Page 2 of 3 1 2 3
Re: Best Street Gear Ratio?? -HELP [Re: Mr.Yuck] #60650
05/21/08 11:36 AM
05/21/08 11:36 AM
Berwyn, IL
challenger70 Offline
Berwyn, IL
depends on how much highway driving you are going to do. What are the engine specs..and on and on. 3.91's are a good gear for a b-body. With a set of 275/60/15's you can cruise at 70 no problem. 3.55's are ok but they are dog gears compared to 3.91's...as are 3.23's. Try the 3.73's they are pretty new to mopars. Let us know how they run.
I have 3.91's on 28" tires and drove my car from Sanfrancisco to Chicago no problems and they have some pretty high speed limits out west. It can get a little buzzy on the highway but it isn't terrible below 70-75.
Re: Best Street Gear Ratio?? -HELP #60651
05/21/08 11:52 AM
05/21/08 11:52 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
i drove with 4.30's on the hiway with a 28" tall tire at 60-65mph.. wasn't all that bad.
Why would anyone want to drive just 60 or 65 ? Even 70 is not gonna keep up with trafic around here
Even with my 2.76 gears and lock-up trans I am turning 3000 @ 80mph.
Re: Best Street Gear Ratio?? -HELP [Re: HotRodDave] #60652
05/21/08 11:56 AM
05/21/08 11:56 AM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I have to agree. I spend as much if not more time in a 70 MPH speed limit zone than city. If you can't light the tires up maybe you need a tune up...
Re: Best Street Gear Ratio?? -HELP [Re: Dart 340] #60653
05/21/08 01:15 PM
05/21/08 01:15 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
if you plan on doing any freeway driving, I'd go 2.94's or 3.23's w/28" tires.
my car with 3.55's and 27" tires was turning 3k RPM at 70mph without the OD tranny, and it got tiring after about 30 minutes at that speed....now I cruise at ~2200 RPM at 70 with my A500...
2017 Grand Cherokee Overland
Re: Best Street Gear Ratio?? -HELP [Re: A4SixtyNineRR] #60654
05/21/08 01:45 PM
05/21/08 01:45 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Hey guys I want to get everyone's opinion on this one. I have a '69 RR that I am currently restoring and I am trying to decide what gear ratio to use in the rear end (currently a 3.23). I want to be able to use it on the street for cruising, but want to be able to light up the tires when I feel the need. The obvious choices are 3.55, 3.73, or 3.91 for the set up but I have only driven a 3.91 other than my 3.23. I am afraid a 3.91 might be too low and give me too high of rpm's with whining going down the highway. SO I am thinking that narrows it down to 3.55 or 3.73. Any opinions on which is better or is there even a noticeable difference between the two? Thanks for helping out!!
Before selecting a gear ratio..
I would ask a couple of questions..
1. Type of trans; Stick or Auto
2. If Auto, type of converter & stall speed
3. Engine build like what cam, compression
My experience with the Mopars is that the 3.23 is a great gear, more for cruisin. If the engine is built somewhat like bigger cam (low vacuum) I would step it up to a 3.55. As the engine is built up, typically the HP moves upward while dropping the lower end torque. Also What type of driving also is pertinent here, country road cruisin or stop & go..
Just my ..
Re: Best Street Gear Ratio?? -HELP [Re: patrick] #60655
05/21/08 01:46 PM
05/21/08 01:46 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Someone on this post made this calculator which is quite cool I might add. Will tell you exactly what you will get.
http://vexer.com/68rt/speed.html
Re: Best Street Gear Ratio?? -HELP [Re: Dart 340] #60656
05/21/08 02:18 PM
05/21/08 02:18 PM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
When put behind 600lbft. of torque 3:55's are NOT a dog gear.
Re: Best Street Gear Ratio?? -HELP [Re: Jeff_383] #60657
05/21/08 02:23 PM
05/21/08 02:23 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
You got that right.
Re: Best Street Gear Ratio?? -HELP [Re: Dart 340] #60658
05/21/08 04:12 PM
05/21/08 04:12 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
because lots of street drivers have 600 lb-ft of torque on tap, right!????
Re: Best Street Gear Ratio?? -HELP [Re: Jeff_383] #60659
05/21/08 04:18 PM
05/21/08 04:18 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
doubt he'll be pushing close to those numbers..and whatever 3.55's can do 3.91's can do better.
Re: Best Street Gear Ratio?? -HELP [Re: A4SixtyNineRR] #60660
05/21/08 04:26 PM
05/21/08 04:26 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
I reccommend 355 with a tire size of 25 or 26 inches...that roadrunner will accept some meaty shoes and what I would do is run a drag/street tire of 30 inches hieght and run 391 or 410.Either way you will light them and have a very nice top end
Re: Best Street Gear Ratio?? -HELP [Re: terzmo] #60661
05/21/08 04:57 PM
05/21/08 04:57 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yeah a 25-26" tire on the back of a b-body looks all wrong.
Re: Best Street Gear Ratio?? -HELP [Re: Mr.Yuck] #60662
05/21/08 05:24 PM
05/21/08 05:24 PM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
My "street driver" has 600 ftlbs.
Re: Best Street Gear Ratio?? -HELP [Re: HotRodDave] #60663
05/21/08 08:27 PM
05/21/08 08:27 PM
cause i'm not in a hurry to go anywhere.
if i really, really have to go on a superspeed
long trip.. 20mins and the 2.76's are in.
Re: Best Street Gear Ratio?? -HELP [Re: Jeff_383] #60664
05/21/08 08:29 PM
05/21/08 08:29 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
do you have 3.55's and an auto?
Re: Best Street Gear Ratio?? -HELP [Re: Mr.Yuck] #60665
05/21/08 08:51 PM
05/21/08 08:51 PM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
YES
Sorry caps lock was on, yes
Re: Best Street Gear Ratio?? -HELP [Re: Jeff_383] #60666
05/21/08 09:44 PM
05/21/08 09:44 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
My friends car has 800 horsepower and one of those 318 HEMI six-pack super commandoes.
Re: Best Street Gear Ratio?? -HELP #60667
05/21/08 10:19 PM
05/21/08 10:19 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Kinda defeats the purpose if you have to change every time you want to go on a longer highway trip tho. I know some guys do the swap quick but I'm not that good.
I've got 3.55's with a 27" tire and it's okay, but still revving high for me at 60mph. Doesn't really matter that much for me because I don't take my car out on the highway much anyway. 3.55's are a compromise gear. They'll cruise on the highway and they'll race down the strip, but they won't do either one that well. However I still think they're a better middle ground than 3.23's. But if you've got 3.23's already, is it worth the $ to change to 3.55's? IMO, no. Play with the speed/rpm calculator linked to a few posts up and get a feel for what you can handle. I think 3.73's would give me a little more punch and not give up much on the highway, but again, not worth the $ for that little of a change.
Re: Best Street Gear Ratio?? -HELP [Re: DaytonaTurbo] #60668
05/21/08 10:23 PM
05/21/08 10:23 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
3.23 here w/ a 26" tall tire
16 mpg @75 mpg turning 3400 rpm AND 12.56 @106 in the quarter...
best of both worlds for me!
Re: Best Street Gear Ratio?? -HELP [Re: terzmo] #60669
05/21/08 10:29 PM
05/21/08 10:29 PM
Upper Midwest
Black_Sheep Offline
Black_Sheep  Offline
Upper Midwest
There's about 3 rpms difference at 70 mph when comparing 26" tires with 3.55's and 30" tires with 4.10's (this happens to be the combo on the GTX) Here's a decent online calculator which makes it easy to compare options...
http://golenengineservice.com/calc/calcrpm.htm
'69 Plymouth GTX
See you on the street...
Page 2 of 3 1 2 3
