Re: how to paint up non stock 426 hemi???
[Re: hemi-itis]
#617656
02/19/10 11:58 PM
02/19/10 11:58 PM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
I have a severe dislike for ANY shade of orange on ANY engine. I went with a different color.... a burgundy but when it's all together it can't be seen much...?? With the front end on it's even harder to see any block color...
CrAzYMoPaRGuY
[Re: Pat_Whalen]
#617659
02/20/10 12:23 PM
02/20/10 12:23 PM
Posts: 3,505 DFW
mr_340
DFW
I've had problems with the MP/VHT turquoise changing to the pukey yellow/green when antifreeze got on it. My 1969 340 was that color from the factory, but that is the last engine I'll paint with that color. How about 273 red? Put one some black valve covers and stick on some aluminum fins and try to convince everyone it's a 273 HiPo. I've been trying to get HemiFred to paint the Hemi in his S&M Duster with the Phord Blue like Jake used to paint them.
Floyd Lippencott IV
[Re: mr_340]
#617660
02/20/10 02:15 PM
02/20/10 02:15 PM
Posts: 38 Tucson Arizona
Hardy
Tucson Arizona
I like blue but a blue hemi??? this is my 440 for my 73 roadrunner
[Re: POS Dakota]
#617662
02/20/10 04:39 PM
02/20/10 04:39 PM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
While I havent done much looking into it, I am throwing around the idea of powdercoating my heads and block. Has anyone done this with iron? Is it ok to do? Looks like yours is altogether and you're probably not willing to do that. Just thought I would chuck the idea out there though.
Either way, finish-wise, I would suggest a very bright red candyish color that pops nicely when the light hits it. That way it matches the red of the ignition components you already have, still allows you to scope out any oil leaks, and will look badass.
I'm doing the red base, black and raw aluminum theme throughout on my 425 in a dakota that will be all "hotrod black" outside.
The intake, valve covers, waterpump housing, air grabber parts,,pullys, and much more is powdercoated on my motor..Take into consideration that things like bolts that will be torqued down will chip off the powdercoat easily..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
[Re: toplescuda]
#617663
02/20/10 09:03 PM
02/20/10 09:03 PM
Posts: 8,859 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
the only thing that is gonna get painted is the block and the air cleaner lid and oil pump the valve cover i will take back to the polisher and then bring them home and hit them with some hi temp clear (the valve covers are mag.i dont think i could bring my self to paint it blue so far im thinking either hemi orange or some sort of cast iron gray color or a charcoal gray??
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
