Page 3 of 4 1 2 3 4
Re: how much hp will 3/8 fuel line handle? [Re: @#$%&*!] #605000
02/06/10 03:45 PM
02/06/10 03:45 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Ok, lets do some math...
Gasoline is .0267lbs/in^3
So lets say we have 100" of fuel line.
Take the 3/8" diameter
So 3.1415 x .375"^2 x 100"x .0267lbs/in^3= 1.17 lbs mass
So at 1g of acceleration, 1.17lbs, is applied to the 3/8" fuel line area.
1.17lbs x .375"^2 x 3.1415=.5psi of pressure towards the rear of the vehicle.
Looking at the 1/2" fuel line calc...
So 3.1415 x .5"^2 x 100"x .0267lbs/in^3= 2.1 lbs mass
2.1lbs x .5^2 x 3.1415 = 1.65psi in the rear direction.
These rear direction forces cancel out the head pressure in the forward direction normally there.
1.65psi is a pretty good sized increase over .51psi
If the pump motor can barely meet the 6~7lbs of fuel pressure requirment, the 1/2" line PSI force during a 1g launch is a pretty significant jump..
It just depends on the pump then I guess. If the pump is marginal, or can't make much pressure over 6~7psi normally needed. The line diameter could be a factor.
Thoughts?...
Re: how much hp will 3/8 fuel line handle? [Re: dizuster] #605001
02/06/10 04:01 PM
02/06/10 04:01 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
3/8 "is the outside diameter. The inside is @1/4"
Re: how much hp will 3/8 fuel line handle? [Re: VanishPt] #605002
02/06/10 04:07 PM
02/06/10 04:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
the inside is 5/16" on a 3/8" steel line
Re: how much hp will 3/8 fuel line handle? [Re: IcorkSOAK] #605003
02/06/10 04:13 PM
02/06/10 04:13 PM
Denmark
Dart of Denmark Offline
Denmark
The larger the hose diameter the less friction loss given the same hose length and discharge pressure.
Sometimes it does
B U T ....a fire-hose is that traveling from a dead-stop to 60 mph in 2 seconds or so !
Re: how much hp will 3/8 fuel line handle? [Re: dizuster] #605004
02/06/10 05:22 PM
02/06/10 05:22 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
1. Area = pi*D^2/4, your volume calculations are 4X too big. 2. You're using solid mechanics math on a fluid mechanics problem.
There are two separate issues and some are confusing them. One is the acceleration of a fluid and I've explained that one previously, the size of the line isn't an issue. The other is the pressure loss from fluid flow through the lines and fittings. This is the area people should focus on. First find your actual max. flow rate and then calculate the velocity in the line and determine if you need a bigger line. See this page: http://en.wikipedia.org/wiki/Reynolds_number
Re: how much hp will 3/8 fuel line handle? [Re: @#$%&*!] #605005
02/06/10 06:21 PM
02/06/10 06:21 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
11.00s 10.90s 3/8 line here. 3600lbs car We been though this..lots of times here on the board.
Re: how much hp will 3/8 fuel line handle? [Re: IcorkSOAK] #605006
02/06/10 07:04 PM
02/06/10 07:04 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
I guess you're missing the point Doc ? You're a Doctor of What ? Fiberglass ?
Fact is, the larger the diameter the less the friction loss is. A 1.5in line loses 25psi pressure per 100ft. A 2.5in line loses 14psi. A 4in line loses 4 psi....and so on.
A 5/16 line will have more friction loss than a 3/8in line....all things being equal. The velocity of the fluid has little to do with it....surface contact has everything to do with it. The larger the percentage of surface contact vs the total volume of fluid....the greater the friction loss.
All this is academic anyway....i agree that a 3/8-1/2 line is plenty for just about any application
Ron
Re: how much hp will 3/8 fuel line handle? [Re: firefighter3931] #605007
02/06/10 07:44 PM
02/06/10 07:44 PM
Az
Crizila Offline
Crizila  Offline
Az
All this is academic anyway....i agree that a 3/8-1/2 line is plenty for just about any application :thumbRon
:"Academic anyway" is correct. It's all about how much comes out at the end of the hose that connects to your carb. Lot of good info on this thread though - a lot to consider and different ways to look at it. IMO, if you are not pushing the envelope with your build, you can get away with just about anything - but if you are, I would prefer a little overkill in the fuel delivery dept, just to protect the rest of my investment. I've used the "gas can" measurement approach and although it might be a little crude, it pretty much by-passes most of what has been discussed here. You ether got the juz, or you don't got the juz.
Fastest 300
Re: how much hp will 3/8 fuel line handle? [Re: DaveDudek] #605008
02/06/10 09:36 PM
02/06/10 09:36 PM
Emmett, Idaho
SuperStockWagon Offline
Emmett, Idaho
I have one stock 5/16 fuel line feeding both carbs. [Email]10.35@134.4[/Email] and 770HP on the dyno..
Thats all I need know! Thanks Dave!
Re: how much hp will 3/8 fuel line handle? [Re: SuperStockWagon] #605009
02/06/10 10:28 PM
02/06/10 10:28 PM
Thigh-Gap Junction
@#$%&*! Offline
@#$%&*!  Offline
Thigh-Gap Junction
That's all I need know! Thanks Dave!
Those numbers make me have questions. The ET is about 1/2-second slow for the speed and the speed/hp relationship only works if the car weighs like 4150-lbs. There are a lot of possible explanations for all this but one is a car that falls on its face at 900-1000 feet due to fuel starvation.
Re: how much hp will 3/8 fuel line handle? [Re: @#$%&*!] #605010
02/06/10 11:04 PM
02/06/10 11:04 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Racing on a G-70-15 polyglass tires and 300# of ballast would probably be the problem.
Getting old just means you were smarter than some and luckier than others.
Re: how much hp will 3/8 fuel line handle? [Re: @#$%&*!] #605011
02/06/10 11:14 PM
02/06/10 11:14 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
it's a FAST car...quite literally
Re: how much hp will 3/8 fuel line handle? [Re: dannysbee] #605012
02/06/10 11:19 PM
02/06/10 11:19 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
Everyone mount the old school fuel tank on the front bumper and have 5 pounds of free fuel preasure. Dont even run a fuel pump , they are overrated.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: how much hp will 3/8 fuel line handle? [Re: go green] #605013
02/06/10 11:25 PM
02/06/10 11:25 PM
jamesc Offline
jamesc  Offline
comon Dean not all of us are fortunate enough to have to overcome XX pounds of intake manifold pressure
Re: how much hp will 3/8 fuel line handle? [Re: jamesc] #605014
02/07/10 12:18 AM
02/07/10 12:18 AM
Can anyone on here verify if the fluid dynamics theory are based on stationary commercial applications? I'm thinking, that if that is so, then they, it, does not apply to fluid systems mounted onto accelerating vehicle like race cars, race boats, airplanes and rocket ships
Re: how much hp will 3/8 fuel line handle? [Re: Cab_Burge] #605015
02/07/10 12:40 AM
02/07/10 12:40 AM
Thigh-Gap Junction
@#$%&*! Offline
@#$%&*!  Offline
Thigh-Gap Junction
Define "stationary', really, it's not as easy as you think. They say that the only truly stationary 'object' is the center of the universe, and that everything is moving away from it. Effectively, nothing is stationary and all motion is relative. The equation relating pressure of a column of fluid is from hydrostatics, absolutely. But that gravity is included means that an acceleration is involved, 32.2 ft/second^2. The more general form uses acceleration instead of gravity, any acceleration. A similar situation occurs with weight. Weight is just the force that results from a mass under the acceleration of gravity. Accelerate your car at 1G and the reaction force opposite your direction of travel equals the weight of the car/driver.
Re: how much hp will 3/8 fuel line handle? [Re: carolinacuda] #605016
02/07/10 08:04 AM
02/07/10 08:04 AM
NW of Indy
Thackdaddy Offline
Thackdaddy  Offline
NW of Indy
I've had a few tell me I may not have enough fuel for my car. My 74 cuda with 440 has 530ish Hp. I run a holley black pump with a regulator at carb which is an 850. no return. I doesnt stumble nor seem to fall on its face so i havent paid much thaught to it. My 1/4 mph is usually between 117-118mph.
Looks like you are good to go. The most important consideration is line size from the tank/cell to the pump
'71 Duster
Re: how much hp will 3/8 fuel line handle? [Re: DaveDudek] #605017
02/07/10 01:05 PM
02/07/10 01:05 PM
Utah, USA
1964superstock Offline
Utah, USA
I am curious about the fuel system combo in your awesome '69 Roadrunner. I am sure there are many others who would be interested, and helped with your advise on this issue.
1) What fuel pump are you using with the stock 5/16" fuel line?
2) Where is the fuel pump located?
3) What size fuel pickup are you using in the gas tank?
4) Are you using a fuel pressure regulator?
Thanks.
Re: how much hp will 3/8 fuel line handle? [Re: @#$%&*!] #605018
02/08/10 05:24 AM
02/08/10 05:24 AM
IL
knyech1 Offline
knyech1  Offline
IL
Hmmmmm, most basic fluid dynamics equations seem leave gravity out I was told for what we did it was not really necessary....The fact that everything has an inward angular acceleration (or "rotates" as most say) from the gravitational pull of the sun really has little effect on anything. One can consider an object stationary if it is sitting on the earth with no velocity, the motions of the earth relative to the object you are examining have such a minimal effect that they need not be taken into consideration.
As far as the 1G thing goes it sounds like you are saying that if I were to accelerate at 32.2ft/s^s in the positive x-dir the weight of the car plus me would be on my in the negative x-dir. Pretty crushing force. As you sit on your computer right now you are opposing 1G, defined by Newton's Second Law, F=ma; F being basically what you see when you hop up on the scale in your bathroom, it IS your weight. I am 160lb, so if I were to accelerate at 32.2ft/s^2 that would be a 2G force, and the force acting on my body would be 320lb-force downward onto my seat, and as Newton's Third Law explains, the seat would react with a force equal in magnitude and opposite in direction, making you feel the force being put upon you.
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: how much hp will 3/8 fuel line handle? [Re: knyech1] #605019
02/08/10 12:31 PM
02/08/10 12:31 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Exactly. I just don't see why you think the mass of the fuel can be ignored. (not you Kny')
Look at it this way, if you throw a cup full of water towards the air, the water continues upward (despite being under 14.7 psi of pressure from the atmosphere). Then the water comes back down, because the mass is being affected by gravity (acceleration). The water is still at 14.7psi through the entire situation, but the external forces on the way up, and the gravitational forces on the way down, still have an effect.
6psi is just gauge pressure, which is really 20.7psi actual, but it's all acting the same way.
Page 3 of 4 1 2 3 4
