how far can a 318 be bored? #619243
02/20/10 10:45 PM
02/20/10 10:45 PM
Durham, NC
motomatt383 Offline OP
Durham, NC
i've looked around & there seems to be a real confusion as to whether or not a 318 block can be bored out to stock 340 bore specs. I'm curious if anybody has done it with any success?
matt
Re: how far can a 318 be bored? [Re: motomatt383] #619244
02/20/10 10:49 PM
02/20/10 10:49 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
there seems to be alot of 318 which are 3.91 bore being bored to 4.00 which is .090...
a 340 is 4.040..you will need another .050 for a total of .130....that is ALOT.
If you want to bore that 318 larger then say .040...you should find a machine shop that can sonic test the thickness of the cylinder walls to determine how much of an overbore you bore can take safely ...
Tony
70 AARCuda Vitamin C
Re: how far can a 318 be bored? [Re: 70AARcuda] #619245
02/20/10 10:50 PM
02/20/10 10:50 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
As mentioned, have the block sonic checked then you will know just how far of an overbore you can go...
Re: how far can a 318 be bored? [Re: OzHemi] #619246
02/20/10 11:35 PM
02/20/10 11:35 PM
Exactly & I doubt you can go from 3.91" to 4.04"
Re: how far can a 318 be bored? [Re: RapidRobert] #619247
02/21/10 12:44 AM
02/21/10 12:44 AM
dulcich Offline
dulcich  Offline
Let me correct you on this, Robert, it's been done, way back in the days before sonic testers. That said, it is probably a rare 318 block that can go that far. These days, by all means, sonic the block, and prepare to be dissappointed.
Re: how far can a 318 be bored? [Re: dulcich] #619248
02/21/10 12:54 AM
02/21/10 12:54 AM
Steve I had a feeling that me and you were going to connect over this. What exactly are you correcting me on? I didn't say that it had never been done and yes I remember from way back several reports of it being sucessfully performed. If I was him & set on that block I'd consider a 4" crank & get some cubes that way.
Re: how far can a 318 be bored? [Re: RapidRobert] #619249
02/21/10 01:15 AM
02/21/10 01:15 AM
dulcich Offline
dulcich  Offline
I was just correcting you where you said that you doubt you can go from a 3.91 bore to a 4.040 bore by saying it has been done. Good advice on the longer stroke though, it is a lot more reliable.
But, if you have some old 340 pistons and a thick 318 block both sitting under the bench...
-dulcich
Re: how far can a 318 be bored? [Re: dulcich] #619250
02/21/10 01:21 AM
02/21/10 01:21 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Now not to hijack, but can those 71-74 360 go to 4.10 since they are reported to be off the 340 casting
Re: how far can a 318 be bored? [Re: ademon] #619251
02/21/10 09:50 AM
02/21/10 09:50 AM
scratchnfotraction Offline
seen lots of the poly 318 bored 90-100+ over bore
but its the poly block that is the diff from what I understand
cant you use a sleeve in the thin 318 block to get the 340 bore?
4" crank is the ticket with a 318 IMHO anyways
Re: how far can a 318 be bored? [Re: scratchnfotraction] #619252
02/21/10 01:11 PM
02/21/10 01:11 PM
Durham, NC
Durham, NC
sorry i started this posting kinda vague. i'm researching this, and i keep hearing its been done, but I've yet to hear from someone who HAS done it. I'm putting it in my '70 D-100 pickup, the engine is a 99 Magnum motor, with a dual plane intake & i just ordered my Cam, not huge just a nice improvement over stock. i don't want to get into building a stroker. yea it'd be Kool, but.
Re: how far can a 318 be bored? [Re: motomatt383] #619253
02/21/10 02:38 PM
02/21/10 02:38 PM
MotoMatt your Q didn't sound vague at all. I think it will depend on what thickness the sonic checker shows you. I am doing a 360 stroker w the 4" crank and some 1.560" badger flat top pistons and some 50 under rod bearings and some .054" felpros' and I am going to destroke it as much as I can w these bearings ALL to reduce my positive deck height deck so I will only have to mill the pistons slightly (plus notches). A bit different but I'm working with what I have (plus on a budget) and I mainly need more torque in my daily driver 65 dart (I'm getting no respect w the stock 318 ). I'd call your shop & see what they want to sonic check it & if it'll go .130" all you need to do is take your choice of pistons in & tell them to go ahead.
Re: how far can a 318 be bored? [Re: motomatt383] #619254
02/21/10 02:51 PM
02/21/10 02:51 PM
New Zealand
solidcam Offline
solidcam  Offline
New Zealand
I have done it.Would I do it again,....no.That engine failed due to oil starvation,bearing failure.You want the walls as thick as possible on any given block and go for MINIMUM oversize.That block at 130 thou oversize I believe worked but when pushed hard put alot of heat into the walls and jacket water.
Stroker crankshafts have eliminated the need to gain displacement by boring a block not specifically engineered for that purpose.
Re: how far can a 318 be bored? [Re: solidcam] #619255
02/21/10 03:38 PM
02/21/10 03:38 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Here is an old Mopar Muscle article about Hensley Performance. They were routinely taking 318s .090" (4" bore - same as a 360) to get 402" with a 4" crank. The 318 cores went through rigorous sonic and pressure testing before being used. Sonic checking is the only way to tell as mentioned, but 4.04" would be pushing it and I would opt for more stroke rather than trying for that much overbore.
Re: how far can a 318 be bored? [Re: motomatt383] #619256
02/21/10 03:52 PM
02/21/10 03:52 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
I would even more cautious with a Magnum block.Sonic test is a must over .040.
Leave the gun.......take the Cannoli's....Mike
Re: how far can a 318 be bored? [Re: mike s] #619257
02/21/10 04:38 PM
02/21/10 04:38 PM
Durham, NC
Durham, NC
i'm kinda getting the vibe not to, i don't want to spend a fortune rebuilding it, but was hoping to do something outside the box!
Re: how far can a 318 be bored? [Re: motomatt383] #619258
02/21/10 04:56 PM
02/21/10 04:56 PM
New Zealand
solidcam Offline
solidcam  Offline
New Zealand
You don't have to spend a fortune on a teen to get performance.The main thing going against you are the pistons, usually down the hole quite far resulting in low compression.Some KB'S will sort out that problem.Next the cylinder heads, for low bucks I like the the factory J castings(for a non Magnum application) cleaned up with 2.02 or 1.92 valves with new guides,springs,retainers and some machine work(do a bowl port at the minimum),some ARP rod bolts.Find some 273 solid lifter valve gear from a junker or second hand and throw in a nice solid lift cam and you will be enjoying the teen the way it should have been assembled from the factory.
Re: how far can a 318 be bored? [Re: solidcam] #619259
02/21/10 06:05 PM
02/21/10 06:05 PM
Durham, NC
Durham, NC
I'm gonna just get a set of .030 pistons, with a zero deck height. i was hoping to get it to 340std. bore specs, mostly because its easier to say its a 340 than it a 318. but I've had a couple of 340 cars & even in there wore out condition. they would run like nobodies business!!
as far as the engine I've got, its a magnum so its got good heads & roller cam!
Re: how far can a 318 be bored? [Re: solidcam] #619260
02/21/10 06:07 PM
02/21/10 06:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Apparently, I am the only one that reads CarCraft. They have a stroked and poked 318 article in it RIGHT NOW.
4" bore 318 is not uncommon, but as said t is sonic tested first. BTW, all you recommending a sonic test, what's you minimum wall thickness recommendation?
(funny how everyone hollers sonic test, but no one says what you need, methinks Polly has been around).
Don't be the exception.
Re: how far can a 318 be bored? [Re: Supercuda] #619261
02/21/10 07:21 PM
02/21/10 07:21 PM
Re: how far can a 318 be bored? [Re: Supercuda] #619262
02/22/10 03:35 PM
02/22/10 03:35 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
There is a very good discussion about sonic testing here...
