Re: Help me pick a cam!
[Re: 1Bad67Coronet]
#611439
02/12/10 01:01 PM
02/12/10 01:01 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
If you liked that one, the MP .509 is not to far off from it, and would allow you to save some $ w/ sis.
You didn't really tell us what you want out of the car. If its a street car, the .509 is a proven solid choice. If you want more power, and do some time at the strip with it, I'd consider going to the .557 solid. Going to a solid, you'd gain more than just a little more in profile. You'd have to invest in some rocker gear, but if you're getting the cam kit at cost, you might be able to do it all for just a little more than you'd spend for the comp hydraulic ???
Let us know a little more about what your goals are.
[Re: 1Bad67Coronet]
#611442
02/12/10 02:19 PM
02/12/10 02:19 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
This car will see little time at the track. I am just looking for an aggressive street build.
I just found out that the MP cam at my sisters cost is actually 5% above cost and it is not the large discount that I expected. I may just go with the same cam as it was part of the complete set: cam, springs, timing, etc. I have also considered the summit k6401 cam.
Also, I am using adjustable roller rockers.
I used the summit 488 cam in a 67 cornet. 9:1 440 w/ stock 906 heads RPM intake, headers, mopar 175k converter, 3.91's car ran great 12.90's @ 104
[Re: 1Bad67Coronet]
#611444
02/12/10 04:41 PM
02/12/10 04:41 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
street car with your stall, I'd probably look at a comp XE275HL or lunati voodoo 60304
[Re: ireland383]
#611448
02/12/10 09:30 PM
02/12/10 09:30 PM
Mr.Yuck
Brookeville, Md
FWIW range is from 2200 to 5000 .
yeah but I've used a few. it pulls to 5400 easy. 6000 w/ 6psi of boost.
[Re: Mr.Yuck]
#611449
02/14/10 01:42 AM
02/14/10 01:42 AM
Posts: 176 Rome, GA
GTXX
Rome, GA
I ran the old style (76degree overlap) 292/509 with Rhoads lifters for years in a 440 on the street with a stock Road Runner convertor. The low stall convertor kept it from blowing away the tires on the street. Big headers, 4.10 Dana, ported big valve 906's. 60' times were around 1.8 which I thought were respectable in the early 80's for a full weight 71 GTX. I still have a spare cam, if you're interested in it PM me.
'71 GTX w/Air Grabber, Super Trak Pak, Spoiler Pkg. been apart for 22 years, thinking it's time to do something about that....
[Re: patrick]
#611450
02/14/10 04:52 AM
02/14/10 04:52 AM
DaytonaTurbo
Manitoba, Canada
I run the 60303, but if I had decent compression I'd be running the 60304. But since you've already got the adjustable valve train, I would definitely be going with a solid cam. No reason not to IMO. The summit cam is okay for a budget build, however it doesn't sound aggressive at all, the car my bro bought came with the 6401 summit cam.
[Re: kymudracer]
#611455
02/15/10 10:58 PM
02/15/10 10:58 PM
Posts: 176 Rome, GA
GTXX
Rome, GA
I highly recommend the LunatiVoodoo cam. I run one in my mudracer and everyone swore it was a roller.
which VooDoo did you have? the biggest one?
