Re: Crank case evac [Re: Rodney] #609096
02/10/10 12:18 AM
02/10/10 12:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
didn't the moroso also have slice cuts out of the pipe some where on the pipe that fit inside?
I dont recall that
EDIT
Yes there is
www.summitracing.com/parts/MOR-25900/?rtype=10
Re: Crank case evac [Re: Crizila] #609097
02/10/10 12:41 AM
02/10/10 12:41 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
If I can ever get out from under the friggin snow, I wil continue with my evac testing.
This is not correct.
Re: Crank case evac [Re: Crizila] #609098
02/10/10 12:46 AM
02/10/10 12:46 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
How much does the evac help? I mean say on a 11.90 car?
I've heard all kinds of claims on this board from nothing to over 30HP and I'm sure there are a million variables as to why. My car only runs low 11.70's, so I'm not expecting much, but I don't see any negatives. If I could get get a tenth or so out of it ( for the $ I have in it )I'd be a happy camper.
Worth absolutely nothing on 3 different dyno tests that I have personally witnessed. Worth absolutely nothing on my stocker. May help keep some seals dry.
Re: Crank case evac [Re: Rodney] #609099
02/10/10 09:17 AM
02/10/10 09:17 AM
Az
Crizila Offline
Crizila  Offline
Az
Yes, those were locator cuts, so you could position the pipes corectly - per Moroso. I do plan on trying s set as Mr P Body has suggested - perpendicular to the exhaust flow verses parallel. With 11.2:1 CR, standard ring package and tight piston to wall clearance, I don't have blow-by issues with this motor, so I probably won't see much if any gain. Still think it would be a benifit to run negative pressure in the crankcase at all times though.
Fastest 300
Re: Crank case evac [Re: 68LAR] #609100
02/10/10 09:22 AM
02/10/10 09:22 AM
Az
Crizila Offline
Crizila  Offline
Az
I also use a PCV valve along with my evac system.
Why?
No, it doesn't defeat the purpose. At idle, there is a negative pressure in the crankcase due to the PCV valve. Anything above idle, there is also a negative pressure in the crankcase due to the crankcase evac. system.
Just curious - do you remember how much vacuum you pulled at idle with the PCV hooked up on a closed ( not open to atmosphere )crankcase?
Fastest 300
Re: Crank case evac [Re: Crizila] #609101
02/10/10 11:12 AM
02/10/10 11:12 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
This is dependant on the cam being used. In my case with a stick car, I pull 9" at 1200rpm(idle). One thing to remember. Any negative pressure is better than a positive pressure in the crankcase.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Crank case evac [Re: 68LAR] #609102
02/10/10 11:44 AM
02/10/10 11:44 AM
Az
Crizila Offline
Crizila  Offline
Az
10-4 that.
Fastest 300
