Re: Any danger to home porting my heads?
[Re: Crizila]
#617110
02/20/10 07:34 PM
02/20/10 07:34 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Very cool!
Got one of those 440 source heads ported and it worked great. Just swung rig around to get all angles from same stool position. I'll say this about 440 source THEY AINT EDELBROCKS!!!! Money spent better than on cast but they are well CHINESE!!
[Re: Dodgem]
#617111
02/21/10 12:21 AM
02/21/10 12:21 AM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
I would stick the end of a 40+ year old electrolux vacuum in the opposite end of the port I was working on to keep metal shavings out of my way!!!! dont laugh it worked! TBF
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
[Re: tubtar]
#617112
02/21/10 09:39 AM
02/21/10 09:39 AM
Posts: 846 Illinois
moparmattkos
mopar addict
mopar addict
Illinois
I learned that I should also wear a mask
Yep. Black snot is only good for scaring the kids , but that novelty wears off quick.
OMG I almost spit soda on my puter reading this !! ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: tpabayflyer]
#617113
02/21/10 11:51 AM
02/21/10 11:51 AM
Dodgem
Ontario, Canada
Yea if I ever do an old set of iron heads your shop vac trick for sure. That iron dust will kill you dead. That trick is mention in one of the links above!! I used to use a dual filter mask too!! Dam new aluminum is so nice!! little WD 40 on the rasp files and go!!!
[Re: 1AARCUDA]
#617114
02/21/10 01:01 PM
02/21/10 01:01 PM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
I agree with Mike Raff. Any head will pick up significant horse power if you sand roll the throats and work the short turn on the exhaust port with wedge heads. Just be careful you don't damage the seats.
My guess is its worth 30-50 HP over a bare casting for a couple hours of patient work.
8.30's @3400 lbs
