Re: tunes in your vintage Mopar.......what are you usin
[Re: HemiStan]
#61359
05/22/08 09:51 PM
05/22/08 09:51 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
.."breaker,breaker one-nine.. negatory on the jukebox,I am usually 10-8 on the side hunting for bears on my vintage 23 channel CB.. I got my pedal to the metal and I'm east bound hammer down..... 10-4 and all the good numbers to ya good buddy.Keep your britches between the ditches. This is 318 and I'm waving a hand back at ya! 10-4 and I'm gone!" ![](http://i51.photobucket.com/albums/f385/68Cbarge/IMG_1406.jpg)
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
Re: tunes in your vintage Mopar.......what are you using?
[Re: challenger70]
#61363
05/23/08 11:04 AM
05/23/08 11:04 AM
Posts: 2,928 Canada
RobR
Canada
I never really listen to the tunes but I put some in for my son..(I'm too busy listening for parts falling off) ![](/ubbthreads/images/graemlins/biggrin.gif)
![](http://www.mts.net/~reidfam/shifter.jpg)
What mounting points did you use for the amp you mounted on the rear sear brace? Factory holes or did you drill? I had the same idea for my Challenger but there wasn't quite enough room to get at it easily. I plan on doing that once I get to that point with the Charger though. Nice clean install.
challenger70 I think I just drilled...I think there were two holes at the top that I used but the bottom for sure had to be drilled... I'd have to go out and look to be a 100%... Thanks for the complement
[Re: RobR]
#61364
05/23/08 07:24 PM
05/23/08 07:24 PM
Posts: 902 Bellevue, WA
Blackwidow69
Ring Knocker
Ring Knocker
Bellevue, WA
I posted a couple of pictures of mine back in a thread from sept 2007. Hopefully this link will work for you. https://board.moparts.org/ubbthreads/show...art=1&vc=1.Not sure if you are looking for a hidden deal or a new type of radio in the existing radio hole. It wasn't that hard to fashion up a piece of sheet metal to use the existing radio holes and clamp the radio body to. Then the plastic face plate to cover the sheet metal plate I cut out of one side of my calipers storage box. Pattern looked pretty similar to vinyl really. Good luck with yours. Todd
1969 Ply Roadrunner, 383 4-speed on street tires.
3,830 lbs race weight.
Best 1/4: 13.1 @ 106.83
440 & overdrive 4 speed going in.
2005 Power Wagon 35X12.5 KM2's
[Re: Blackwidow69]
#61367
05/23/08 10:42 PM
05/23/08 10:42 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
this is sort of what i have in mind. thanks for the pic and link.
[Re: 63stabamatic]
#61370
05/24/08 10:25 PM
05/24/08 10:25 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Dual flowmasters make my tunes.
[Re: Supercuda]
#61371
06/02/08 11:09 PM
06/02/08 11:09 PM
70Fish
I was searching for audio threads and found this one. I just had a Kenwood CD player and 4 speakers installed in my 68 Dart. Sounds great, but after running it for a bit, there's a faint smell of something burning, I think. When you turn the power off, the smell goes away. [Edited by Moparts - Keep it clean], I'm worried something's now cooking under the dash! ![](/ubbthreads/images/graemlins/smilie_help.gif) Should my head unit with no amps can be wired directly under the dash to the ignition switch/power or should it have gone to the engine bay on the relay? Thanks!
'70 Barracuda
'94 Harley Davidson FXDWG
Pit Bull named IKE
[Re: fast68plymouth]
#61372
06/02/08 11:28 PM
06/02/08 11:28 PM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
That's odd, I'm searching for a two-shaft stereo as we speak.... I can't seem to find good ones anywhere, I take it they aren't made anymore. I guess I *could* toss a new style deck in, but I don't want to if I don't have to..... ![](http://crazymoparguy.homestead.com/jenint.jpg)
CrAzYMoPaRGuY
[Re: mkdart]
#61376
06/03/08 10:43 PM
06/03/08 10:43 PM
70Fish
Sounds are a must in my ol' Dart since she's only got a slant 6 in her to listen to!
Any recommendations on wiring the power wires under the dash vs directly to the starter relay? If going to the starter relay, is there some sort of fuse used in-line? Thanks!
'70 Barracuda
Pit Bull named IKE
[Re: 70Fish]
#61377
06/03/08 10:59 PM
06/03/08 10:59 PM
Posts: 824 NH
72challorange
He's Game
He's Game
NH
I used a Sony Head unit with Ipod cable. I have the cable in the Ash tray for the Ipod. I made the box from some scrap plywood nd some carpet from the parts store. Sounds good. I put some small speakers back in the doors since they had holes already. Added some power lock solenoids while I was in there. That is the red light in the blank guage. Tom ![](/ubbthreads/images/graemlins/thumbs.gif) ![](http://img219.imageshack.us/img219/7162/car110lj2.jpg) By tdavist, shot with DSC-P72 at 2008-06-01 ![](http://img372.imageshack.us/img372/6626/dsc01040smallqq8.jpg) By tdavist, shot with DSC-P72 at 2007-12-08 ![](http://img175.imageshack.us/img175/7213/dsc00001smallvy9.jpg) By tdavist, shot with DSC-P72 at 2008-04-10
