Re: This is interesting...................... [Re: fullmetaljacket] #604219
02/07/10 03:08 PM
02/07/10 03:08 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
So it is safe to say that no one can truly make a Domi have manners on a street/strip car?
I run a 4150 on mine and some have said that a Domi would make it wail.
Ummmm NO! I drive a street car with a Dominator and it has perfrctly fine street manners. It is I think my fifth strep/street car with a Dominator and never had an issue. A Dominator is the most tunable carb Holley sells so if you cannot get one to work right street or strip you are doing it wrong
Like stated every combo is different but I share what I have seena nd found to be true. Once the carb is tuned for the application from my experience the 4500 intake wins. Just slapping it on and not doing any tuning is not an accurate measurement of ANY change you make to your car.
Re: This is interesting...................... [Re: Al_Alguire] #604220
02/07/10 03:42 PM
02/07/10 03:42 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I run a 9375 1050 on the street. the CARB SHOP.. set it up, right out of the box, works great.
If you believe in your carb guy. I would listen to him.
Re: This is interesting...................... [Re: roadhazard] #604221
02/07/10 04:49 PM
02/07/10 04:49 PM
toronto
6PAK70CUDA Offline
6PAK70CUDA  Offline
toronto
Has anybody else done some back to back testing
I'm sure there's more opinions out there so let's hear them
Years ago I had a 500 inch RB with Stage V iron heads that were not very big. It was a Weiand Team G 4500 and 1050 Dom, would not run as quick as the 850 Annular Discharge on a TM7 Edelbrock with an adaptor. IIRC, two-tenths diff in ET(9.50 vs 9.70) IMO the runner length on that Team G was just way too short; you could see that to get the Dom pad they just cut into the runner length and shortened them. Now a more modern manifold would be another story...
Re: This is interesting...................... [Re: Cab_Burge] #604222
02/07/10 05:48 PM
02/07/10 05:48 PM
State of confusion
Thumperdart Offline OP
State of confusion
Cab,I`m done racing for a while and need a dana first that way I don`t gernade the 8 3/4 and want to be established in Vegas better also. My car was chassis tuned w/the adapter but is was WAY out of the ballpark in terms of jetting and air bleeds which leads me to think I need a different/better fuel system. Thankxx for the offer though.
Re: This is interesting...................... [Re: Thumperdart] #604223
02/07/10 06:21 PM
02/07/10 06:21 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Dom, every engine is different. I had my Dominator on a 650 cammed 440 with an M1 and adapter. One of the best in this area, Dale Cubic, set it for that engine. I then put the same carb on my 650 roller cammed Hemi using a 4500 intake. I thought it ran great, until Carburator Joe from APD, as mentioned by Rickster, totally went through it again. After getting a baseline of 505 RWHP, I gave them the carb. Changing nothing but bolting on the new carb, I gained a real world 30 RWHP. Then Vic(DIscoQuik), fine-tuned it for the street. It idles @875, and still runs 10.80's. I'd listen to your carb guy, and let him "tinker" with it. $400 is the going rate, I believe, for quality work. PM AndyF. He's the resident tinkerer and knows what works. I think he tunes in his sleep..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: This is interesting...................... [Re: Thumperdart] #604224
02/07/10 06:39 PM
02/07/10 06:39 PM
Q
Quicktree Offline
Quicktree  Offline
Q
oh come on Dom you couldn't grenade that thing if you wanted to.
Re: This is interesting...................... [Re: Quicktree] #604225
02/07/10 07:16 PM
02/07/10 07:16 PM
It takes at least 750 HP RWHP to break any stock 8 3/4
Re: This is interesting...................... [Re: Quicktree] #604226
02/07/10 07:50 PM
02/07/10 07:50 PM
State of confusion
State of confusion
Actually quick, I don`t want to get a "I told you so" ESPECIALLY from you. I know that`s true Cab about em being bullet proof but just in case the dana is a good investement.
Re: This is interesting...................... [Re: Cab_Burge] #604227
02/07/10 09:18 PM
02/07/10 09:18 PM
Q
Quicktree Offline
Quicktree  Offline
Q
yea but you have to build one that makes 750 hp first and then it has to make it off of the dyno
