Re: boosted cams,post yours.
[Re: BigBlockMopar]
#618487
02/27/10 12:16 AM
02/27/10 12:16 AM
Posts: 1,090 north cakalaky
instigator
north cakalaky
Bullet solid flat tappet
259/255 @ .050 .625/.620 @ 1.6 114 deg centerline
hopefully getting motor together tomorrow!
408ci Indy 360-2 230cc Twin 67mm turbos
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: 1Fast340]
#618490
03/02/10 12:35 AM
03/02/10 12:35 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
After trying ALOT of cams and turbos on the same basic engine, I came up with some very basic self tested rules: The smaller the turbine, the smaller and wider you want the cam. Pump gas likes less lsa at higher boost levels. Race gas likes more lsa (seems backward doesn't it?) A free flowing turbine/wheel combo will like a cam closer to that of a n/a engine, don't be afraid of a 260+ cam.
[Re: headhunter]
#618494
03/14/10 07:44 PM
03/14/10 07:44 PM
TRENDZ
Milwaukee WI
A cam like that would really flatten out engine performance, unless you had HUGE turbine wheel(s) and housing(s). There is to much int/ex overlap to run a normal turbine selection. On the positive side, you wouldn't hurt your engine with a cam like that. You would contaminate the intake charge with alot of exhaust gas. You wouldn't make enough power to hurt anything.
[Re: headhunter]
#618496
03/20/10 12:00 PM
03/20/10 12:00 PM
TRENDZ
Milwaukee WI
Sounds like a real nice choice to me.
[Re: goldmember]
#618498
03/22/10 02:08 PM
03/22/10 02:08 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You're the first one who's ever brought that up. All I know is that was as close as Comp could grind it without going to a custom blank. I wanted as little as possible. It's worked for several years so I guess I can't complain too much.
[Re: feets]
#618499
03/22/10 04:07 PM
03/22/10 04:07 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
and that is what comp told me about my roller i listed.i have 40* overlap at .050 and 70* total. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: blownzoom440]
#618500
03/22/10 06:19 PM
03/22/10 06:19 PM
feets
Senior Management
Senior Management
Irving, TX
Yours is a roller which does change things but it's still a lot more cam than what I've got.
[Re: blownzoom440]
#618502
03/22/10 09:32 PM
03/22/10 09:32 PM
Posts: 846 Illinois
moparmattkos
mopar addict
mopar addict
Illinois
I sent all my info to Comp to have them spec a cam for my indy head turbo big block, and this is what they sent me back. ![](/ubbthreads/images/graemlins/shruggy.gif) Part #: 23-000-9 Grind #: 4001/4121 R115+2 Duration @ .050”: 248/244 Lift w/ 1.5 Ratio: .630/.615 LSA: 115 Advance: +2
[Re: blownzoom440]
#618504
03/24/10 08:49 AM
03/24/10 08:49 AM
Posts: 833 MN
hemidup
MN
I'm thinking about a cam swap. Currently running a Paxton blower with a 216/220, 114 LSA. I have 2 other cams I could use. One a 219/224, 114 LSA and the other a 205/210, 116 LSA. Also have 4.56 gears and 3800 stall. The truck has always e.t'd better than MPH.
Jerry Williams.
