Re: Superformance Products gaskets
[Re: AndyF]
#608461
02/09/10 12:57 AM
02/09/10 12:57 AM
Posts: 52,972 Romeo MI
MR_P_BODY
He sent me some valve cover gasket to sample(small block)... I've only had a change to look at them, and from what I see I like the material... I dont know about the thickness as of yet since I havent put them on my engine.... he was talking(I believe) of making a version with a metal frame (like the MP version with the silicone over metal) but I'm not sure. When I get home from vacation I will put them on a engine and check out a few different valve covers that I have.... wish I had some stamped alum ones also for further testing
[Re: Triple Threat]
#608463
02/09/10 12:25 PM
02/09/10 12:25 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
where do you get these I have looked online and can't seem to find them.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: AndyF]
#608464
02/09/10 01:23 PM
02/09/10 01:23 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I will be stocking his gaskets soon, Very nice quality and he knows what he is selling.
I am placing my stock order and will have an announcement when they arrive. I believe another member on here will have them also.
Finally what I believe are some alternatives to some old design gaskets which we have all been forced to deal with. More to follow shortly.
RIP Monte Smith
[Re: MuscleMike]
#608466
02/09/10 03:18 PM
02/09/10 03:18 PM
CompWedgeEngines
Syracuse,NY
You old timer you ! You can attest to their quality as well...nice pieces.
RIP Monte Smith
[Re: MuscleMike]
#608467
02/09/10 08:46 PM
02/09/10 08:46 PM
Posts: 2,503 Illinois
CRE2004
super gas
super gas
Illinois
Been using them for a few years now.
Mike @MM
Same here. We've been using them, selling them and including them in our girdle kits for the last two or three years. Excellent product.
[Re: CRE2004]
#608468
02/09/10 09:59 PM
02/09/10 09:59 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I've seen a couple samples of Greg's gaskets and they are nice.
Not only that, He is graciously supplying the gaskets for my build
I'm not sure if he is set up to sell direct to the public but he was saying he was going to try and get out to the track more and sell there.
He did say a few of the motor builders on here had them in stock though.
[Re: MR_P_BODY]
#608469
02/10/10 07:29 PM
02/10/10 07:29 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
MR P BODY I'm glad you like the material, the thickness should be no problem @ .050" thick.
Those valve cover gaskets were not designed for stamped covers only cast or fabbed covers. Don't want you to have a potential leak
If I produce them with a steel core they will be faced on both sides with the same material and probably cost $$$ They won't be like the MP ones.
The pic below uses my valve cover gaskets WITHOUT a Steel Core and last him ALL season without a weep!
[Re: jamesc]
#608471
02/10/10 08:08 PM
02/10/10 08:08 PM
WILD BILL
BROOK PARK, OH
Greg, can you give us any info on what you currently have available and what's in the future? thanks
And finish the website
[Re: jamesc]
#608472
02/11/10 09:13 PM
02/11/10 09:13 PM
roadhazard
Akron, Ohio U.S.A.
I'd like to thank AndyF for posting some pics of my products. MR P BODY keep me posted Thanks for your kind words Competition Wedge I'd aslo like to thank Muscle Mike and CRE2004 "Mike" for their past and present use of my Superformance Products gaskets and seals. jamesc If you would like to shoot me a call I can fill you in on what I offer and recommend you to someone to purchase them from if you were so inlcined. Just click the link in my sig and there is a toll free number. All I have done is the front page for my site. Maybe Bill can do something about that Thanks again
[Re: roadhazard]
#608474
02/11/10 09:36 PM
02/11/10 09:36 PM
WILD BILL
BROOK PARK, OH
I know more about trany's then I do about web sites
[Re: greendart408]
#608475
02/11/10 09:57 PM
02/11/10 09:57 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
Anyone know if the w2 gaskets will fit indy 230cc oval port heads also?
I really like the sealant around the port to create a good pinch point with running upwards of 25-30 psi of boost through them.
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: instigator]
#608476
02/11/10 10:50 PM
02/11/10 10:50 PM
roadhazard
Akron, Ohio U.S.A.
Is there any chance that you are going to do some W5 gaskets?????
The W-2 and W-5 take the same gasket correct?
My oval port intake gaskets measure 2.085" tall x 1.450" wide if that helps.
You small block guys sure do have enough head choices out there
[Re: roadhazard]
#608477
02/11/10 11:06 PM
02/11/10 11:06 PM
instigator
north cakalaky
The 230's are 2.125 x 1.375
Looks like they would work great.
