Re: any R5/P7 turbocharged motors out there?
[Re: HOTMOPR]
#2186738
10/31/16 01:47 PM
10/31/16 01:47 PM
Posts: 11,804 Portage,michigan
B3422W5
Portage,michigan
NASCAR P7 motors have huge flowing heads and are made to turn big rpm, and have thin rings. Gotta think they wouldn't be the way to go with a turbo
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car
1.41 best 60 foot 6.54 @ 105.20
[Re: scottb]
#2187022
10/31/16 08:45 PM
10/31/16 08:45 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Been running a 40 pill in my R5 aluminum block. Cylinders have not moved.
Noah Strickland sprayed a 32 pill on his 358 drowning it with fuel and way overtimed. Only damage was pistons. Head gaskets didn't leak.
[Re: Leon441]
#2187320
11/01/16 11:39 AM
11/01/16 11:39 AM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
Noah Strickland sprayed a 32 pill on his 358 drowning it with fuel and way overtimed. Only damage was pistons. Head gaskets didn't leak. Leon what have you run on the 40 pill?? That's cool!
