don't use a toggle switch for your line loc? [Re: RemCharger] #619704
02/28/10 08:51 AM
02/28/10 08:51 AM
NH
torredcuda Offline
torredcuda  Offline
NH
IHRA rulebook-
All line locks must be self-returning upon the release of the switch and return the system to normal operating mode.
Page 3 of 3 1 2 3
