Re: 1968 GTX vin / engine stamping questions [Re: 6bblgt] #619386
02/21/10 03:42 AM
02/21/10 03:42 AM
Dirk Offline OP
Dirk  Offline OP
I have a call in to the possible 1st owner in Texas and he may be able to enlighten us on it's history. Stay tuned.
I am sure a few of these were blown up early in the warranty too... That would be a good case for an early replacement block.
Thank you for the compliment...Make my next project a Charger please! Nice.
Re: 1968 GTX vin / engine stamping questions [Re: Dirk] #619387
02/21/10 03:48 AM
02/21/10 03:48 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Dirk, the reason I say it's probably not a warranty engine is that the "D" stamped on the upper pad would not be there indicating the model year it was originally installed into. I am with Dan on the HP vs non HP theory, as well as the possible date correct replacement, ESPECIALLY with the lack of an "HP" on the pad after the D 440.
Re: 1968 GTX vin / engine stamping questions [Re: ScottSmith_Harms] #619388
02/21/10 04:30 AM
02/21/10 04:30 AM
Dirk Offline OP
Dirk  Offline OP
Would that then indicate someone was conscious enough to replace the original motor for whatever reason with a nice early block out of a non-performance Mopar?
Would a GTX only have an HP block?
Re: 1968 GTX vin / engine stamping questions [Re: Dirk] #619389
02/21/10 05:10 AM
02/21/10 05:10 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Yes, either on purpose or by mistake someone used a "heart-donor" early non-HP '68 car.
all '68 GTXs were 440HP (375hp) or HEMI (as were Charger R/Ts & Coronet R/Ts)
in '68 some c-bodies were available with 440 (350hp) or 440HP (375hp)
FYI, all '68 440s were painted turquoise.
Re: 1968 GTX vin / engine stamping questions [Re: 6bblgt] #619390
02/21/10 05:43 AM
02/21/10 05:43 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
What's this number stamped on the passenger side bellhousing about the fill tube?
Re: 1968 GTX vin / engine stamping questions [Re: autoxcuda] #619391
02/21/10 10:40 AM
02/21/10 10:40 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
69 & later...
