Re: .960 or 1.00 torsion bars, any diffrence in handeling? [Re: Roppa440] #617931
02/22/10 10:54 AM
02/22/10 10:54 AM
The actual rate you get at the wheel from a torsion bar depends on how long your lower control arm is (B/E different to A) and how wide your wheels/tires are.
Are you sure about this? I had always thought that, because the torsion bar is directly connected to the lower control arm inner pivot, the spring rate is the same as the wheel rate, regardless of the length of the LCA or the wheel offset - in contrast to any coil spring setup which necessarily has to be mounted somewhere between the control arm outer pivot and inner pivot and so only a percentage of the spring rate would act on the wheel, the actual amount depending on the length of the control arm and where on the arm the spring is attached (and in which case, the wheel offset would move the outer pivot and so affect the ratios and the percentage of the spring rate acting on the wheel).
Of course, I've been wrong before. . . .
Re: .960 or 1.00 torsion bars, any diffrence in handeling? #617932
02/23/10 09:07 AM
02/23/10 09:07 AM
N.E. England
Roppa440 Offline
super street
Roppa440  Offline
super street
N.E. England
Think of the torsion bar as a bolt you need to brake loose. You would not use that short stubby wrench if it was tight would you? You would use a long wrench to get the leverage.
The LCA is a lever that is twisting the end of the torsion bar. The longer the LCA the less the bar has to twist if you lift the wheel an inch. So the easier it is to twist the bar with the same force. Which is the same thing as lowering the spring rate of the bar.
I am not very good at explaining things so sorry if that sounds patronising or is even more confusing.
2002 Chevrolet Corvette 5.7 LS1 2011 Alpha Romeo Giulietta Veloce 1.6 JTD Because running a Mopar in the UK is getting TOO expensive!!
Re: .960 or 1.00 torsion bars, any diffrence in handeling? [Re: roadrunninMark] #617933
02/23/10 09:07 AM
02/23/10 09:07 AM
E Central IN
N
nd65 Offline
nd65  Offline
N
E Central IN
I went from the 318 bars to the 1" with a rubber suspension on my 65 Coronet. I love the 1" bars. I run a 7" front wheel and cheapo Monroe gas shocks.
They do not ride harsh or rough at all. I live on a rough country road. It is a nice improvement.
Good luck.
Re: .960 or 1.00 torsion bars, any diffrence in handeling? [Re: Roppa440] #617934
02/23/10 12:50 PM
02/23/10 12:50 PM
GA
roadrunninMark Offline
GA
Hi Roppa,
Do you think the 1" bar would be good for my setup (please pan up a few posts, roadrunninmark)?
Thanks,
Mark
Re: .960 or 1.00 torsion bars, any diffrence in handeling? [Re: roadrunninMark] #617935
02/23/10 06:09 PM
02/23/10 06:09 PM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
Thanks for all the input and refreshing my ideas on what the frontend should be and how it should be set up. From the discription, I also need to figure out what leaf springs I need for the challenger. I'l gonna put myorder in tomorrow for the torsion bars, and see what mods i can do to some stock parts to make them fit/work better.
Re: .960 or 1.00 torsion bars, any diffrence in handeling? [Re: migsBIG] #617936
02/23/10 06:46 PM
02/23/10 06:46 PM
Phoenix, Arizona
HerboldRacing Offline
Phoenix, Arizona
My wife says she can feel the difference between 0.96" and 1.00" diameter.
Marvin Herbold 1973 Plymouth Duster 340 Drag Car Blog - http://www.HerboldRacing.com Videos - http://www.YouTube.com/mherbold Pictures - http://gallery.herbold-family.com/main.php?g2_itemId=10331
Re: .960 or 1.00 torsion bars, any diffrence in handeling? [Re: HerboldRacing] #617937
02/23/10 07:35 PM
02/23/10 07:35 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Lollllllll
Good one there !!!!
Re: .960 or 1.00 torsion bars, any diffrence in handeling? [Re: HerboldRacing] #617938
02/23/10 08:57 PM
02/23/10 08:57 PM
Here
jcc Online content
jcc  Online Content
Here
Too bad you've only got a .84" bar
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
Re: .960 or 1.00 torsion bars, any diffrence in handeling? [Re: Roppa440] #617939
02/23/10 11:01 PM
02/23/10 11:01 PM
I am not very good at explaining things so sorry if that sounds patronizing or is even more confusing.
Not patronizing at all, and your explanation sounds reasonable to me. Thanks for responding.
Re: .960 or 1.00 torsion bars, any diffrence in handeling? [Re: roadrunninMark] #617940
02/24/10 09:30 AM
02/24/10 09:30 AM
N.E. England
Roppa440 Offline
super street
Roppa440  Offline
super street
N.E. England
Hi Roppa,
Thanks,
Mark
I use 1" bars on my heavy 440 Challenger in conjunction with a 1 1/8th front sway bar.
But I have also uprated the rear springs. They are custom made to my spec (about 30% uprated from 440/Hemi spec) and are used with a 3/4" rear sway bar. But the springs are moved in 5/8ths each side for tyre clearence which again alters the actual wheel rate.
If I had to drive on dirt roads I would have gone softer. But a lot of how the car feels is down to the shocks.
One friend has even thicker torsion bars on his Challenger. But it does not feel as stiff as mine. Another has stock 383 suspension on his 440 Challenger. But the adjustable shocks make it handle really well and with comfort.
I made a mistake in fitting KYB shocks (but they were all I could afford at the time) and will soon be fitting adjustable QA1 shocks. I think my ride will benefit a lot from them.
But as it stands now my Challenger corners really flat and fast. Very slight understeer when pushed very hard and oversteer on demand from controlled application of the throttle.
Re: .960 or 1.00 torsion bars, any diffrence in handeling? [Re: Roppa440] #617941
02/24/10 02:08 PM
02/24/10 02:08 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
nice to know about the QA1 shocks. It's still looking into a good leaf spring, so far that's still in the air.
Re: .960 or 1.00 torsion bars, any diffrence in handeling? [Re: migsBIG] #617942
05/18/10 09:30 PM
05/18/10 09:30 PM
Cooperstown, NY
jrlegacy23 Offline
jrlegacy23  Offline
Cooperstown, NY
Did you decide on a leaf yet? Anything installed? How does it handle
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
Re: .960 or 1.00 torsion bars, any diffrence in handeling? [Re: jrlegacy23] #617943
05/19/10 08:38 AM
05/19/10 08:38 AM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
hey guys great post. glad my wife didn't read this one. understeer and oversteer was brought up, can someone explain just what that is and the cause and effect. i think i have an idea of what it is, probably worng though. thanks
Re: .960 or 1.00 torsion bars, any diffrence in handeling? [Re: lokalik] #617944
05/19/10 11:23 AM
05/19/10 11:23 AM
central CT
cudazappa Offline
cudazappa  Offline
central CT
just a few notes from my setup with 1" t-bars
stock suspension, rebuilt, new rubber bushings (when I bought the car) and no-name shocks. Stock 318 leaf springs.
Upgraded 1" bars, 1 1/8" front sway bar, 12" rotors, SG, and 245/45 17 tires. Fiberglass hood (weight reduction)
Car handles MUCH more modern, but there are shortcomings when driven more aggressive than street. On the street its an absolute pleasure to drive. I plan on upgrading to XHD leafs soon w/ no sway bar. The rear leafs are soft. and would be very balanced at that stage. The bars are not too much for the shocks. In an agressive situation, right now, the street tires are the weak link. I'm remedying that. Further development for this car will go beyond 1" t-bars, but overall, for a street car they are great. Some taller sidewall tires (15") and even the potholes won't annoy you.
1971 Challenger
