Wiring Harnesses #61202
05/21/08 06:21 PM
05/21/08 06:21 PM
Georgia
K
koolmerve Offline OP
K
Georgia
how hard is it to find replacement wiring harnesses for 70 chragers to include tail lights and the like?
Re: Wiring Harnesses [Re: koolmerve] #61203
05/21/08 06:25 PM
05/21/08 06:25 PM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
Year One
Amazing how an unchallenged lie can become the absolute truth.
Re: Wiring Harnesses [Re: beepbeep] #61204
05/21/08 06:28 PM
05/21/08 06:28 PM
Q
Quicktree Offline
Quicktree  Offline
Q
not hard at all pm BJS racing, Jason will fix you up with a painless system
Re: Wiring Harnesses [Re: Quicktree] #61205
05/22/08 09:33 AM
05/22/08 09:33 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
which looks nothing like the original.
Re: Wiring Harnesses [Re: 05dakota] #61206
05/22/08 09:38 AM
05/22/08 09:38 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Not even close.
Re: Wiring Harnesses [Re: NITROUSN] #61207
05/22/08 10:41 AM
05/22/08 10:41 AM
Howell, Mi
Shatar4 Offline
Shatar4  Offline
Howell, Mi
Not even close.
And not even close to painless to put in!
Re: Wiring Harnesses [Re: Shatar4] #61208
05/22/08 11:33 AM
05/22/08 11:33 AM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
Not even close.
But still not that hard!
Re: Wiring Harnesses [Re: Devil] #61209
05/22/08 05:16 PM
05/22/08 05:16 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
There is no way you can please everyone. Is it work to put one of the harnesses in? Yes it is. Is it a direct replacement? No it isn't. Does it help eliminate weak links in the factory wiring? Yes it does. Would I like to see the harnesses improved and a little more direct application? Yes I would and I am working on that. Is the harness impossible to put in? No. I have installed about 30 of our harnesses and only ever had one issue and that was with one of the first harnesses that were put out and before there was print on the wiring. I switched two wires around. Fixed it and the truck is on the road. If you would care to call me and talk about the install or have questions on our set ups you can call me at the office at (817)244-6212 ext. 1016. Depending on what you are doing with your car a factory replacement harness may be better for you to use.
Back in the swing of things at Painless again! Great to be back!
Re: Wiring Harnesses [Re: NITROUSN] #61210
05/23/08 07:07 AM
05/23/08 07:07 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Not even close.
he didn't say he wanted a factory looking harness. he said a repalcement that has turn signals!
Re: Wiring Harnesses [Re: Shatar4] #61211
05/23/08 07:10 AM
05/23/08 07:10 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Not even close.
not a whole lot is easy when working on these hot rods. he could always bring it down to me and I could do it for him.
Re: Wiring Harnesses [Re: Quicktree] #61212
05/23/08 07:12 AM
05/23/08 07:12 AM
Q
Quicktree Offline
Quicktree  Offline
Q
here's some pic's of a pro/street system. has everything you need for the street.
https://board.moparts.org/ubbthreads/show...t=4#Post4371655
Re: Wiring Harnesses [Re: koolmerve] #61213
05/23/08 12:56 PM
05/23/08 12:56 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
If you dont care about it being "correct" in appearance why not just pick up 20' of a 6 or 8 conductor wire and DIY? it sure isnt rocket science
Re: Wiring Harnesses [Re: Quicktree] #61214
05/23/08 12:56 PM
05/23/08 12:56 PM
Georgia
K
K
Georgia
Thanks alot...I just know I have bought alot of stuff without the wires and know I will have to get some...not looking for the original I understand that was a weakness in the Dodge anyway so just curious where to locate it all. Thanks! And I am in Georgia so that may be feasible!
Re: Wiring Harnesses [Re: koolmerve] #61215
05/23/08 01:45 PM
05/23/08 01:45 PM
Q
Quicktree Offline
Quicktree  Offline
Q
give Jason a call and he will tell you about the different systems they carry. and if you need some help I am in north Fl
Re: Wiring Harnesses [Re: Quicktree] #61216
05/23/08 02:02 PM
05/23/08 02:02 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
New Painless
Old...
Ryan
Re: Wiring Harnesses [Re: Devil] #61217
05/23/08 02:11 PM
05/23/08 02:11 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
Ryan, I see you got the block off plate. Did you get the wiring for the wiper and the heater as well?
Re: Wiring Harnesses [Re: koolmerve] #61218
05/23/08 03:48 PM
05/23/08 03:48 PM
Toronto, ON
Shakey Offline
Shakey  Offline
Toronto, ON
As mentioned, it depends on what you are looking for with your project.
Here is a photo of the M&H harness from Year One.
1969 Dodge Charger R/T SE - 440 AUTO
Re: Wiring Harnesses [Re: Shakey] #61219
05/23/08 05:39 PM
05/23/08 05:39 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I went with the M&H as well, although I got it from RPM.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Wiring Harnesses [Re: DPelletier] #61220
05/23/08 07:29 PM
05/23/08 07:29 PM
Toronto, ON
Shakey Offline
Shakey  Offline
Toronto, ON
I've always been told that YO had the exclusive on the M&H harnesses.
Re: Wiring Harnesses [Re: Shakey] #61221
05/23/08 07:33 PM
05/23/08 07:33 PM
Howell, Mi
Shatar4 Offline
Shatar4  Offline
Howell, Mi
Who is RPM?
