Pump gas 410 SB Mopar using RHS heads!
#604784
02/05/10 01:08 PM
02/05/10 01:08 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
We just dyno'd a nice 410 sb mopar using the new RHS heads we sell. We sell them with 8mm 2.02x1.60 Ferrea 6000 series valves, Comp Beehive springs good for .600 lift, valve jobbed, bowl blend, ready to run OOTB for 1295.00. This 410 was Scat cast crank, I beam's, KB forged dish pistons, compression was 10.2:1. Cam was Comp HL295 hyd. cam. Hughes 1.55 rockers and pushrods and our heads like we sell them. We also tried 3 sets of headers, 2 different intakes and found the best combo was TTI 1 5/8 stepped header with Eddy rpm air gap and OOTB Holley 750DP with a 1" open spacer under it.
It made 485HP at 5400rpm and only dropped 8HP from 5400 to 6000rpm. It made 517TQ at 4400rpm!! This was a budget build, and will be in June's Car Craft issue which should be out in April I believe.
Re: Pump gas 410 SB Mopar using RHS heads!
[Re: Brian Hafliger]
#604785
02/05/10 01:28 PM
02/05/10 01:28 PM
Posts: 1,880 USA
Ron Silva
USA
How did the headers fit those heads?
That is great torque. Mopar strokers RULE! LOL.
SRT DEMON ONE SEAT
[Re: sshemi]
#604788
02/05/10 02:05 PM
02/05/10 02:05 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Heads flow 268@ .500 and 272@.550 and then they go turbulent. Flow curve is great from bottom to top. These are unported, just blended the valve job into the bowl. This is how we sell these heads. We tried rpm airgap, and super victor. The latter was down on TQ and HP up till 5000rpm...it was down ALOT!! We tried my 1 7/8 TTI's against TTI's smaller header and the small header beat it everywhere. Also tried some 1 3/4 Hookers and they were almost as good as the small TTI's but not quite. Yes they still hang in the port some, but didn't seem to hurt anything!!
Brian Hafliger
[Re: autoxcuda]
#604791
02/05/10 05:19 PM
02/05/10 05:19 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
Those heads flow nice for ootb
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
#604793
02/05/10 11:18 PM
02/05/10 11:18 PM
Posts: 27,480 So Cal
autoxcuda
So Cal
Brian, how do you think these cams perform with that same combo?
1. XE274H
2. XE275HL
Or something similar of your choice?
This was my choice!! With 10.2:1 you don't want a small cam in there or you'll detonate all over the place. Cranking compression was 180avg. any more and your not really pump gas friendly...at least where I'm at being sea level and dry air.
Smaller cam would only make more TQ earlier which would be good in a truck I guess but we already have 517ft.lbs. on hand!!
Sorry. I realize this is a whole combination/system. Just trying to relate it to the 450 hp thread. I guess I'm off topic. Maybe you have some suggestions over there.
[Re: autoxcuda]
#604794
02/05/10 11:47 PM
02/05/10 11:47 PM
Posts: 576 Escondido, CA
kick_the_reverb
Escondido, CA
Thanks for sharing Brian! Are these the Magnum version or the LA? Sounds like the Magnum version? Thanks, Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto Finally - disc brakes on the front. In the plans - rear disc brakes, B&M 250 blower
