Re: Once again "DON'T ASK ME HOW I KNOW"
[Re: fasteddie]
#616904
02/18/10 08:49 PM
02/18/10 08:49 PM
Posts: 303 southwest Alabama
challenger73400
southwest Alabama
When tweeking your carb on a very hot day, sweat pouring off your bare arms, never lean/brace yourself on a good solid ground with one hand and reach through spark plug wires with the other. MSD makes a good product!
[Re: challenger73400]
#616905
02/18/10 08:55 PM
02/18/10 08:55 PM
Posts: 20,204 Park Forest, IL
slantzilla
Park Forest, IL
When using a Line-Loc to launch a 4 speed car, always let go of the button before the front tires come down.
[Re: Dartin]
#616908
02/18/10 09:15 PM
02/18/10 09:15 PM
Posts: 1,138 San Angelo, Texas
W8n2DustU
San Angelo, Texas
Don't get your motor fuel pressure regulator mixed up with your Nitrous fuel pressure regulator. The motor is not happy when the pressures are crossed! I heard of this happening to someone.
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
[Re: Thumperdart]
#616910
02/18/10 09:32 PM
02/18/10 09:32 PM
JCFcuda
Dont be in a big hurry to load your car on a open trailer in the morning after a heavy fall frost. Dont ask me how I know. Jim F
[Re: JCFcuda]
#616912
02/18/10 09:45 PM
02/18/10 09:45 PM
Posts: 753 San Diego, CA
brktracr
super street
super street
San Diego, CA
Never leave a diet coke on the fuel cell when filling the tank. Put the trunk lid back on and head up to staging. Pull into water box and have the starter wave you off because something is leaking out of your car in the back, by the trunk area. Especially during a big $$$$ race... that was a $100 diet coke that I didn't finish.
1.298 60 ft
6.001 1/8 mile
114 mph
9.52 1/4 mile
140.87 mph
@ 3110 lbs
[Re: drbill]
#616913
02/18/10 10:04 PM
02/18/10 10:04 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Good thread; I don't feel so alone on the "Island of Stupidity"...
So, DON'T ASK ME HOW I KNOW ABOUT these:
Hood pins in the glass hood after tech is done looking.
After 7 runs at a TnT, your buddy tells you to check the fuel level and you think you're good. Only to run out on an elevated single lane return road. Yes, there is a line forming behind you...
You get to the track late and rush through tech with your scoop plug in and in your haste to get in on the last time shots, you leave that scoop plug in.
If you have a 440-abody and try to run a "too tall" front runner and you smell rubber buring after a lap and the wheels are slighty turned...the tire WILL pop and go flat.
Make sure your new trick B&M shifter is IN PARK when you get out of your car after driving up onto an open trailer.
If you drive 75 miles to your shop where the car/trailer is, hopefully you brought the keys to the shop and trailer with you.
After you cut a .002 light in the nightime semi's, make sure you know where the black primered other car is (he broke at 1000') before you run a 11.41 on an 11.43 dial!
Don't ever clean a trans pan with parts cleaner over the garage sink...next to the hot water heater.
And finally, (I SWEAR this wasn't me, not even a race car...) make sure the pin is IN the ball mount in your reciever hitch...before you go up hill with your big trailer full of 6 dirtbikes/quads!!
[Re: cudadoug]
#616914
02/18/10 10:26 PM
02/18/10 10:26 PM
Posts: 2,379 MD
Kevins493
MD
make sure you have the car in park before you get out of it while its on the trailer. make sure the coil is not going to arc to the fuel line when its leaking yes, msd is a very good way to shock yourself! when your jr dragster motor comes apart at 9800, it sounds like you threw a bunch of bolts in a blender. detonation can trash a piston without you ever hearing it and without slowing the car down noticeably. the electrode can break off a spark plug and the cylinder can still fire. but not when cold. just because the header is cool, doesn't mean the flange is! Removing the # 6 plug on an early B with 2" headers can be painful if you forget this! when you drop something on the car it almost never hits the ground, and if it does it always rolls to the middle just out of reach. when you're in physics lab and you have 500v on wires, don't pull them out of the electron gun to make sure they're installed properly. Since it wasn't me that did this, what happened after was pretty entertaining! for ksj (i think thats his username??)..dont test fire a junior dragster anywhere near a pool.
#616916
02/18/10 10:37 PM
02/18/10 10:37 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Always pump the brakes a few times after compressing the pistons in the calipers to put in new pads. The neighbors fence is closer than it looks!
ET TU ? This is one of the funniest threads I have read anywhere , and mostly because I just about ran out of fingers counting how many of them I had personal experience with. My most recent ? When you remove the gas tank before starting any cutting / grinding projects on the rear of the car , you may think you are being safety conscious. Buy by only moving the fuel line to the other side of the car , you are ( this is by my personal grading system ) still 3/4's of an idiot. Ask me ......... go ahead. I am under the car working with a cut off wheel and all of a sudden , that harsh white fluorescent light has gained a dirty orange , flickering quality to it. My 2' diameter camp fire is being fed by still dripping 110 and I had to decide......do I look for the fire extinguisher or smother it with the moving blanket I was laying on. Being a man of action , I attacked it with the blanket. Plus , I wasn't sure exactly where the two fire extinguishers I have out there were at the time......elevating me to full fledged idiot. But I got it out and it only cost me the bottom 1/2 " of my beard. Don't try this at home , sports fans. I'm a professional.
[Re: tubtar]
#616917
02/18/10 10:50 PM
02/18/10 10:50 PM
Make sure the arbor hole on a zip disk is the right size before you start cutting with it. Ask me how I know......... five stitches on the left hand almost a cut off right ear and a souvenir still embedded in the ceiling as a reminder, oh yaaaa.
[Re: tubtar]
#616919
02/18/10 10:53 PM
02/18/10 10:53 PM
Posts: 971 Mooresville, NC
A70Runner
Mooresville, NC
If you drop a soldering iron let it hit the floor...Dont try to catch it!
Before loading your car into a trailer make sure the ball is fully engaged and locked...
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
Post deleted by Defbob
[Re: 9 Sec Phill]
#616923
02/19/10 01:21 AM
02/19/10 01:21 AM
