Re: ok anybody got a S/C'd car?
[Re: Mr.Yuck]
#616776
02/18/10 11:35 AM
02/18/10 11:35 AM
Posts: 3,336 Summit, NJ
whiplash
Summit, NJ
here's mine. Swingin, what max psi numbers were you seeing? performance?
details for mine in sig:
- 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
- 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
- NEW BEST ET - 12.40@110mph...
[Re: whiplash]
#616777
02/18/10 12:01 PM
02/18/10 12:01 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I the most I ran was about 6. The car before boost went 12.90 on a good day 13.0's on hot. I added boost and went 12.0's pretty consistantly. I think 12.26 was the worst on a real hot day...but that was due to traction. I did add a 8psi pulley but sold the car before I ran it...funny I was in the staging lane getting ready for a full pass when the guy called and bought the car. So I had to take it easy that day. Still ran 12.48 shifting at 5k on only about 4.5lbs of boost. build was a .030 over 440, cast replacement pistons (9:1 maybe), 906 heads fresh but not ported, 2.08/1.81 valves, Summit 488 cam, 13/4 headers, RPM intake ProFormed holley 750DP, Mopar 175k convert, 727, 3.91's. Car weighed 3850 w/ me and 1/2 tank of gas.
[Re: Mr.Yuck]
#616778
02/18/10 03:34 PM
02/18/10 03:34 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Not quite what you were looking for but my first S/C ride and its fun as heck. 420 to the wheels with only 10psi.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: DaytonaTurbo]
#616784
02/18/10 09:04 PM
02/18/10 09:04 PM
Mr.Yuck
Brookeville, Md
I always liked those SRT-6's, very cool little cars.
I've got a Paxton SN2000 s/c like in swingin's pic sitting in a box under my desk. Still not sure on what I'm gonna do with it, but it might just end up on my brother's 66 charger.
hey didn't I owe you a template??? I have one if needed. Although if I did it again (and will) it will go on the pass side.
[Re: Mr.Yuck]
#616790
02/19/10 12:04 AM
02/19/10 12:04 AM
DaytonaTurbo
Manitoba, Canada
Actually I designed my own bracket, it put the s/c on the passenger side and relocated the alternator lower down. Then I sent the design out to be cnc cut.
[Re: DaytonaTurbo]
#616791
02/19/10 12:37 AM
02/19/10 12:37 AM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
Here is the blown 340 in my challenger. The motor went together with the blower in 1998 and is still going strong! It was originally carb'd with X heads, but has had edelbrock heads on it since 2000 and EFI since 2001. This is a old pic, and its kinda ugly, but it only has more miles and ugly on it now. I've run it as high as 15lbs, but my final tune on it is setup for 10lbs. All I got out of the higher boost setting was more tire spin and more broken drivetrain parts. -Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
[Re: blown340]
#616792
02/19/10 12:40 AM
02/19/10 12:40 AM
blown340
Walnut Creek, CA
here's the car. it doesn't look nearly as nice in person.
Post deleted by Defbob
[Re: blown340]
#616793
02/19/10 02:14 AM
02/19/10 02:14 AM
