Re: This is interesting......................
[Re: roadhazard]
#604221
02/07/10 04:49 PM
02/07/10 04:49 PM
Posts: 684 toronto
6PAK70CUDA
toronto
Has anybody else done some back to back testing I'm sure there's more opinions out there so let's hear them
Years ago I had a 500 inch RB with Stage V iron heads that were not very big. It was a Weiand Team G 4500 and 1050 Dom, would not run as quick as the 850 Annular Discharge on a TM7 Edelbrock with an adaptor. IIRC, two-tenths diff in ET(9.50 vs 9.70) IMO the runner length on that Team G was just way too short; you could see that to get the Dom pad they just cut into the runner length and shortened them. Now a more modern manifold would be another story...
[Re: Thumperdart]
#604223
02/07/10 06:21 PM
02/07/10 06:21 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Dom, every engine is different. I had my Dominator on a 650 cammed 440 with an M1 and adapter. One of the best in this area, Dale Cubic, set it for that engine. I then put the same carb on my 650 roller cammed Hemi using a 4500 intake. I thought it ran great, until Carburator Joe from APD, as mentioned by Rickster, totally went through it again. After getting a baseline of 505 RWHP, I gave them the carb. Changing nothing but bolting on the new carb, I gained a real world 30 RWHP. Then Vic(DIscoQuik), fine-tuned it for the street. It idles @875, and still runs 10.80's. I'd listen to your carb guy, and let him "tinker" with it. $400 is the going rate, I believe, for quality work. PM AndyF. He's the resident tinkerer and knows what works. I think he tunes in his sleep..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: Thumperdart]
#604224
02/07/10 06:39 PM
02/07/10 06:39 PM
Quicktree
Cab,I`m done racing for a while and need a dana first that way I don`t gernade the 8 3/4 and want to be established in Vegas better also. My car was chassis tuned w/the adapter but is was WAY out of the ballpark in terms of jetting and air bleeds which leads me to think I need a different/better fuel system. Thankxx for the offer though.
oh come on Dom you couldn't grenade that thing if you wanted to.
[Re: Cab_Burge]
#604227
02/07/10 09:18 PM
02/07/10 09:18 PM
Quicktree
It takes at least 750 HP RWHP to break any stock 8 3/4
yea but you have to build one that makes 750 hp first and then it has to make it off of the dyno
