Re: Wiring Harnesses
[Re: NITROUSN]
#61207
05/22/08 10:41 AM
05/22/08 10:41 AM
Posts: 1,038 Howell, Mi
Shatar4
Howell, Mi
which looks nothing like the original.
Not even close.
And not even close to painless to put in!
[Re: Shatar4]
#61208
05/22/08 11:33 AM
05/22/08 11:33 AM
Posts: 10,502 Chicago, Illinois
Devil
Chicago, Illinois
Not even close.
But still not that hard! And not even close to painless to put in!
[Re: Devil]
#61209
05/22/08 05:16 PM
05/22/08 05:16 PM
Posts: 2,224 Arlington, Tx.
BJS racing
Arlington, Tx.
There is no way you can please everyone. Is it work to put one of the harnesses in? Yes it is. Is it a direct replacement? No it isn't. Does it help eliminate weak links in the factory wiring? Yes it does. Would I like to see the harnesses improved and a little more direct application? Yes I would and I am working on that. Is the harness impossible to put in? No. I have installed about 30 of our harnesses and only ever had one issue and that was with one of the first harnesses that were put out and before there was print on the wiring. I switched two wires around. Fixed it and the truck is on the road. If you would care to call me and talk about the install or have questions on our set ups you can call me at the office at (817)244-6212 ext. 1016. Depending on what you are doing with your car a factory replacement harness may be better for you to use.
Back in the swing of things at Painless again! Great to be back!
[Re: NITROUSN]
#61210
05/23/08 07:07 AM
05/23/08 07:07 AM
Quicktree
Not even close.
he didn't say he wanted a factory looking harness. he said a repalcement that has turn signals!
[Re: Shatar4]
#61211
05/23/08 07:10 AM
05/23/08 07:10 AM
Quicktree
Not even close.
not a whole lot is easy when working on these hot rods. he could always bring it down to me and I could do it for him. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: koolmerve]
#61215
05/23/08 01:45 PM
05/23/08 01:45 PM
Quicktree
Thanks alot...I just know I have bought alot of stuff without the wires and know I will have to get some...not looking for the original I understand that was a weakness in the Dodge anyway so just curious where to locate it all. Thanks! And I am in Georgia so that may be feasible!
give Jason a call and he will tell you about the different systems they carry. and if you need some help I am in north Fl ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Devil]
#61217
05/23/08 02:11 PM
05/23/08 02:11 PM
BJS racing
Arlington, Tx.
Ryan, I see you got the block off plate. Did you get the wiring for the wiper and the heater as well?
[Re: koolmerve]
#61218
05/23/08 03:48 PM
05/23/08 03:48 PM
Posts: 3,387 Toronto, ON
Shakey
Toronto, ON
As mentioned, it depends on what you are looking for with your project. Here is a photo of the M&H harness from Year One.
1969 Dodge Charger R/T SE - 440 AUTO
[Re: Shakey]
#61221
05/23/08 07:33 PM
05/23/08 07:33 PM
Shatar4
Howell, Mi
I went with the M&H as well, although I got it from RPM.
I've always been told that YO had the exclusive on the M&H harnesses.
Who is RPM?
