Any danger to home porting my heads?
#617087
02/18/10 04:22 PM
02/18/10 04:22 PM
Posts: 502 North Texas
1AARCUDA
North Texas
I know the obvious of port thru or to thin, but I am just going to smooth out the rough casting and any benefits to this? any advice, I have Mopar Performance Stage 5 cast iron heads.
1970 AAR CUDA
1970 Super Bee 383 Auto
1969 Super Bee 383 4Spd
1968 Satellite 500 Stroker
1986 Shelby GLHS
1970 Coronet 500 383 Auto
1996 Indy Pace Truck
1998 Dakota R/T 408 Stroker
Re: Any danger to home porting my heads?
[Re: Rodney]
#617089
02/18/10 10:52 PM
02/18/10 10:52 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
My personal experience was to try and think like a molecule of fuel or air. ![](/ubbthreads/images/graemlins/laugh2.gif) Anything that appeared to be an obstruction was removed or smoothed. Didn't get too carried away with stock removal or opening things up. Little contouring around the guide and I was happy. Apparently , so was the motor. The last one was 80 " Evo motor with a small Andrews cam and swapped to a Mikuni carb. 80 h.p. at the rear wheel.......up from 54. Before that was Ford 429 C.J. heads , where the intakes needed more restriction from where I was sitting , but the exhausts needed all the help I could give them. Unless you need maximum flow ( a job I tend to leave to the professionals ) , just smooth things out and contour the guide in the port and you will be fine IMO.
[Re: tubtar]
#617090
02/18/10 11:14 PM
02/18/10 11:14 PM
Posts: 1,051 The Great White North
RAMM
First question is: What are your goals? This NEEDS to be answered honestly by you to determine what if anything needs to be done to your heads. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: 1AARCUDA]
#617091
02/18/10 11:48 PM
02/18/10 11:48 PM
Thumperdart
State of confusion
Alumunum cuts VERY quickly w/carbide cutters so you better know how to controll it or you can jack em up quick. I`m no expert but I ported my rpm heads and removed MOST of the push rod pinch and measured remaining thickness leaving about .080 wall thickness. I slightly raised the roofs and gently blended the short turn radious then opened up the bowls while ALWAYS measuring each and every change I made then made every port the same as best that I could. LOTS of work but next time it`s cnc ported for me w/a follow up by hand if needed. What you`re talking about is like a stage 1 clean up and is worth it in my opinion as long as you keep the intake fairly rough and tha exhaust smooth. ![](/ubbthreads/images/graemlins/Twocents.gif) My bad, I see they`re cast iron....everything`s the same except for the fact that alum`s easier and faster.
[Re: Thumperdart]
#617092
02/19/10 11:26 AM
02/19/10 11:26 AM
Posts: 731 Aurora Colorado
BELVEDERE67
mopar addict
mopar addict
Aurora Colorado
I did some 516 heads from scratch. It was alot of work. I approached it in the same way you are going to do. I have to say it was "fun" but......... Wear safety glasses, Metal shavings and dust will really be flying all around. You will avoid an emergency room visit. DAMHIK When I was "done" I had the heads rebuilt. My machinist flowed 'em. He said he could get more. He found 25% more flow. That's alot. So here's my take. I know much more about how this really works which is a good thing. I also know that the work I did was much less than pro's can do. I'd leave it in the pro's hands from now on. ![](/ubbthreads/images/graemlins/2241092-prplchrgr.gif)
[Re: 1AARCUDA]
#617094
02/19/10 01:46 PM
02/19/10 01:46 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
First off, get the MP BB porting templates. Second, if you can do them outdoors, do so, makes cleanup easier. Next, if you must do them indoors, try taping a shop vac hose on or near the other end of the port and have it running, to catch the filings as you grind. There are supposedly gains to be made in grinding down the short turn of the port just past the seat, but there's a danger of breaking into the water jacket underneath the short turn. So opening up the bowls, port matching the first 1/2" of the intake port to the gasket, and narrowing the guide bosses will pick up some flow. Earplugs and glasses are a must.
[Re: 1AARCUDA]
#617095
02/19/10 04:54 PM
02/19/10 04:54 PM
BradH
... Mopar Performance Stage 5 cast iron heads.
Search on both the old and current Tech Archives here on Moparts for both OEM and Stage V head porting. There have been a couple of threads from years ago which could give you at least some idea of what you could be getting into.
Also, there are some good Mopar Muscle porting articles done by Steve Dulcich that I believe are accessible online from that magazine's web site which could also be helpful.
Do some reading before you start grinding... ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: 1AARCUDA]
#617097
02/19/10 08:03 PM
02/19/10 08:03 PM
tubtar
St. Paul , Mn.
I learned that I should also wear a mask
Yep. Black snot is only good for scaring the kids , but that novelty wears off quick. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: 1AARCUDA]
#617101
02/20/10 08:47 AM
02/20/10 08:47 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Biggest gain is in the bowls then the short turn and just cleaning up the trees that are in the production castings ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 1AARCUDA]
#617103
02/20/10 09:47 AM
02/20/10 09:47 AM
Posts: 16,932 NC
440Jim
NC
I just want to smooth the rough casting,
Smoothing the runners won't gain you anything. Gasket matching the openings is fine. Most of the benefit will come from the bowl work (and guide boss). Be very careful not to nick the valve seat, repeat that to yourself.
[Re: 1AARCUDA]
#617106
02/20/10 11:03 AM
02/20/10 11:03 AM
Posts: 7,506 Az
Crizila
Az
Suggest you start with a set of head stands. Per the pic, mine are home made, fit many different heads, and act like a spit where you can rotate the heads 360 degrees for optimum angle of attack when grinding. After you have the heads lined up on your ( working height )bench, take the port you want to work on and break it down in to quadrants. Then take one quadrant ( lets say the bowl area ) and break it down in to quadrants. Grind on one quadrant of the bowl area, then move to the same area on the next port until you have all 8 ports done in that area. The idea is to maintain repeatability accross the ports. Don't grind to the finished size each time ether. I'm not an expert, but I have had great success this way improving factory port to port air flow variations. Last set of sm block heads I did I was able to improve the port to port air flow variation by more than 8%. It's not rocket science, and it is a lot of hard, dirty work, but you can make better flowing heads. Concentrate on areas that are obvious flow restrictions or look like they will cause turbulance. There is a lot of info out there on head porting. Gather all you can on your heads before you start.
Fastest 300
