Re: drive train vibration.HELP
[Re: RapidRobert]
#613714
02/15/10 05:41 PM
02/15/10 05:41 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
How about the front u joint angle and the centering of the entire drivetrain viewed from above?
Check the runout of the tires AT THE TREAD with a dial indicator.
[Re: dynamite]
#613722
02/20/10 01:33 PM
02/20/10 01:33 PM
Posts: 5,270 Missouri
MY340
Missouri
Sometimes you definitely have to play with pinion and transmission angles to rid of pesky vibrations. On my 1973 Duster 340-4spd-4.10 gears I used 3 degree pinion shims in the rear and a 1/4" spacer up front to raise the tailend of the tranny. Good luck!
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
Re: drive train vibration.HELP....UPDATE !!!
[Re: MI_Custumz]
#613724
02/21/10 08:55 PM
02/21/10 08:55 PM
Posts: 1,444 NEW JERSEY
dynamite
NEW JERSEY
BOTH,parked or at 50 mph...But I'm zeroing in on the problem ...I'll keep you posted..THINK TRACTION BARS.. HERE's THE DEAL--THE TRACTION BARS I HAD ,HAVE THE SPRING PLATE AS PART OF IT..SO THE U-BOLTS BOLTED THRU THE TRACTION BAR ITS SELF..THUS TORQING THE REAR SPRINGS AND NOT LETTING THEM FLEX..I INSTALLED STOCK SPRING PLATES AND 75% OF THE VIBRATION WENT AWAY..NOW ALL I HAVE TO DO IS UNDO ALL THE SPACERS AND SHIMS AND GET EVERYTHING BACK TO WHERE THEY BELONG..DID SOME ALIGNMENT TODAY AND IMPROVED THE VIBRATION SOME MORE..GOTTA UNSPACE THE REAR TRANS MOUNT TOMORROW ...WILL KEEP YA'LL POSTED..Thanks for all the help guys..
