Re: tunes in your vintage Mopar.......what are you usin [Re: HemiStan] #61359
05/22/08 09:51 PM
05/22/08 09:51 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
.."breaker,breaker one-nine..
negatory on the jukebox,I am usually 10-8 on the side hunting for bears on my vintage 23 channel CB..
I got my pedal to the metal and I'm east bound hammer down.....
10-4 and all the good numbers to ya good buddy.Keep your britches between the ditches.
This is 318 and I'm waving a hand back at ya!
10-4 and I'm gone!"
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: tunes in your vintage Mopar.......what are you usin [Re: 68Cbarge] #61360
05/22/08 10:15 PM
05/22/08 10:15 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Looks like most of you need to learn about Ipod's...I've put all my CD's on my Ipod (Iphone actually)I've added a connector in my console that plugs into the phone & keeps the battery charged while sending music through my hidden stereo...If your radio keeps you happy great but there are places in California where the only radio stations you recieve don't speak english...I've got 70 days worth of music that I actually like on my phone & unlike a CD player once you turn it on you don't need to touch it....
Re: tunes in your vintage Mopar.......what are you usin [Re: 68Cbarge] #61361
05/23/08 08:12 AM
05/23/08 08:12 AM
N. of 8mile, S. of heaven
Spike Offline
Go Blue!!
Spike  Offline
Go Blue!!
Converted am/8 track to am/fm 8track with mp3 jack.
Sony amp in the trunk.
Re: tunes in your vintage Mopar.......what are you usin [Re: 1_WILD_RT] #61362
05/23/08 08:27 AM
05/23/08 08:27 AM
Burma Shave
plymouthfan Offline
plymouthfan  Offline
Burma Shave
I'm with you! I have nothing more than a small amp mounted under my seat which plugs into my speakers. I simply run a wire up through the back of my bench seat and use an iPod... thousands of songs at my fingertips!
One red car, one yellow car.
Re: tunes in your vintage Mopar.......what are you using? [Re: challenger70] #61363
05/23/08 11:04 AM
05/23/08 11:04 AM
Canada
RobR Offline
RobR  Offline
Canada
I never really listen to the tunes but I put some in for my son..(I'm too busy listening for parts falling off)
What mounting points did you use for the amp you mounted on the rear sear brace? Factory holes or did you drill? I had the same idea for my Challenger but there wasn't quite enough room to get at it easily. I plan on doing that once I get to that point with the Charger though. Nice clean install.
challenger70
I think I just drilled...I think there were two holes at the top that I used but the bottom for sure had to be drilled... I'd have to go out and look to be a 100%...
Thanks for the complement
Re: tunes in your vintage Mopar.......what are you using? [Re: RobR] #61364
05/23/08 07:24 PM
05/23/08 07:24 PM
Bellevue, WA
Blackwidow69 Offline
Ring Knocker
Ring Knocker
Bellevue, WA
I posted a couple of pictures of mine back in a thread from sept 2007. Hopefully this link will work for you.
https://board.moparts.org/ubbthreads/show...art=1&vc=1.
Not sure if you are looking for a hidden deal or a new type of radio in the existing radio hole. It wasn't that hard to fashion up a piece of sheet metal to use the existing radio holes and clamp the radio body to. Then the plastic face plate to cover the sheet metal plate I cut out of one side of my calipers storage box. Pattern looked pretty similar to vinyl really. Good luck with yours.
Todd
1969 Ply Roadrunner, 383 4-speed on street tires. 3,830 lbs race weight. Best 1/4: 13.1 @ 106.83 440 & overdrive 4 speed going in. 2005 Power Wagon 35X12.5 KM2's
Re: tunes in your vintage Mopar.......what are you using? [Re: RobR] #61365
05/23/08 08:52 PM
05/23/08 08:52 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
RobR,could you please post a breakdown of that system? I'm looking to do something in my FB B'cuda and I'm looking for ideas.What head unit,amp,speakers,etc? Thanks for the help.BTW nice install!!!
Re: tunes in your vintage Mopar.......what are you using? [Re: fast68plymouth] #61366
05/23/08 10:12 PM
05/23/08 10:12 PM
WV
bacaruda Offline
bacaruda  Offline
WV
Not in yet, but FM conversion to AM radio and
SIRIUS. 14-19 ch is good for classic rock but 74 blues
is nuts.
Re: tunes in your vintage Mopar.......what are you using? [Re: Blackwidow69] #61367
05/23/08 10:42 PM
05/23/08 10:42 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
this is sort of what i have in mind.
thanks for the pic and link.
Re: tunes in your vintage Mopar.......what are you using? [Re: fast68plymouth] #61368
05/24/08 06:20 AM
05/24/08 06:20 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
I have the Custom Auto Sound hidden units in two cars and share the CD player between them. The new units are MP3 compatable.
http://www.casmfg.com/
Re: tunes in your vintage Mopar.......what are you using? [Re: 63stabamatic] #61369
05/24/08 09:22 PM
05/24/08 09:22 PM
Idaho
Runner Offline
Runner  Offline
Idaho
hey dwayne, this is my junk.( ya i know the wood grain isnt correct) its a pioneer deh-3000ib with an i pod hook up in the glove box then just some pioneer 6x9's on the rear. sounds decent enough for me and i dont have much invested in it. you can buy the din stereo mounts for a 68 from yearone and others.
Re: tunes in your vintage Mopar.......what are you using? [Re: 63stabamatic] #61370
05/24/08 10:25 PM
05/24/08 10:25 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Dual flowmasters make my tunes.
Don't be the exception.
Re: tunes in your vintage Mopar.......what are you using? [Re: Supercuda] #61371
06/02/08 11:09 PM
06/02/08 11:09 PM
70Fish Offline
70Fish  Offline
I was searching for audio threads and found this one. I just had a Kenwood CD player and 4 speakers installed in my 68 Dart. Sounds great, but after running it for a bit, there's a faint smell of something burning, I think. When you turn the power off, the smell goes away. [Edited by Moparts - Keep it clean], I'm worried something's now cooking under the dash!
Should my head unit with no amps can be wired directly under the dash to the ignition switch/power or should it have gone to the engine bay on the relay? Thanks!
'70 Barracuda '94 Harley Davidson FXDWG Pit Bull named IKE
Re: tunes in your vintage Mopar.......what are you using? [Re: fast68plymouth] #61372
06/02/08 11:28 PM
06/02/08 11:28 PM
Canada
CrAzYMoPaRGuY Offline
Canada
That's odd, I'm searching for a two-shaft stereo as we speak.... I can't seem to find good ones anywhere, I take it they aren't made anymore.
I guess I *could* toss a new style deck in, but I don't want to if I don't have to.....
CrAzYMoPaRGuY
Re: tunes in your vintage Mopar.......what are you using? [Re: CrAzYMoPaRGuY] #61373
06/03/08 09:09 PM
06/03/08 09:09 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Crutchfield has one although expensive at $299. http://www.crutchfield.com/App/Product/Item/Main.aspx?search=classic+receiver&i=068RETRO1 See Attached pic.
Re: tunes in your vintage Mopar.......what are you using? [Re: Ronnman] #61374
06/03/08 09:25 PM
06/03/08 09:25 PM
Ohio
gtxmark Offline
gtxmark  Offline
Ohio
ceramic coated headers running thru 2-in exhaust,dynamax mufflers. Although I have thought about hooking up the radio.
Re: tunes in your vintage Mopar.......what are you using? [Re: fast68plymouth] #61375
06/03/08 10:08 PM
06/03/08 10:08 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
Sony unit from walmart,95bucks,6x9'on the package tray,two 3 1/2 rounds under the dash.
I don't get to worked up about it looking original. Its good enough for me.
Mike
Re: tunes in your vintage Mopar.......what are you using? [Re: mkdart] #61376
06/03/08 10:43 PM
06/03/08 10:43 PM
70Fish Offline
70Fish  Offline
Sounds are a must in my ol' Dart since she's only got a slant 6 in her to listen to!
Any recommendations on wiring the power wires under the dash vs directly to the starter relay? If going to the starter relay, is there some sort of fuse used in-line? Thanks!
Re: tunes in your vintage Mopar.......what are you using? [Re: 70Fish] #61377
06/03/08 10:59 PM
06/03/08 10:59 PM
NH
72challorange Offline
He's Game
He's Game
NH
I used a Sony Head unit with Ipod cable. I have the cable in the Ash tray for the Ipod.
I made the box from some scrap plywood nd some carpet from the parts store. Sounds good. I put some small speakers back in the doors since they had holes already. Added some power lock solenoids while I was in there. That is the red light in the blank guage.
Tom
By tdavist, shot with DSC-P72 at 2008-06-01
By tdavist, shot with DSC-P72 at 2007-12-08
By tdavist, shot with DSC-P72 at 2008-04-10
Re: tunes in your vintage Mopar.......what are you using? [Re: Ronnman] #61378
06/04/08 01:54 AM
06/04/08 01:54 AM
Canada
Canada
Ouch! Not even a built in CD player for 300 bucks... I guess what else can you do though...
CrAzYMoPaRGuY
